jQuery UI Widgets Forums Layouts Docking Problems with 'orientation' …
This topic contains 2 replies, has 2 voices, and was last updated by  stephan 11 years, 10 months ago.
  • Problems with 'orientation' … #22882
    stephan
    I’d like to have my windows dock hrizontally, yet they always dock vertically no matter how I set the ‘orientation’ option. Have a look at this fiddle:
    http://jsfiddle.net/qMQhg/2/
    The windows will dock only vertically. Out of desperation I also tested setting ‘Orientation’ to vertical, yet this changed nothing.
    So my question is: how do I get my windows to dock only horizontally instead of only vertically ?
    Stephan
    Problems with 'orientation' … #22936
    Hello Stephan,
    To achieve horizontal orientation, you should add more panels. It is the panels that are aligned, not the windows inside.
    In your example, change the script to:
    $('#myApp').append('<div id="dock" />');
    $('#dock').append('<div id="panel1" />');
    $('#dock').append('<div id="panel2" />');
    $('#panel1').append('<div id="window1"><div>Header 1</div><div>Content 1</div></div>');
    $('#panel1').append('<div id="window2"><div>Header 2</div><div>Content 2</div></div>');
    $('#panel2').append('<div id="window3"><div>Header 3</div><div>Content 3</div></div>');
    $("#dock").jqxDocking({
    width: "300",
    mode: 'docked',
    orientation: 'horizontal',
    //orientation: 'vertical',
    Problems with 'orientation' … #22959
    stephan
    Hi Dimitar,
    Ok, thanks, I understand now. So I can not get this dynamic “remove” effect and animation for the horizontal direction ?
    You know: when I drag something out of a panel the elements below slide upwards to fill the space vacated by the window that is being dragged away. I wanted to get this effect horizontally: so the remaining horizontal windows slide to the left side.
    Stephan
