jQuery UI Widgets Forums Grid Refresh problem after insert, delete .
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 8 years, 3 months ago.
  • Refresh problem after insert, delete . #90978
    edd
    Hi i have tried to refresh table after insert with all methods , can anyone help me ?
    ` <%@ Page Title=”” Language=”C#” MasterPageFile=”~/Conta.Master” AutoEventWireup=”true” CodeBehind=”TipSolicitari.aspx.cs” Inherits=”Conta.TipSolicitari1″ %>
    <asp:Content ID=”Content1″ ContentPlaceHolderID=”head” runat=”server”>
    </asp:Content>
    <asp:Content ID=”Content2″ ContentPlaceHolderID=”MainContent” runat=”server”>
    <link type=”text/css” href=”/jqwidgets/styles/jqx.base.css” rel=”stylesheet” />
    <link type=”text/css” href=”/jqwidgets/styles/jqx.classic.css” rel=”stylesheet” />
    <link type=”text/css” href=”/jqwidgets/styles/jqx.metro.css” rel=”stylesheet” />
    <link type=”text/css” href=”/jqwidgets/styles/jqx.office.css” rel=”stylesheet” />
    <link type=”text/css” href=”/jqwidgets/styles/jqx.energyblue.css” rel=”stylesheet” />
    <link type=”text/css” href=”/1.11.4/jquery-ui.min.css?” rel=”stylesheet” />
    <%–<script type=”text/javascript” src=”/javascript/jquery-2.2.3.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqx-all.js”></script>
    <script type=”text/javascript” src=”/javascript/jquery-1.11.1.min.js?”></script>
    <script type=”text/javascript” src=”/1.11.4/jquery-ui.min.js?”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqx-all.js?”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxcore.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxdropdownlist.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxmenu.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxgrid.filter.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxgrid.selection.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxcheckbox.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxgrid.sort.js”></script>
    <%– <script type=”text/javascript” src=”/jqwidgets/jqxcore.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxdata.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxbuttons.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxscrollbar.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxlistbox.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxgrid.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxpanel.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/globalization/globalize.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxcalendar.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxdatetimeinput.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxgrid.pager.js”></script>
    <script type=”text/javascript” src=”/jqwidgets/jqxgrid.columnsresize.js”></script>–%>
    <style type=”text/css”>
    .no-close .ui-dialog-titlebar-close {
    display: none;
    div.ui-dialog {z-index:1000;}
    div.ui-dialog-titlebar{display:none;}
    /*ui-widget-header ui-corner-all ui-helper-clearfix ui-draggable-handle*/
    /*div.ui-dialog {float: left; width: auto !important; display:none;}*/
    </style>
    var bInit = 1;
    var sUserName = “”;
    // function runADDbtn()
    // alert(“work”);
    // $(‘#addbutton’).click(function () {
    // //$(“#jqxgrid”).jqxGrid(‘clearfilters’);
    // alert(‘WORK1’);
    /*$(“#pageHome”).click(function () {
    window.location.replace(“Default.aspx”);
    $(‘#delogare’).click(function () {
    $(‘input[id$=btnLogout]’).click();
    $(‘img[title=Setari]’).click(function () {
    getUserForUpdateSettings($(this).parent().find(‘div’).attr(‘value’));
    //#R Hide all errors
    $(‘#alertOldPassU’).hide();
    $(‘#alertOldPassWrongU’).hide();
    $(‘#alertUsernameU’).hide();
    $(‘#alertPassU’).hide();
    $(‘#alertConfirmPassU’).hide();
    $(‘#alertEmail’).hide();
    var bInit = 1;
    var sUserName = “”;
    function closeIframeBind() {
