jQuery UI Widgets Forums Grid Resize column with showfilterrow and in a div with position absolute
This topic contains 7 replies, has 3 voices, and was last updated by  Peter Stoev 11 years, 5 months ago.
  • codemaker
    I have a problem. I searched but I did not find a solution.
    I have a grid, where you are allowed to resize the column width. I have also a filter row. In my case I display the grid in a div with a style attribute “position: absolute;”. This is necessary, because I use a library with insert this attribute automatically.
    In this combination the resize function of the columns do not work correctly.
    An example is below.
    Do you have any solution?
    codemaker
    <meta charset="UTF-8">
    <title>xxx</title>
    <link href="core/lib/jqwidgets/styles/jqx.base.css" rel="stylesheet" />
    <link href="core/lib/jqwidgets/styles/jqx.web.css" rel="stylesheet" />
    <script src="core/lib/jquery/jquery.js"></script>
    <script type="text/javascript" src="core/lib/jqwidgets/jqx-all.js"></script>
    var theme = 'web';
    var data = {};
    var firstNames =
    var lastNames =
    var productNames =
    var priceValues =
    var generaterow = function (i) {
    var row = {};
    row["price"] = price;
    row["quantity"] = quantity;
    return row;
    for (var i = 0; i < 10; i++) {
    var row = generaterow(i);
    data[i] = row;
    localdata: data,
    datatype: "local",
    datafields:
    // initialize jqxGrid
    $("#jqxgrid").jqxGrid(
    width: 500,
    height: 350,
    sortable : false,
    columnsresize : true,
    showfilterrow : true,
    filterable : true,
    { text: 'Unit Price', datafield: 'price', width: 90, cellsalign: 'right', cellsformat: 'c2' },
    { text: 'Total', datafield: 'total', width: 100, cellsalign: 'right', cellsformat: 'c2' }
    <div style='position: absolute;'>
    <div style="float: left;" id="jqxgrid"></div>
    EDIT:
    It Works in ie 9 but I use firefox 24.0
    Hi codemaker,
    Please, find below a working sample with jQWidgets 3.0.3.
    <title id='Description'>This example shows how to create a Grid from Array data.</title>
    <script type="text/javascript" src="../../jqwidgets/jqxgrid.columnreorder.js"></script>
    var theme = 'web';
    var data = {};
    var firstNames =
    var lastNames =
    var productNames =
    var priceValues =
    var row = {};
    return row;
    data[i] = row;
    localdata: data,
    datatype: "local",
    datafields:
    width: 500,
    height: 350,
    sortable: false,
    showfilterrow: true,
    codemaker
    I am sorry, but it does not work for me!
    I downloaded jqx 3.0.3 and jquery 1.10.2 but I still have the same problem.
    Did you test with firefox 24.0?
    Hi codemaker,
    Resizing on my side works with FireFox 24.0. The only difference is that while a column is being resized, the Text is selected, too and that sometimes breaks the user experience and a new drag is required. Of course, we will improve that in the future releases.
    arajput
    We are similar issue in FF 24.0, resizing of the column selects the column header and also makes it nearly impossible to drag the column header edge.
    Do you guys have a handle on this issue, and when a fix would be available? we cannot go to prod with this issue, so any solution or workaround would be highly appreciated.
    Ashish
    Hi Ashish,
    Everything that I had to say about this topic can be found in my last answer.
    arajput
    Thank you for a very short tempered answer, but I was trying to get specifics on Of course, we will improve that in the future releases. (as we cannot have a broken application on FF!!!)
    We have already purchased an enterprise license, but unfortunately, find this kind of answer very unprofessional.
    Hi arajput,
    Columns Resizing works in Firefox and that is demonstrated in this demo: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/columnsresizing.htm?arctic. Columns Resizing when Filter Row is enabled works in Firefox, too. However, the columns resizing currently makes a browser selection which is unnecessary and should be improved in a future version. That is what I meant in my previous post. If you do not like how the columns resizing feature currently performs, then you have 2 temporary options – turn off columns resizing or turn off the filter row and use the filtering menu.
