jQuery UI Widgets › Forums › Chart › Rendering Problem
Tagged: chart, date, format, formatDate, jqxChart, jqxTabs, min, minValue, range selector, RangeSelector, render, rendering, tab, Tabs, value
This topic contains 11 replies, has 3 voices, and was last updated by Peter Stoev 10 years, 4 months ago.
AuthorRendering Problem Posts
I’ve a mix of different table, tab, chart. Now I edited “colorFunction” and starting from that I experience rendering problems. If I change the “rangeSelector” range in the chart, then some data are not displayed anymore.
The data are about 1000 sets.
Here my code:
<html lang=”en”>
<title id=’Description’>Anzeige der TSI-Werte.
</title>
<link rel=”stylesheet” href=”jqwidgets/jqwidgets/styles/jqx.base.css” type=”text/css” />
<link rel=”stylesheet” href=”jqwidgets/jqwidgets/styles/jqx.black.css” type=”text/css” />
<script type=”text/javascript” src=”jqwidgets/scripts/jquery-1.11.1.min.js”></script>
<script type=”text/javascript” src=”jqwidgets/scripts/demos.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxcore.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxtabs.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxcheckbox.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxmenu.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxgrid.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxgrid.edit.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxgrid.selection.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxbuttons.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxscrollbar.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxlistbox.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxdropdownlist.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxdata.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxdraw.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxchart.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxchart.core.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxchart.rangeselector.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/globalization/globalize.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/globalization/globalize.culture.de-DE.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxdatetimeinput.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxcalendar.js”></script>
<script type=”text/javascript”>$(document).ready(function () {
// Create a jqxMenu
$(“#jqxMenu”).jqxMenu({ width: ‘120’, mode: ‘vertical’, theme: ‘black’});
$(“#jqxMenu”).css(‘visibility’, ‘visible’);var initGrid = function () {
// and with parameter false if the synchronization failder.
commit(true);
},datafields: [
{ name: ‘datum’, type: ‘date’ },
{ name: ‘tsi_wert’, type: ‘number’ }
url: ‘tsi_werte.php’
};var dataAdapter = new $.jqx.dataAdapter(source);
$(“#jqxGrid”).jqxGrid(
width: ‘100%’,
height: ‘100%’,
theme: ‘black’,
showstatusbar: true,
// appends buttons to the status bar.
var container = $(“<div style=’overflow: hidden; position: relative; margin: 3px;’></div>”);
var addButton = $(“<div style=’float: left; margin-left: 5px;’><span style=’margin-left: 4px; position: relative; top: -3px;’>Add</span></div>”);
var deleteButton = $(“<div style=’float: left; margin-left: 5px;’><span style=’margin-left: 4px; position: relative; top: -3px;’>Delete</span></div>”);
var reloadButton = $(“<div style=’float: left; margin-left: 5px;’><span style=’margin-left: 4px; position: relative; top: -3px;’>Reload</span></div>”);
var searchButton = $(“<div style=’float: left; margin-left: 5px;’><span style=’margin-left: 4px; position: relative; top: -3px;’>Find</span></div>”);
container.append(addButton);
container.append(deleteButton);
container.append(reloadButton);
container.append(searchButton);
statusbar.append(container);
addButton.jqxButton({ width: 60, height: 20, theme: ‘black’ });
deleteButton.jqxButton({ width: 65, height: 20, theme: ‘black’ });
reloadButton.jqxButton({ width: 65, height: 20, theme: ‘black’ });
searchButton.jqxButton({ width: 50, height: 20, theme: ‘black’ });
// add new row.
addButton.click(function (event) {
var datarow = ”;
$(“#jqxGrid”).jqxGrid(‘addrow’, null, datarow[0]);
// delete selected row.
deleteButton.click(function (event) {
var selectedrowindex = $(“#jqxGrid”).jqxGrid(‘getselectedrowindex’);
var rowscount = $(“#jqxGrid”).jqxGrid(‘getdatainformation’).rowscount;
var id = $(“#jqxGrid”).jqxGrid(‘getrowid’, selectedrowindex);
$(“#jqxGrid”).jqxGrid(‘deleterow’, id);
// reload grid data.