    //$(‘#somediv’).dialog(‘close’);
    $(“#thedialog”).attr(‘src’, “about:blank”);
    $(‘#somediv’).dialog(‘destroy’);
    $(‘#jqxgrid’).jqxGrid(‘updatebounddata’);
    return false;
    function closeIframeNoBind() {
    return false;
    $(document).keypress(function (e) {
    if (e.keyCode === 13) {
    e.preventDefault();
    return false;
    function buildQueryString(data) {
    var str = ”;
    for (var prop in data) {
    if (data.hasOwnProperty(prop)) {
    str += prop + ‘=’ + data[prop] + ‘&’;
    $(‘#hidGridFormatedData’).val(formatedData);
    return str.substr(0, str.length – 1);
    var formatedData = ”;
    var totalrecords = 0;
    //start
    document.title = ‘Tip Solicitari’;
    sUserName = $(‘#’ + ‘<%=hdnLoginName.ClientID %>’).val();
    //add button bind
    $(‘#btnRight’).click(function(e) {
    var selectedOpts = $(‘[id$=ListBox1] option:selected’);
    if (selectedOpts.length == 0) {
    alert(“Nu ati selectat nimic pentru a adauga.”);
    e.preventDefault();
    $(“[id$=ListBox2]”).append($(selectedOpts).clone());
    $(selectedOpts).remove();
    var deletedid=””;
    for(var iIndex = 0;iIndex < $(selectedOpts).length;iIndex++){
    deletedid= $(selectedOpts)[iIndex].value;
    var searchedstring = “;” + deletedid + “;”;
    var bIsAlreadyInDB = false;
    if($(“[id$=hdnRemUsers]”).val().indexOf(searchedstring) != -1 ){
    $(“[id$=hdnRemUsers]”).val($(“[id$=hdnRemUsers]”).val().replace(deletedid + “;”,””));
    bIsAlreadyInDB = true;
    if($(“[id$=hdnAddedUsers]”).val() == ”){
    $(“[id$=hdnAddedUsers]”).val(“;”);
    if(!bIsAlreadyInDB)
    $(“[id$=hdnAddedUsers]”).val($(“[id$=hdnAddedUsers]”).val() +$(selectedOpts)[iIndex].value + “;” );
    e.preventDefault();
    //—————————DubleClickEvent
    $(“[id$=ListBox1]”).dblclick(function(e) {
    e.preventDefault();
    var deletedid=””;
    if(!bIsAlreadyInDB)
    e.preventDefault();
    //remove button bind
    $(‘#btnLeft’).click(function(e) {
    var selectedOpts = $(‘[id$=ListBox2] option:selected’);
    alert(“Nu ati selectat nimic pentru a sterge.”);
    e.preventDefault();
    //hdnRemUsers
    if($(“[id$=hdnRemUsers]”).val() == ”){
    $(“[id$=hdnRemUsers]”).val(“;”);
    var addedid= “”;
    addedid= $(selectedOpts)[iIndex].value;
    var searchedstringtoadd = “;” + addedid + “;”;
    if($(“[id$=hdnAddedUsers]”).val().indexOf(searchedstringtoadd) != -1 ){
    $(“[id$=hdnAddedUsers]”).val($(“[id$=hdnAddedUsers]”).val().replace(addedid + “;”,””));
    $(“[id$=hdnRemUsers]”).val($(“[id$=hdnRemUsers]”).val() +$(selectedOpts)[iIndex].value + “;” );
    $(“[id$=ListBox1]”).append($(selectedOpts).clone());
    e.preventDefault();
    //DubleClickEvent
    $(“[id$=ListBox2]”).dblclick(function(e) {
    e.preventDefault();
    //hdnRemUsers
    var addedid= “”;
    e.preventDefault();
    //—————————————————————————– ADD BUTTON———–
    //add button bind
    $(‘#btnRight1’).click(function(e) {
    var selectedOpts = $(‘[id$=ListBox3] option:selected’);
    e.preventDefault();
    $(“[id$=ListBox4]”).append($(selectedOpts).clone());
    var deletedid=””;
    if(!bIsAlreadyInDB)
    e.preventDefault();
    //——————DBCLICK SENDER
    $(“[id$=ListBox3]”).dblclick(function(e) {
    e.preventDefault();
    var deletedid=””;
    if(!bIsAlreadyInDB)
    e.preventDefault();
    $(‘#btnLeft2’).click(function(e) {
    var selectedOpts = $(‘[id$=ListBox4] option:selected’);
    e.preventDefault();
    //hdnRemUsers
    var addedid= “”;
    $(“[id$=ListBox3]”).append($(selectedOpts).clone());
    e.preventDefault();
    //——————–DBCLICK REMOVE
    $(“[id$=ListBox4]”).dblclick(function(e) {
    e.preventDefault();
    //hdnRemUsers
    var addedid= “”;
    e.preventDefault();
    //—————————————————————————–END ADD BUTTON———–
    type: “POST”,
    url: ‘/api/TipSolicitari.asmx/GetCustomers?’+ “filterscount=0&groupscount=0&sortdatafield=Nume&sortorder=asc&pagenum=0&pagesize=1500&recordstartindex=0&recordendindex=10&bInit=1&sUserName=”,
