jQuery UI Widgets Forums Grid Problems with virtualscroll, if jquery 3.x.x is used
This topic contains 3 replies, has 2 voices, and was last updated by  Dimitar 8 years, 9 months ago.
  • badera
    Dear all
    Just for information: After an update from jquery 2.x.x to 3.x.x (while having jqwidgets 4.1.2), we observed a big issue using jqxgrid and virtual scroll (with server side filtering / sorting, but without paging [angularjs use case, but I think it would occur also without angular): As soon as we sort on any column AND scroll down a little bit in the grid, the grid endlessly flickers and reload data… going back to jquery 2.2.4 solved the problem.
    I do not have the time to prove this with a minimal example (because we also need a backend for this).
    But I show it with a short video:
    So it would be great, if you could throw an eye on this (there are probably other issues, if jquery 3.x.x is used).
    – badera
    Hello badera,
    Thank you for your feedback. Could you, please, share if there are any errors thrown in your browser’s console when the issue occurs? Please note, that jQuery 3 is still not supported by jQWidgets, but the support is in our official plans.
    badera
    Hi Dimitar
    On every such “reload”, one js error occurs:
    We have bought jqWidgets and have the source package; if it helps, I could also use the non-uglified jqx-all.js, if you need more infos than just line 7.
    Hi badera,
    Thank you. We have noted this issue and will do our best for it to be resolved when jQuery 3 is officially supported by jQWidgets.