reloadButton.click(function (event) {
$(“#jqxGrid”).jqxGrid({ source: getAdapter() });
// search for a record.
searchButton.click(function (event) {
$(“#jqxwindow”).jqxWindow(‘open’);
$(“#jqxwindow”).jqxWindow(‘move’, offset.left + 30, offset.top + 30);
//localization: getLocalization(‘de’),
{ text: ‘Datum’, datafield: ‘datum’, columntype: ‘datetimeinput’, cellsformat: ‘d’, width: 150,
{ text: ‘TSI-Wert’, datafield: ‘tsi_wert’, width: 100,
editor.jqxNumberInput({ decimalDigits: 2, digits: 4 });
var initChart = function () {
{ name: ‘datum’ },
{ name: ‘tsi_wert’ }
source, { async: false, autoBind: true, loadError: function (xhr, status, error) {
alert(‘Error loading “‘ + source.url + ‘” : ‘ + error); }
});var months = [‘Jan’, ‘Feb’, ‘Mar’, ‘Apr’, ‘Mai’, ‘Jun’, ‘Jul’, ‘Aug’, ‘Sep’, ‘Okt’, ‘Nov’, ‘Dez’];
var toolTipCustomFormatFn = function (value, itemIndex, serie, group, categoryValue, categoryAxis) {
var dataItem = dataAdapter.records[itemIndex];
return ‘<div style=”text-align:left”><b>Datum: ‘ + categoryValue.getDate() + ‘.’ + months[categoryValue.getMonth()] + ‘.’ + categoryValue.getFullYear() + ‘</b><br/>TSI-Wert: ‘ + dataItem.tsi_wert + ‘</div>’;
};// prepare jqxChart settings
var settings = {
title: “Übersicht TSI-Werte”,
borderLineWidth: 1,
showBorderLine: true,
enableAnimations: true,
enableCrosshairs: true,
showLegend: false,
animationDuration: 1500,
padding: { left: 5, top: 5, right: 10, bottom: 5 },
titlePadding: { left: 0, top: 0, right: 0, bottom: 10 },
xAxis:
dataField: ‘datum’,
type: ‘date’,
baseUnit: ‘day’,
minValue: new Date(2013, 0, 1),
maxValue: new Date(2013, 11, 31),
textRotationAngle: -45,
formatFunction: function (value) {
return value.getDate() + ‘.’ + months[value.getMonth()] + ‘.’ + value.getFullYear().toString().substring(2);
showGridLines: true,
rangeSelector: {
padding: { /*left: 0, right: 0,*/top: 30, bottom: 0 },
minValue: new Date(2004, 0, 1),
backgroundColor: ‘white’,
dataField: ‘tsi_wert’,
baseUnit: ‘month’,
showGridLines: false,
return months[value.getMonth()] + ‘\” + value.getFullYear().toString().substring(2);
colorScheme: ‘scheme01’,
seriesGroups:
type: ‘spline’,
toolTipFormatFunction: toolTipCustomFormatFn,
valueAxis:
unitInterval: 0.05,
minValue: 0.8,
maxValue: 1.2,
displayValueAxis: true,
description: ‘TSI-Wert’
series: [{
displayText: ‘TSI-Wert’,
//lineWidth: 1,
//lineWidthSelected: 1,
emptyPointsDisplay: ‘connect’,
colorFunction: function (value, itemIndex, serie, group) {
return (value < 1) ? ‘#FF0000’ : ‘#00FF00’;
// setup the chart
$(‘#jqxChart’).jqxChart(settings);
// init widgets.
