jQuery UI Widgets Forums Grid Problems when binding grid to remote data
This topic contains 5 replies, has 3 voices, and was last updated by  tomrauch 10 years ago.
  • vudh
    First, thanks for your excellent grid plug-in. I’m looking into features before purchasing a license.
    I tried to bind the grid to jsonp data from WCF data serivices as follows:
    datatype: “jsonp”,
    { name: ‘Navn’ },
    { name: ‘Nummer’ },
    { name: ‘VF_Adresse1’ }
    url: url for WCF data services,
    root: ‘GetWindowGridDataResult’
    $(“#jqxgrid”).jqxGrid(
    { text: ‘Name’, datafield: ‘Navn’, width: 200 },
    { text: ‘Number’, datafield: ‘Nummer’, width: 170 },
    { text: ‘Address’, datafield: ‘VF_Adresse1’, minwidth: 110 }
    When debugging in Chrome, I see the returned json data from WCF data services as follows:
    GetWindowGridDataResult: “[{“Navn”:”New Customer”,”Nummer”:”234″,”VF_Adresse1″:”Address of Customer”},{“Navn”:”trung”,”Nummer”:”13123″,”VF_Adresse1″:”fghfccf”},{“Navn”:”customer 1″,”Nummer”:”234324″,”VF_Adresse1″:”sdfsdfsd”}]”
    However, the grid displayed no rows. Could you please help me?
    Thanks in advance,
    vudh.
    Hi vudh,
    I debugged the scenario locally by using your initialization and the provided data and found out that the ajax call returns a parse error because there were missing ” characters in the data.
    Here’s the modified file that I was able to load into the Grid:
    {"GetWindowGridDataResult":[
    {"Navn":"New Customer","Nummer":"234","VF_Adresse1":"Address of Customer"},
    {"Navn":"trung","Nummer":"13123","VF_Adresse1":"fghfccf"},
    {"Navn":"customer 1","Nummer":"234324","VF_Adresse1":"sdfsdfsd"}
    Here’s my initialization:
    <script type="text/javascript" src="../../scripts/jquery-1.7.2.min.js"></script>
    var theme = '';
    { name: 'Navn' },
    { name: 'Nummer' },
    { name: 'VF_Adresse1' }
    root: 'GetWindowGridDataResult',
    url: 'testdata.txt'
    $("#jqxgrid").jqxGrid(
    { text: 'Name', datafield: 'Navn', width: 200 },
    { text: 'Number', datafield: 'Nummer', width: 170 },
    { text: 'Address', datafield: 'VF_Adresse1', minwidth: 110 }
    <div id="jqxgrid">
    Hope this helps you.
    Best Wishes,
    vudh
    Thanks for your support. It works great with your sample code above.
    However, when getting data directly from the service, the grid cannot bind successfully. Now I deployed a test service for debugging, and hereafter is my test page:
    jqxGrid Demo
    datatype: ‘jsonp’,
    datafields: [{ name: ‘Navn’ }, { name: ‘Nummer’ }, { name: ‘VF_Adresse1’ }
    url: ‘http://vaf.vegasmb.com:8101/ServiceDebug/Service.svc/GetWindowGridData?method=?’,
    data: {}
    , root: ‘GetWindowGridDataResult’
    downloadComplete: function (data, status, xhr) { alert(status); },
    loadComplete: function (data) { alert(data.GetWindowGridDataResult); },
    loadError: function (xhr, status, error) { alert(error); }
    width: 670,
    columns: [{ text: ‘Name’, dataField: ‘Navn’, minwidth: 100, classname: ‘header’, cellclassname: ‘textcell’ }
    , { text: ‘Number’, dataField: ‘Nummer’, minwidth: 100, classname: ‘header’, cellclassname: ‘textcell’ }
    , { text: ‘Postal address.Address’, dataField: ‘VF_Adresse1’, minwidth: 100, classname: ‘header’, cellclassname: ‘textcell’ }
    .header
    font-weight: bold;
    font-size: 14px; /*margin-top:5px;*/
    .textcell
    /*color:Black;*/
    .numbercell
    color: Red;
    Could you please help me debug that case?
    Thanks in advance,
    vudh.
    Hi vudh,
    There are additional ” in your code: {“GetWindowGridDataResult”:[{
    However, if you’d like to stay with that kind of result, the solution would be:
    datatype: "jsonp",
    { name: 'Navn' },
    { name: 'Nummer' },
    url: 'http://vaf.vegasmb.com:8101/ServiceDebug/Service.svc/GetWindowGridData?method=?'
    downloadComplete: function (data) {
    return $.parseJSON(data['GetWindowGridDataResult']);
    Best Wishes,
    vudh
    Thanks for your help ! It works great now.
    vudh
    tomrauch
    Hi, I am having the same problem (datagrid not loading data), but I am not generating any additional text (as in the case above). Here’s my code and what my output from the php file looks like. Any help greatly appreciated!
    <html lang=”en”>
    <title id=’Description’>In this example the Grid is bound to a Remote Data.</title>
    <link rel=”stylesheet” href=”js/widgets/jqwidgets/styles/jqx.base.css” type=”text/css” />
    <script type=”text/javascript” src=”js/widgets/scripts/jquery-1.11.1.min.js”></script>
    <script type=”text/javascript” src=”js/widgets/jqwidgets/jqxcore.js”></script>
    <script type=”text/javascript” src=”js/widgets/jqwidgets/jqxdata.js”></script>
    <script type=”text/javascript” src=”js/widgets/jqwidgets/jqxbuttons.js”></script>
    <script type=”text/javascript” src=”js/widgets/jqwidgets/jqxscrollbar.js”></script>
    <script type=”text/javascript” src=”js/widgets/jqwidgets/jqxmenu.js”></script>
    <script type=”text/javascript” src=”js/widgets/jqwidgets/jqxgrid.js”></script>
    <script type=”text/javascript” src=”js/widgets/jqwidgets/jqxgrid.selection.js”></script>
    <script type=”text/javascript” src=”js/widgets/jqwidgets/jqxgrid.columnsresize.js”></script>
    <script type=”text/javascript” src=”js/widgets/scripts/demos.js”></script>
    datatype: “jsonp”,
    { name: ‘first_name’, type: ‘string’ },
    { name: ‘last_name’, type: ‘string’ },
    { name: ‘job_title’, type: ‘string’ }
    url: “http://php/test3.php”
    width: 850,
    { text: ‘First Name’, datafield: ‘first_name’, width: 200 },
    { text: ‘Last Name’, datafield: ‘last_name’, width: 170 },
    { text: ‘Job’, datafield: ‘job_title’,width: 170 }
    <body class=’default’>
    <div id=’jqxWidget’ style=”font-size: 13px; font-family: Verdana; float: left;”>
    <div id=”jqxgrid”></div>
    [{“first_name”:”Bob”,”last_name”:”Davis”,”job_title”:”Supplemental Staffing”},{“first_name”:”Jane”,”last_name”:”Doe”,”job_title”:”PHYSICAL THERAPY”},{“first_name”:”Sam”,”last_name”:”Collins”,”job_title”:”DENTAL-REG”},{“first_name”:”Mary”,”last_name”:”Nice”,”job_title”:”MSW”}]
