jQuery UI Widgets Forums Lists ComboBox reset to default after making selecting
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 7 years, 3 months ago.
  • reset to default after making selecting #98182
    douglas168
    I have a jqxComboBox that does not highlight any item when show its dropdown list at first (selectedIndex: -1). After user first makes a selection from the dropdown list, next time any user click to show the dropdown list the previous user selection will be highlighted.
    Is there any way for jqxCombox to reset back to the default (no selection item highlighted)?
    Appreciate the help!
    Douglas
    reset to default after making selecting #98200
    Hello Douglas,
    Yes, you could reset this setting in any time you want with this approach:
    $("#jqxComboBox").jqxComboBox({ selectedIndex: -1 });