    pager: function (pagenum, pagesize, oldpagenum)
    // data: { bInit: bInit, sUserName: sUserName },
    dataType: “json”,
    success: function (data) {
    //………………………………………… bun
    var source = {
    { name: ‘ID’, type: ‘int’ },
    { name: ‘Nume’, type: ‘string’ },
    { name: ‘Responsabil’, type: ‘bool’ },
    { name: ‘Clasa’, type: ‘string’ }
    async: false,
    sort: function () {
    source.data = { bInit: bInit, sUserName: sUserName };
    if (bInit != ‘1’) {
    bInit++;
    filter: function ()
    if (bInit != ‘1’) {
    bInit++;
    var returnData = {};
    data = data.d;
    // totalrecords = data.count;
    //returnData.totalrecords = data.count;
    //returnData.records = data.data;
    return returnData;
    addRow: function (ID, rowData, position, commit) {
    var data = “insert=true&” + $.param(rowData);
    //var data = “insert=true&rowID=”+rowID+”&”+$.param(rowData);
    //var data = “insert=true&ID=228&Nume=test24&Responsabil=true&Clasa=test_Cl228”;
    $.ajaxSetup({ async: false });
    setTimeout(function () {
    dataType: ‘json’,
    url: ‘/api/TipSolicitari.asmx/TipSolicitari_Insert’,
    cache: false,
    data: data,
    //type: “GET”,
    commit(true);
    alert(commit(true));
    alert(‘work’);
    dataAdapter.dataBind();
    // error: function () {
    // commit(false);
    // alert(‘Does not work’);
    $(“#jqxgrid”).jqxGrid(‘updatebounddata’);
    }, 500);
    $.ajaxSetup({ async: true });
    return false;
    updateRow: function (rowID, rowData, commit) {
    var data = “update=true&” + $.param(rowData);
    //+ “&sortdatafield=CompanyName&sortorder=asc&filterscount=0&pagenum=0&pagesize=10”
    dataType: ‘json’,
    url: ‘/api/TipSolicitari.asmx/TipSolicitari_Update’,
    cache: false,
    data: data,
    commit(true);
    }, 500);
    return false;
    deleteRow: function (rowID, rowData, commit) {
    console.log(“Delete…….”);
    var tipsolicitareID = $(“#jqxgrid”).jqxGrid(‘getrowdata’, rowID).ID;
    var data = “request=deleteuser&ID=” + tipsolicitareID;
    //”&sortdatafield=CompanyName&sortorder=asc&filterscount=0&pagenum=0&pagesize=10″
    dataType: ‘json’,
    url: ‘/api/TipSolicitari.asmx/TipSolicitari_Delete’,
    cache: false,
    data: data,
    // type: “post”,
    commit(true);
    if (data == 1) var n1 = noty({ text: ‘Users <b>successfully </b> has been deleted!!’, timeout: 1500 });
    else var n2 = noty({ text: ‘Deletion is has not done!’ });
    }, 500);
    localdata: data.d
    //———————————————————-CONTEXT MENU ADAUGARE—————————————————————
    $(“#Nume_ID”).addClass(‘jqx-input’);
    $(“#Responsabil_ID”).addClass(‘jqx-input’);
    $(“#Clasa_ID”).addClass(‘jqx-input’);
    $(“#Nume_ID”).width(150);
    $(“#Nume_ID”).height(23);
    $(“#Responsabil_ID”).width(150);
    $(“#Responsabil_ID”).height(23);
    $(“#Clasa_ID”).width(150);
    $(“#Clasa_ID”).height(23);
    var dataAdapter = new $.jqx.dataAdapter(source, {autoBind: true });
    var editrow = -1;
    //—————————Creare Context Menu
    var contextMenu = $(“#Menu”).jqxMenu({
    width: 200,
    height: 58,
    autoOpenPopup: false,
    mode: ‘popup’
    $(“#jqxgrid”).on(‘contextmenu’, function () {
    return false;
    //————————————-Triger Context Menu Click
    $(“#addbutton”).click (function (event) {
    var args = event.args;
    //var rowindex = $(“#jqxgrid”).jqxGrid(‘getselectedrowindex’);
    // editrow = rowindex;
    $(“#popupWindow2”).jqxWindow({ position: { x: parseInt(offset.left) + 60, y: parseInt(offset.top) + 60} });
    //var dataRecord = $(“#jqxgrid”).jqxButton();
    // $(“#Nume_ID”).val(dataRecord.Nume);
    // $(“#Responsabil_ID”).val(dataRecord.Responsabil);
    // $(“#Clasa_ID”).val(dataRecord.Clasa);
    //$(“#price”).jqxNumberInput({ decimal: dataRecord.price });
    // show the popup window.