var initWidgets = function (tab) {
switch (tab) {
case 0:
initGrid();
break;
case 1:
initChart();
break;
$(‘#jqxTabs’).jqxTabs({ width: 800, height: 560, theme: ‘black’, initTabContent: initWidgets });
<body class=’default’ style=’background: #222222′>
<div id=’jqxMenu’ style=”visibility: hidden; float: left;”>
<?php
include(“navigation.html”);
<div id=’jqxWidget’>
<div id=’jqxTabs’>-
<li style=”margin-left: 30px;”>
<div style=”height: 20px; margin-top: 5px;”>
<div style=”float: left;”>
<div style=”margin-left: 4px; vertical-align: middle; text-align: center; float: left;”>
Grafik</div>
Tabelle</div>
</div><div style=”overflow: hidden;”>
<div id=”jqxGrid”>
<div id=’jqxChart’ style=”width: 100%; height: 100%”>
</html>Hello elbnacht,
Could you, please, re-post your code and format it by selecting it and clicking the
code
button in the toolbar so that your script and HTML code are more readable?Best Regards,
http://www.jqwidgets.com/<!DOCTYPE html> <html lang=”en”> <head> <title id=’Description’>Anzeige der TSI-Werte. </title> <link rel=”stylesheet” href=”jqwidgets/jqwidgets/styles/jqx.base.css” type=”text/css” /> <link rel=”stylesheet” href=”jqwidgets/jqwidgets/styles/jqx.black.css” type=”text/css” /> <script type=”text/javascript” src=”jqwidgets/scripts/jquery-1.11.1.min.js”></script> <script type=”text/javascript” src=”jqwidgets/scripts/demos.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxcore.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxtabs.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxcheckbox.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxmenu.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxgrid.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxgrid.edit.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxgrid.selection.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxbuttons.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxscrollbar.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxlistbox.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxdropdownlist.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxdata.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxdraw.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxchart.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxchart.core.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxchart.rangeselector.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/globalization/globalize.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/globalization/globalize.culture.de-DE.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxdatetimeinput.js”></script> <script type=”text/javascript” src=”jqwidgets/jqwidgets/jqxcalendar.js”></script> <script type=”text/javascript”> $(document).ready(function () { // Create a jqxMenu $(“#jqxMenu”).jqxMenu({ width: ’120′, mode: ‘vertical’, theme: ‘black’}); $(“#jqxMenu”).css(‘visibility’, ‘visible’); var initGrid = function () { var source = { datatype: “json”, updaterow: function (rowid, rowdata, commit) { // synchronize with the server – send update command // call commit with parameter true if the synchronization with the server is successful // and with parameter false if the synchronization failder. commit(true); }, datafields: [ { name: 'datum', type: 'date' }, { name: 'tsi_wert', type: 'number' } ], url: ‘tsi_werte.php’ }; var dataAdapter = new $.jqx.dataAdapter(source); $(“#jqxGrid”).jqxGrid( { width: ’100%’, height: ’100%’, theme: ‘black’, source: dataAdapter, showstatusbar: true, renderstatusbar: function (statusbar) { // appends buttons to the status bar. var container = $(“<div style=’overflow: hidden; position: relative; margin: 3px;’></div>”); var addButton = $(“<div style=’float: left; margin-left: 5px;’><span style=’margin-left: 4px; position: relative; top: -3px;’>Add</span></div>”); var deleteButton = $(“<div style=’float: left; margin-left: 5px;’><span style=’margin-left: 4px; position: relative; top: -3px;’>Delete</span></div>”); var reloadButton = $(“<div style=’float: left; margin-left: 5px;’><span style=’margin-left: 4px; position: relative; top: -3px;’>Reload</span></div>”); var searchButton = $(“<div style=’float: left; margin-left: 5px;’><span style=’margin-left: 4px; position: relative; top: -3px;’>Find</span></div>”); container.append(addButton); container.append(deleteButton); container.append(reloadButton); container.append(searchButton); statusbar.append(container); addButton.jqxButton({ width: 60, height: 20, theme: ‘black’ }); deleteButton.jqxButton({ width: 65, height: 20, theme: ‘black’ }); reloadButton.jqxButton({ width: 65, height: 20, theme: ‘black’ }); searchButton.jqxButton({ width: 50, height: 20, theme: ‘black’ }); // add