jQuery UI Widgets Forums Dialogs and Notifications Window Resize window issue
This topic contains 4 replies, has 2 voices, and was last updated by  Dimitar 10 years, 7 months ago.
  • Resize window issue #60196
    Rob
    As soon a vertical scroll bar appears on a resize action with the mouse it doesn’t seem to be possible to resize a second time. The horizontal resize cursor does not appear. This problem can be demonstrated using your offline demo jqxwindow/multiple-windows.htm
    Is this expected behaviour?
    Thanks, Rob
    Resize window issue #60197
    Rob
    Update to previous post. The resize cursor appears but the window can’t be resized.
    BTW : trying to edit a previous post using the ‘edit’ hyperlink on this page does not work. Clicking the hyperlink reloads the website
    Resize window issue #60218
    Hello Rob,
    We tested the demo and we could not reproduce the reported issue. Please make sure you are using the latest version of jQWidgets (3.5.0).
    Resize window issue #60233
    Rob
    Hello Dimitar,
    Just tested again with version 3.5 and i see the same behavior. (all current browsers on windows 7/32). So i guess that you and i test differently.
    Once the vertical scroll bar appears it is not possible anymore to re-size the window pulling on the right side of the window. Pulling on the left side remains possible.
    When the window is small enough to show a vertical scroll bar it’s possible to enlarge the window vertically, by pulling the top of the window, once the scroll bar disappears re-sizing horizontally from the right side of the window is possible again.
    Hope this makes it more clear
    Thanks, Rob
    Resize window issue #60235
    Hi Rob,
    If you wish you can put your window content in another div with a specified right margin. This way the div’s scrollbar and the right edge of the window will not be taking the same space and the resize should work on your side.