    $(“#popupWindow2”).jqxWindow(‘show’);
    $(“[id$=hdnAddedUsers]”).val(”);
    $(“[id$=hdnRemUsers]”).val(”);
    // var solicitareID = dataRecord.ID;
    //GetAssignedUsers(solicitareID);
    //GetNotAssignedUsers(0);
    GetNotAssignedUsers_AddContext(0);
    //——————————–START PopUp Window and Button’s
    width: 500,
    height: 400,
    resizable: true,
    isModal: true,
    autoOpen: false,
    cancelButton: $(“#Cancel2”),
    modalOpacity: 0.01
    // $(“#Cancel”).jqxButton({ theme: theme });
    // $(“#Save”).jqxButton({ theme: theme });
    //—————————update the edited row when the user clicks the ‘Save’ button
    $(“#Save2”).click(function () {
    //if (editrow >= 0)
    var row = { Clasa: $(“#Clasa_ID”).val(), Nume: $(“#Nume_ID”).val(), Responsabil: $(“#Responsabil_ID”).val()};
    //price: parseFloat($(“#price”).jqxNumberInput(‘decimal’))
    AddButton(row);
    var postData =
    dataAdapter.bindBindingUpdate();
    //$(“#jqxGrid”).jqxGrid(“updatebounddata”);
    var rowid = $(“#jqxgrid”).jqxGrid(‘getrowid’, editrow);
    $(‘#jqxgrid’).jqxGrid(‘updaterow’, rowid, row);
    $(“#popupWindow2”).jqxWindow(‘hide’);
    $(‘#jqxgrid’).jqxGrid(‘updatebounddata’, ‘cells’);
    var deletedUsers = $(“[id$=hdnRemUsers]”).val().split(“;”);
    if(deletedUsers != null && deletedUsers != ‘undefined’ && deletedUsers.length > 0){
    for(var iIndex = 0; iIndex < deletedUsers.length;iIndex++){
    if($.isNumeric(deletedUsers[iIndex]))
    GetNotAssignedUsers(deletedUsers[iIndex], row.ID);
    var addedUsers = $(“[id$=hdnAddedUsers]”).val().split(“;”);
    if(addedUsers != null && addedUsers != ‘undefined’ && addedUsers.length > 0){
    for(var iIndex = 0; iIndex < addedUsers.length;iIndex++){
    if($.isNumeric(addedUsers[iIndex])){
    //SaveFunctionButton(addedUsers[iIndex], tipsolid);
    //———————————————END CONTEXT MENU ADD———————————————–
    //———————————————initializare contextMenu———————————————
    $(“#ID”).addClass(‘jqx-input’);
    $(“#Nume”).addClass(‘jqx-input’);
    $(“#Responsabil”).addClass(‘jqx-input’);
    $(“#Clasa”).addClass(‘jqx-input’);
    $(“#ID”).width(150);
    $(“#ID”).height(23);
    $(“#Nume”).width(150);
    $(“#Nume”).height(23);
    $(“#Responsabil”).width(150);
    $(“#Responsabil”).height(23);
    $(“#Clasa”).width(150);
    $(“#Clasa”).height(23);
    // if (theme.length > 0) {
    // $(“#firstName”).addClass(‘jqx-input-‘ + theme);
    // $(“#lastName”).addClass(‘jqx-input-‘ + theme);
    // $(“#product”).addClass(‘jqx-input-‘ + theme);
    //$(“#ID”).jqxNumberInput({ width: 150, height: 23, inputMode: ‘simple’, spinButtons: true });
    //$(“#price”).jqxNumberInput({ symbol: ‘$’, width: 150, height: 23, spinButtons: true });
    var editrow = -1;
    width: 200,
    height: 58,
    mode: ‘popup’
    return false;
    $(“#Menu”).on(‘itemclick’, function (event) {
    if ($.trim($(args).text()) == “Editati Randul Selectat”)
    editrow = rowindex;
    $(“#popupWindow”).jqxWindow({ position: { x: parseInt(offset.left) + 60, y: parseInt(offset.top) + 60} });
    $(“#ID”).val(dataRecord.ID);
    $(“#Nume”).val(dataRecord.Nume);
    $(“#Responsabil”).val(dataRecord.Responsabil);
    $(“#Clasa”).val(dataRecord.Clasa);
    $(“#popupWindow”).jqxWindow(‘show’);
    GetNotAssignedUsers(solicitareID);
    else
    var rowid = $(“#jqxgrid”).jqxGrid(‘getrowid’, rowindex);