new row. addButton.click(function (event) { var datarow = ”; $(“#jqxGrid”).jqxGrid(‘addrow’, null, datarow[0]); }); // delete selected row. deleteButton.click(function (event) { var selectedrowindex = $(“#jqxGrid”).jqxGrid(‘getselectedrowindex’); var rowscount = $(“#jqxGrid”).jqxGrid(‘getdatainformation’).rowscount; var id = $(“#jqxGrid”).jqxGrid(‘getrowid’, selectedrowindex); $(“#jqxGrid”).jqxGrid(‘deleterow’, id); }); // reload grid data. reloadButton.click(function (event) { $(“#jqxGrid”).jqxGrid({ source: getAdapter() }); }); // search for a record. searchButton.click(function (event) { var offset = $(“#jqxgrid”).offset(); $(“#jqxwindow”).jqxWindow(‘open’); $(“#jqxwindow”).jqxWindow(‘move’, offset.left + 30, offset.top + 30); }); }, editable: true, //localization: getLocalization(‘de’), selectionmode: ‘multiplecellsadvanced’, columns: [ { text: 'Datum', datafield: 'datum', columntype: 'datetimeinput', cellsformat: 'd', width: 150, }, { text: 'TSI-Wert', datafield: 'tsi_wert', width: 100, createeditor: function (row, cellvalue, editor) { editor.jqxNumberInput({ decimalDigits: 2, digits: 4 }); } } ] }); } var initChart = function () { // prepare the data var source = { datatype: “json”, datafields: [ { name: 'datum' }, { name: 'tsi_wert' } ], url: ‘tsi_werte.php’ }; var dataAdapter = new $.jqx.dataAdapter( source, { async: false, autoBind: true, loadError: function (xhr, status, error) { alert(‘Error loading “‘ + source.url + ‘” : ‘ + error); } }); var months = ['Jan', 'Feb', 'Mar', 'Apr', 'Mai', 'Jun', 'Jul', 'Aug', 'Sep', 'Okt', 'Nov', 'Dez']; var toolTipCustomFormatFn = function (value, itemIndex, serie, group, categoryValue, categoryAxis) { var dataItem = dataAdapter.records[itemIndex]; return ‘<div style=”text-align:left”><b>Datum: ‘ + categoryValue.getDate() + ‘.’ + months[categoryValue.getMonth()] + ‘.’ + categoryValue.getFullYear() + ‘</b><br/>TSI-Wert: ‘ + dataItem.tsi_wert + ‘</div>’; }; // prepare jqxChart settings var settings = { title: “Übersicht TSI-Werte”, borderLineWidth: 1, showBorderLine: true, enableAnimations: true, enableCrosshairs: true, showLegend: false, animationDuration: 1500, padding: { left: 5, top: 5, right: 10, bottom: 5 }, titlePadding: { left: 0, top: 0, right: 0, bottom: 10 }, source: dataAdapter, xAxis: { dataField: ‘datum’, type: ‘date’, baseUnit: ‘day’, minValue: new Date(2013, 0, 1), maxValue: new Date(2013, 11, 31), textRotationAngle: -45, formatFunction: function (value) { return value.getDate() + ‘.’ + months[value.getMonth()] + ‘.’ + value.getFullYear().toString().substring(2); }, showGridLines: true, rangeSelector: { size: 120, padding: { /*left: 0, right: 0,*/top: 30, bottom: 0 }, minValue: new Date(2004, 0, 1), backgroundColor: ‘white’, dataField: ‘tsi_wert’, baseUnit: ‘month’, showGridLines: false, formatFunction: function (value) { return months[value.getMonth()] + ‘\” + value.getFullYear().toString().substring(2); } }, }, colorScheme: ‘scheme01′, seriesGroups: [ { type: 'spline', toolTipFormatFunction: toolTipCustomFormatFn, valueAxis: { unitInterval: 0.05, minValue: 0.8, maxValue: 1.2, displayValueAxis: true, description: 'TSI-Wert' }, series: [{ dataField: 'tsi_wert', displayText: 'TSI-Wert', //lineWidth: 1, //lineWidthSelected: 1, emptyPointsDisplay: 'connect', colorFunction: function (value, itemIndex, serie, group) { return (value < 1) ? '#FF0000' : '#00FF00'; } }] } ] }; // setup the chart $(‘#jqxChart’).jqxChart(settings); } // init widgets. var initWidgets = function (tab) { switch (tab) { case 0: initGrid(); break; case 1: initChart(); break; } } $(‘#jqxTabs’).jqxTabs({ width: 800, height: 560, theme: ‘black’, initTabContent: initWidgets }); }); </script> </head> <body class=’default’ style=’background: #222222′> <div id=’jqxMenu’ style=”visibility: hidden; float: left;”> <?php include(“navigation.html”); ?> </div> <div id=’jqxWidget’> <div id=’jqxTabs’> <li style=”margin-left: 30px;”> <div style=”height: 20px; margin-top: 5px;”> <div style=”float: left;”> </div> <div style=”margin-left: 4px; vertical-align: middle; text-align: center; float: left;”> Tabelle</div> </div> <div style=”height: 20px; margin-top: 5px;”> <div style=”float: left;”> </div> <div style=”margin-left: 4px; vertical-align: middle; text-align: center; float: left;”> Grafik</div> </div> <div style=”overflow: hidden;”> <div id=”jqxGrid”> </div> </div> <div style=”overflow: hidden;”> <div id=’jqxChart’ style=”width: 100%; height: 100%”> </div> </div> </div> </div> </body> </html>
Hi elbnacht,
The provided code is still unindented. Please either re-post your code as it is in the development environment you use (e.g. Visual Studio) or create a JSFiddle example demonstrating the issue.
