jQuery UI Widgets › Forums › Navigation › Tabs › Problems aligning text in tab with splitter
This topic contains 1 reply, has 2 voices, and was last updated by Peter Stoev 8 years, 10 months ago.
I have a tab widget with 6 pages. I am dynamically adding text to the tab pages via “document.getElementById(“analysisTabViewpoint”).innerHTML” . This functionality is working fine. The text in the body of tab #1 (called OVERVIEW in my example) should be wrapped normally. The text in the body of tab #2 (Hierarchy) should be centered. If the tab widget is the ONLY thing on the page, the text displays properly on all pages. The problem is that this web page ALSO has a splitter. It appears that the text (specifically the DIV) on tab#1 and tab#2 is looking at the MAXIMUM size of the tab width, not the current size. As such, text on tab#1 is wrapping at 850 pixels instead of 300, and I don’t see all my text. Centering on tab#2 is centering at 850 pixels instead of 300 (as an example), and I don’t see any of my text. I have created a JSEDitor example. URL is
https://www.jseditor.io/?key=tabtest2Thanks
Hi George,
The problem is that the HTML Structure of your sample is incorrect. You missed 1 DIV tag for the Splitter’s Panel. It should be:
<!DOCTYPE html> <HTML> <HEAD> </HEAD> <body class='default'> <div id="splitContainer"> <div> Top Panel </div> <div> <div id="splitter"> <div id='AnalysisBodyLeft'></div> <div> <div id='AnalysisBodyRight'> <ul style='margin-left: 10px;'> <li>Overview</li> <li>Hierarchy</li> <li>Financials</li> <li>Industry</li> <li>3rd Party</li> <li>Additional Assets</li> </ul> <div id="analysisTabOver"> <div id="analysisTabOverLeft"></div> <div id="analysisTabOverRight"></div> <div id="analysisTabOverBottom"></div> </div> <div id="analysisTabViewpoint" style="text-align: center;"></div> <div id="analysisTabFin"> <div id="analysisTabFinLeft"></div> <div id="analysisTabFinRight"></div> </div> <div id="analysisTabInd"></div> <div id="analysisTabComp"> </div> <div id="analysisTabWeb" style="text-align: center;"> </div> </div> </div> </div> </div> </div> </body> </HTML>
Not:
<!DOCTYPE html> <HTML> <HEAD> </HEAD> <body class='default'> <div id="splitContainer"> <div> Top Panel </div> <div> <div id="splitter"> <div id='AnalysisBodyLeft'></div> <div id='AnalysisBodyRight'> <ul style='margin-left: 10px;'> <li>Overview</li> <li>Hierarchy</li> <li>Financials</li> <li>Industry</li> <li>3rd Party</li> <li>Additional Assets</li> </ul> <div id="analysisTabOver"> <div id="analysisTabOverLeft"></div> <div id="analysisTabOverRight"></div> <div id="analysisTabOverBottom"></div> </div> <div id="analysisTabViewpoint" style="text-align: center;"></div> <div id="analysisTabFin"> <div id="analysisTabFinLeft"></div> <div id="analysisTabFinRight"></div> </div> <div id="analysisTabInd"></div> <div id="analysisTabComp"> </div> <div id="analysisTabWeb" style="text-align: center;"> </div> </div> </div> </div> </div> </body> </HTML>