    $(“#jqxgrid”).jqxGrid(‘deleterow’, rowid);
    $(“#jqxgrid”).on(‘rowclick’, function (event) {
    if (event.args.rightclick) {
    $(“#jqxgrid”).jqxGrid(‘selectrow’, event.args.rowindex);
    contextMenu.jqxMenu(‘open’, parseInt(event.args.originalEvent.clientX) + 5 + scrollLeft, parseInt(event.args.originalEvent.clientY) + 5 + scrollTop);
    return false;
    //——————————–START PopUp Window and Buttons
    width: 500,
    height: 400,
    resizable: true,
    isModal: true,
    autoOpen: false,
    cancelButton: $(“#Cancel”),
    modalOpacity: 0.01
    if (editrow >= 0)
    var row = { ID: $(“#ID”).val(), Clasa: $(“#Clasa”).val(), Nume: $(“#Nume”).val(), Responsabil: $(“#Responsabil”).val()};
    //var listbox = { };
    DeleteFromAssignedUser(deletedUsers[iIndex], row.ID);
    SaveFunction(addedUsers[iIndex], row.ID);
    //————————————–finishContextMenu———————–
    //——————————————————————————————-filtru
    var addfilterUser = function () {
    var filter_or_operator = 1;
    var filtervalue = $(‘#UserFullName’).text().trim();
    var filtercondition = ‘contains’;
    var filter1 = filtergroup.createfilter(‘stringfilter’, filtervalue, filtercondition);
    // add the filters.
    $(“#jqxgrid”).jqxGrid(‘addfilter’, ‘Catre’, filtergroup);
    //return filtergroup;
    $(“#jqxgrid”).jqxGrid(‘applyfilters’);
    var addfilterInit = function () {
    var filtertype = ‘stringfilter’;
    var filtervalue = ‘Initiat’;
    var filter1 = filtergroup.createfilter(‘numericfilter’, filtertype, filtervalue, filtercondition);
    // add the filters.
    $(“#jqxgrid”).jqxGrid(‘addfilter’, ‘Initiat’, filtergroup);
    $(“#jqxgrid”).jqxGrid({
    theme: ‘energyblue’,
    width: ‘100%’,
    //height: 280,
    width: 980,
    enabletooltips: true,
    selectionmode: ‘multiplerowsextended’,
    //selectionmode: ‘checkbox’,
    sorttogglestates: 1,
    showfilterrow: true,
    autorowheight: true,
    pagesize: 10,
    pagesizeoptions: [’10’, ’20’, ’50’, ‘100’, ‘200’, ‘226’],
    altrows: true,
    enablemousewheel: true,
    editmode: ‘click’,
    showeverpresentrow: true,
    everpresentrowposition: “top”,
    //virtualmode: true,
    return obj.data;
    { dataField: ‘ID’, text: ‘ID’, width: 90, filtertype: ‘number’, autoresizable: true },
    { dataField: ‘Nume’, columntype: ‘textbox’, text: ‘Nume’, width: 280, filtertype: ‘input’ },
    { dataField: ‘Responsabil’, columntype: ‘textbox’, text: ‘Responsabil’, width: 260, filtertype: ‘bool’, columntype: ‘checkbox’},
    { dataField: ‘Clasa’, columntype: ‘textbox’, text: ‘Clasa’, width: 350, filtertype: ‘input’},
    ready: function ()
    addfilterUser();
    addfilterInit();
    // apply the filters.
    error: function (xmlHttpRequest, textStatus, errorThrown) {
    console.log(xmlHttpRequest.responseText);
    console.log(textStatus);
    console.log(errorThrown);
    // var editmodes = [‘Double-Click’];
    // $(“#editmodes”).jqxDropDownList({
    // autoDropDownHeight: true,
    // dropDownWidth: 150,
    // width: 150,
    // height: 25,
    // selectedIndex: 0,
    // source: editModes
    // $(“#ID”).jqxCheckBox({ checked: true });
    // $(“#Nume”).jqxCheckBox({ checked: true });
    // $(“#Clasa”).jqxCheckBox({ checked: true });
    // $(“#Responsabil”).jqxCheckBox({ checked: true });
    // //$(“#quantity”).jqxCheckBox({ checked: true });
    // // change the Edit mode.