http://www.jqwidgets.com/Sorry, now it works. Meanwhile I reduced the code from unnecessary code (tabs / grid). Result stays the same.
If I take out the “colorFunction”, than all data are shown.Jens
<html lang=”en”>
</title>
// Create a jqxMenu
$(“#jqxMenu”).css(‘visibility’, ‘visible’);var initChart = function () {
{ name: ‘datum’ },
var settings = {
borderLineWidth: 1,
showLegend: false,
xAxis:
dataField: ‘datum’,
type: ‘date’,
baseUnit: ‘day’,
rangeSelector: {
minValue: new Date(2010, 0, 1),
baseUnit: ‘month’,
seriesGroups:
type: ‘spline’,
valueAxis:
unitInterval: 0.05,
minValue: 0.8,
maxValue: 1.2,
series: [{
//lineWidth: 1,
// setup the chart
initChart();});
<?php
<div >
<div >
<div id=’jqxChart’ style=”width: 800px; height: 600px; margin-left: 10px;float: left;”>
</html>Maybe I found the cause: I use the date format from the database “YYYY-MM-DD” Any idea, how to change it to the probable used “MM/DD/YYYY”?
Can I use some of the globalize functions?Jens
Hi Jens,
You can use the data adapter formatDate function. You can find out more about it in the jqxDataAdapter Getting Started guide.
now I got it. It took some efforts.
The final reason of the rendering problem is a strange behavior of the “rangeSelector: minValue:”.
If this value is larger than the data of the source (i.e. minValue: new Date(2010, 0, 1) vs. 2004-01-01), than the time scale shows wrong data.
This leads as well in the bi-color chart to data drops while rendering.Please confirm, if you can verify this.
Jens
Hello Jens,
The range selector is supposed to contain more data points than the chart, not less. That is why your scenario is not supported and leads to unexpected behaviour. We recommend you set the rangeSelector’s minValue to at most the value of the xAxis minValue.
thats not what I mean.
Please consider the following situation:
The JSON source data starts from 2004-01-01 and goes till 2014-01-01.
The xAxis is set from minValue 2013-01-01 to maxValue 2014-01-01.
The range selector minValue is 2006-01-01. The maxValue is not given.In this case, the xAxis shows wrong values (JSON data are more than the range data).
Can you confirm this?
Other question related to this. can I define the following at the xAxis?
minValue: function (xMinToday) { xMinToday = new Date(); return xMinToday.setFullYear(xMinToday.getFullYear() - 1)}, maxValue: new Date(),
I just want to define the settings as today (minValue) and 1 years less from today (maxValue).
Jens
Hi Jens,
1) We confirm the reported issue regarding the chart range selector and will fix it as soon as possible.
2) It is not possible to set the property this way, but you can try the following approach as an alternative:
// before chart initialization var minValue = function(xMinToday) { xMinToday = new Date(); return xMinToday.setFullYear(xMinToday.getFullYear() - 1) }; // chart initialization minValue: minValue, maxValue: new Date(),
http://www.jqwidgets.com/Update: Issue is Fixed in jQWidgets 3.6.0
