jQuery UI Widgets › Forums › Grid › probleme with wrong getcellvalue if I click on another editing value.
Tagged: ajax, Cell, cellendedit, click, edit, editing, end, grid, jqxgrid, validation
This topic contains 2 replies, has 2 voices, and was last updated by nico86 10 years, 1 month ago.
March 5, 2015 at 4:09 pm probleme with wrong getcellvalue if I click on another editing value. #68090
I need help,
When i modified one cell of my grid I want to get value editing to sent it with a ajax request.firstly I change the value of my status field, then
if I click outside the grid or if I did [ENTER] then id which I need are ok because rowIndex is good.
But if I click on another editable cell (another line), rowIndex will not be good because it will take the number of the new clicked lineexample :
if I change the value of the status field on line 1 and then I click on [ENTER]or outside the grid then everything is ok .But if I change the value of the status field on line 1 and then I click the field status of the line 5 will then rowIndex 4 (instead of 0), and send my values to my request will be wrong.
how to recover the right value ? should start the getcellvalue when I click on the cell instead of placing it in the validation part ? or block the ability of clicks an editable fields as I didn ‘t enter or click outside the grid
Thanks for your help and sorry for my english.
here below my code
columns: [ { text: 'PATIDENT', datafield: 'PATIDENT', width: 100, editable: false }, { text: 'ADRNBA', datafield: 'ADRNBA', width: 60, editable: false }, { text: 'SPLIT', datafield: 'ROWSPLIT', width: 50, editable: false }, { text: 'DETECT_DATE', datafield: 'DETECT_DATETIMEC', width: 100, editable: false }, { text: 'DISCOM', datafield: 'DISCOM', width: 150, editable: false }, { text: 'DLLTCOD', datafield: 'DLLTCODC', width: 150, editable: false }, { text: 'DPTCOD', datafield: 'DPTCODC', width: 150, editable: false }, { text: 'STARTDAT', datafield: 'STARTDATC', width: 100, editable: false }, { text: 'ACTION', datafield: 'ACTIONC', width: 100, editable: false }, { text: 'ENTRY', datafield: 'ENTRYC', width: 80, editable: false }, { text: 'STATUS',columntype: 'dropdownlist',source:stat,datafield: 'STATUSC', width: 110, editable: true, createeditor: function (row, column, editor) { editor.jqxDropDownList({ autoDropDownHeight: true, source: stat });}, validation: function (cell, value) { if (value == "NO" || value == "YES" || value == "WAIT" || value == "TO BE DISCUSSED" || value == "NEW" || value == "") { pat= $("#jqxgrid").jqxGrid('getcellvalue', rowindex, 'PATIDENT'); /*VALUE OF THE FIELD NAME OF THE LINE MODIFIED */; adr= $("#jqxgrid").jqxGrid('getcellvalue', rowindex, 'ADRNBA'); /*VALUE OF THE FIELD NAME OF THE LINE MODIFIED */; split= $("#jqxgrid").jqxGrid('getcellvalue', rowindex, 'ROWSPLIT'); /*VALUE OF THE FIELD NAME OF THE LINE MODIFIED */; $("#jqxgrid").jqxGrid({ disabled: true}); $.ajax({ type : 'POST', // envoi des données en GET ou POST beforeSend : function() { // traitements JS à faire AVANT l'envoi $("#ariane").after('<span id="ajax-loader1"><img style="margin-top:11px;margin-left:265px;height:18px;position:absolute" src="'+web_path_p+car_b+'Librairies'+car_b+'Images'+car_b+'ajax-loader2.gif" alt="image du loader" /> </span'); }, url : 'http:'+server_sp+'/Coding/IMERIN/maj_status', // url du fichier de traitement /*async:false,*/ data : '&product='+product+'&study='+study+'&expltn='+expltn+'&STATUS='+value+'&PATIDENT='+pat+'&ADRNBA='+adr+'&ROWSPLIT='+split, dataType : 'json', success : function(data){}, complete :function(data){ $('#ajax-loader1').remove(); log("Log\\maj_status.log","Update status is ok : changed by "+value+" for "+pat+"/"+adr+split+""); } }); } return true; } },
March 6, 2015 at 7:22 am probleme with wrong getcellvalue if I click on another editing value. #68116Hi nico86,
I think it would be better if you make your Ajax call in another column callback function – cellendedit. Here is information about it from the jqxGrid API Documentation:
cellendedit – sets a custom function which is called when a cell leaves the edit mode. The Grid passes 5 parameters to it – row index, column data field, column type, old cell value, new cell value. The function can be used for canceling the changes of a specific Grid cell. To cancel the changes, the function should return false.
{ text: ‘Product’, datafield: ‘productname’,
cellendedit: function (row, datafield, columntype, oldvalue, newvalue) {
if (newvalue == “My Value”)
return false;
}Best Regards,
http://www.jqwidgets.com/March 6, 2015 at 9:30 am probleme with wrong getcellvalue if I click on another editing value. #68122it work fine with cellendedit
I had not thought to this function because with my old grid my ajax request was passed in validation and everything worked
Thanks a lot -