    // $(“#editmodes”).on(‘select’, function (event) {
    // var index = event.args.index;
    // var editMode = index == 0 ? ‘click’ : index == 1 ? ‘dblclick’ : ‘selectedcell’;
    // $(“#jqxgrid”).jqxGrid({ editmode: editMode });
    // // change the Columns Editable state.
    // $(“#ID, #Nume, #Responsabil, #Clasa”).on(‘change’, function (event) {
    // var datafield = event.target.id;
    // $(“#jqxgrid”).jqxGrid(‘setcolumnproperty’, datafield, ‘editable’, event.args.checked);
    function GetParams(data) {
    data.pagenum = data.pagenum || 0;
    data.pagesize = data.pagesize || 10;
    data.sortdatafield = data.sortdatafield || ‘ID’;
    data.sortorder = data.sortorder || ‘asc’;
    data.filterscount = data.filterscount || 0;
    formatedData = buildQueryString(data);
    return formatedData;
    //—————————————————————-until here—————————————–
    //————————————————————————————-Function for BUTTON ADD ——–
    function GetNotAssignedUsers_AddContext(tipSolicitareID){
    var data = jQuery.parseJSON(‘{“ID”:”‘ + tipSolicitareID + ‘”}’);
    $(“[id$=ListBox4]”).empty();
    type:’post’,
    url: ‘/api/TipSolicitari.asmx/Users_AddContext’,
    dataType: “json”,
    data:JSON.stringify(data),
    var users = $.parseJSON(data.d);
    $.each(users, function(index, value) {
    $(“[id$=ListBox3]”).append($(‘<option>’).text(value.UserName).val(value.ID));
    function SaveFunctionButton(userid, tipsolid)
    var data = jQuery.parseJSON(‘{“tipsolid”:”‘ + tipsolid + ‘”, “userid”:”‘ + userid + ‘”}’);
    type:’post’,
    url: ‘/api/TipSolicitari.asmx/SaveFunctionButton’,
    dataType: “json”,
    alert(‘debug1SAVE’);
    //————————————————————————————END Function BUTTON ADD———
    function GetAssignedUsers(tipSolicitareID){
    $(“[id$=ListBox2]”).empty();
    var data = jQuery.parseJSON(‘{“ID”:”‘+ tipSolicitareID + ‘”}’);
    type:’post’,
    url: ‘/api/TipSolicitari.asmx/Useri_Asignati’,
    dataType: “json”,
    //listbox2
    //$(“[id$=ListBox2]”)
    $(“[id$=ListBox2]”).append($(‘<option>’).text(value.UserName).val(value.ID));
    //$(“[id$=hdnAddedUsers]”).val($(“[id$=hdnAddedUsers]”).val() + “;” + value.ID + “;”);
    function GetNotAssignedUsers(tipSolicitareID){
    $(“[id$=ListBox1]”).empty();
    type:’post’,
    url: ‘/api/TipSolicitari.asmx/Useri_Neasignati’,
    dataType: “json”,
    $(“[id$=ListBox1]”).append($(‘<option>’).text(value.UserName).val(value.ID));
    function SaveFunction(userid, tipsolid)
    type:’post’,
    url: ‘/api/TipSolicitari.asmx/UserToTipSolicitare_Insert’,
    dataType: “json”,
    //alert(‘debug1’);
    setTimeout(function() {$(“#jqxgrid”).jqxGrid(‘userid’,{datatype:’json’}); },50);
    function DeleteFromAssignedUser(userid, tipsolid){
    var data = jQuery.parseJSON(‘{“tipsolid”:”‘ + tipsolid + ‘”, “userid”:”‘ + userid + ‘”}’ );
    type:’post’,
    url: ‘/api/TipSolicitari.asmx/UserToTipSolicitare_DELETE’,
    dataType: “json”,
    // alert(‘debug2’);
    function AddButton(row){
    var Nume_ID=$(‘#Nume_ID’).val();
    var Responsabil_ID=$(‘#Responsabil_ID’).val();
    var Clasa_ID=$(‘#Clasa_ID’).val();
    //SaveFunction(addedUsers[iIndex], row.ID);
    var data = “insert=true&Nume_ID=” + Nume_ID + “&Responsabil_ID=” + Responsabil_ID + “&Clasa_ID=” + Clasa_ID+ “&UserIDs=” + addedUsers;
    dataType: ‘json’,
    url: ‘/api/TipSolicitari.asmx/TipSolicitari_Insert_AddButton’,
    //url: ‘/api/TipSolicitari.asmx/SaveFunctionButton’,
    cache: false,
    data: data,
    type: “get”,
    commit(true);
    alert(‘work’);
    console.log(data);
    // commit(false);
    //setTimeout(function() {$(“#jqxgrid”).jqxGrid(‘setGridParam’,{datatype:’json’}); },5);
    return false;
    // void Page_Load(Object sender, EventArgs e)
    // if(!IsPostBack)
    // // Declare the query string.
    // String queryString =
    // “Select [ID], [Nume], [Responsabil], [Clasa] From [TipSolicitare]”;
    // // Run the query and bind the resulting DataSet
    // // to the GridView control.
    // DataSet ds = GetData(queryString);
    // if (ds.Tables.Count > 0)
    // AuthorsGridView.DataSource = ds;
    // AuthorsGridView.DataBind();
    // else
    // Message.Text = “Unable to connect to the database.”;
    // DataSet GetData(String queryString)
    // // Retrieve the connection string stored in the Web.config file.
    // String connectionString = ConfigurationManager.ConnectionStrings[“connectionString”].ConnectionString;
    // DataSet ds = new DataSet();
    // try
    // // Connect to the database and run the query.
    // SqlConnection connection = new SqlConnection(connectionString);
    // SqlDataAdapter adapter = new SqlDataAdapter(queryString, connection);
    // // Fill the DataSet.
    // adapter.Fill(ds);
    // catch(Exception ex)
    // // The connection failed. Display an error message.
    // return ds;
    //var data = jQuery.parseJSON(‘{“Nume”:”‘ + Nume + ‘”, “Responsabil”:”‘ + Responsabil + ‘”, “Clasa”:”‘ + Clasa + ‘”}’);
    // $.ajax({
    // //type:’post’,
    // url: ‘/api/TipSolicitari.asmx/TipSolicitari_Insert’,
    // contentType: “application/json; charset=utf-8”,
    // dataType: “json”,
    // data:JSON.stringify(data),
    // success: function (data) {
    // alert(‘debug2’);
    // error: function (xmlHttpRequest, textStatus, errorThrown) {
    // console.log(xmlHttpRequest.responseText);
    // console.log(textStatus);
    // console.log(errorThrown);
    <input type=”hidden” id=”gridData” name=”gridData” />
    <input type=”hidden” id=”hidGridFormatedData” name=”hidGridFormatedData” />
    <input type=”hidden” id=”hdnLoginID” name=”hdnLoginID” runat=”server” />
    <input type=”hidden” id=”hdnLoginName” name=”hdnLoginName” runat=”server” />
    <input type=”hidden” id=”hdnIsPostBack” name=”hdnIsPostBack” runat=”server” />
    <input type=”hidden” id=”hdnRemUsers” name=”hdnRemUsers” runat=”server” />
    <input type=”hidden” id=”hdnAddedUsers” name=”hdnAddedUsers” runat=”server” />
    <%– <input type=”hidden” id=”hdnAddedUsers2″ name=”hdnAddedUsers2″ runat=”server” />–%>
    <div id=”form1″ runat=”server” class=”content”>
    <div style=”float: left; vertical-align: top; margin-left: 20px; margin-right: 10px;
    margin-top: 5px; font-weight: bold;”>
    <span id=”ctl00_SiteMapPath1″>Skip Navigation Links<span>Home</span><span> > </span><span>Tip Solicitari</span></span>
    <div id=”templateListaFirme” runat=”server” style=”display: inline-block; margin-left: 20px; min-height: 0px;”>
    <div style=”margin: 0px;”>
    <div style=”width: 1200px; margin: 0px auto; display: block; height: 1px;”>
    <div style=”float: left;”>
    <div style=’margin-left: 20px; margin-bottom: 20px; font-size: 14px; font-family: Trebuchet MS;
    color: Red’>
    <u><b>Click dreapta pe linie pentru editare/stergere</b></u></div>
    <div style=’display: inline;’>
    <div style=’margin-left: 10px; margin-bottom: 20px; display: inline;’>
    <input type=”button” value=”Adaugare” id=”addbutton” style=”margin-bottom: 7px;”/>
    <div id=’jqxWidget’ style=”font-size: 12px; font-family: Trebuchet MS;”>
    <div id=”jqxgrid”>
    <div id=”popupWindow” >
    <div>Editare</div>
    <div style=”overflow: hidden;”>
    <table>
    <tr>
    <td align=”right”>ID:</td>
    <td align=”left”><input id=”ID” /></td>
    </tr>
    <tr>
    <td align=”right”>Clasa:</td>
    <td align=”left”><input id=”Clasa” /></td>
    </tr>
    <tr>
    <td align=”right”>Nume:</td>
    <td align=”left”><input id=”Nume” /></td>
    </tr>
    <tr>
    <td align=”right”>Responsabil:</td>
    <td align=”left”><input id=”Responsabil” /></td>
    </tr>
    <%–<tr>
    <td align=”right”>Price:</td>
    <td align=”left”><div id=”price”></div></td>
    </tr>–%>
    <tr>
    <td colspan=2>
    <div style=”float:left;”>
    <asp:ListBox ID=”ListBox1″ runat=”server” multiple=”multiple” name=”ListBox1″ ClientID=”Static” style=”width:160px;border:solid 1px #b5b5b5;” >
    </asp:ListBox>
     <input type=’button’ id=’btnRight’ value =’ >> ‘ />
    <br/>
     <input type=’button’ id=’btnLeft’ value =’ << ‘/>
    <asp:ListBox ID=”ListBox2″ runat=”server” multiple=”multiple” name=”ListBox2″ ClientIDMode=”Static” style=”width:160px;border:solid 1px #b5b5b5;”>
    </asp:ListBox>
    </td>
    </tr>
    <tr>
    <td align=”right”></td>
    <td style=”padding-top: 10px;” align=”right”><input style=”margin-right: 5px;” type=”button” id=”Save” value=”Save” /><input id=”Cancel” type=”button” value=”Cancel” /></td>
    </tr>
    </table>
    <div id=’Menu’>
    • Editati Randul Selectat
    • Stergeti Randul Selectat
    <div id=”popupWindow2″ >
    <div>Editare</div>
    <table>
    <tr>
    <td align=”left”><input id=”Nume_ID” /></td>
    </tr>
    <tr>
    <td align=”left”><input id=”Clasa_ID” /></td>
    </tr>
    <tr>
    <td align=”left”><!–input id=”Responsabil_ID” /–><select id=”Responsabil_ID”><option value=”true”>True</option><option value=”false”>False</option></select></td>
    </tr>
    <tr>
    <td colspan=2>
    <asp:ListBox ID=”ListBox3″ runat=”server” multiple=”multiple” name=”ListBox3″ ClientID=”Static” style=”width:160px;border:solid 1px #b5b5b5;” >
    </asp:ListBox>
     <input type=’button’ id=’btnRight1′ value =’ >> ‘/>
    <br/>
     <input type=’button’ id=’btnLeft2′ value =’ << ‘/>
    <asp:ListBox ID=”ListBox4″ runat=”server” multiple=”multiple” name=”ListBox4″ ClientIDMode=”Static” style=”width:160px;border:solid 1px #b5b5b5;”>
    </asp:ListBox>
    </td>
    </tr>
    <tr>
    <td style=”padding-top: 10px;” align=”right”><input style=”margin-right: 5px;” type=”button” id=”Save2″ value=”Salvare” /><input id=”Cancel2″ type=”button” value=”Anulare” /></td>
    </tr>
    </table>
    </asp:Content>
    Refresh problem after insert, delete . #91101
    Hello edd,
    I did one fast review of your code, but this is one complicated source code and we cannot spend as much time on each one project.
    Please, provide us a small example that demonstrates a concrete issue.
    That I noticed:
    – the places where you use the callbacks of the DataAdapter source – “addRow” need to be with lowercase letters “addrow” (the same thing goes for “updateRow” and “deleteRow”).
    – when you use “rendergridrows” need to set virtualmode: true. Both are interconnected.
    I would like to suggest you this demo (in the ASP.NET section) and this article.
    Also, I would like to ask you for any error messages?
    Thank you for your understanding.
