jQuery UI Widgets › Forums › Grid › Problem with selection mode 'chekbox'
This topic contains 11 replies, has 2 voices, and was last updated by Dimitar 11 years, 6 months ago.
Hello! I have a jqxGrid with filter row in my MVC 4 application. I use selection mode ‘checkbox’. Filtering execute on server side and return data to view. Problem – i try to select row, but row not displaying as selected. Please help me.
Hello watchman,
Please provide us with your grid JavaScript code, which would help us determine the source of the issue.
http://www.jqwidgets.com/Oh! Yes of course!
This is my js file:
{ name: ‘FirstName’, type: ‘string’ },
{ name: ‘MiddleName’, type: ‘string’ },
{ name: ‘SurName’, type: ‘string’ },
{ name: ‘TabNomer’, type: ‘string’ },
{name:’Podrazdelenie’, type: ‘string’}
url: ‘OnePhoto/GetEmployees’,
filter: function () {
var dataAdapter = new $.jqx.dataAdapter(source);$(“#jqxdropdownbutton”).jqxDropDownButton({ width: 400, height: 25});
width: 768,
theme:’arctic’,
selectionmode: ‘checkbox’,
showfilterrow: true,
{ text: ‘Фамилия’, datafield: ‘SurName’, width: 200 },
{ text: ‘Имя’, datafield: ‘FirstName’, filterable : false, width: 100 },
{ text: ‘Отчество’, datafield: ‘MiddleName’, filterable: false, width: 180 },
{ text: ‘Таб.номер’, datafield: ‘TabNomer’, filterable: false, width: 75, cellsalign: ‘right’ },
{ text: ‘Подразделение’, datafield: ‘Podrazdelenie’, filterable: false, width: 150 }
});Server side code:
[Authorize]
public JsonResult GetEmployees()
var query = Request.QueryString;
var SurNameFilter = String.Empty;
if (filtersCount > 0)
var filterKey = query.GetKey(0);
if (filterKey == “SurNameoperator”)
SurNameFilter = query.GetValues(1)[i];
SurNameFilter = SurNameFilter.ToUpper();
var rezreq = model.tblEmployees.Where(w =>w.colSurname.StartsWith(SurNameFilter)).Select(s => new { FirstName = s.colName, MiddleName = s.colMiddlename, SurName = s.colSurname, TabNomer = s.colTabNumber, Podrazdelenie = s.tblEnterpriseTree.colName }).ToList();
return Json(rezreq, JsonRequestBehavior.AllowGet);
return Json(null, JsonRequestBehavior.AllowGet);
}And I can show screen with my problem.
I can selected custom rows, but this not displaing as selected.
Hi watchman,
Please make sure you are using the latest version of jQWidgets (3.0.3) in your solution.
http://www.jqwidgets.com/I am sure that i use the latest version of widjets. This is link http://www.jqwidgets.com/download/ for download. I choose the type of download as “personal, for non-comercial use”.
Guys! What about my problem?
Hi watchman,
We were not able to determine the source of the issue from the code snippet you provided. Please post a image that shows the issue and also the code with the CSS and JavaScript references in your page.
http://www.jqwidgets.com/when i load data into jqxGrid without filters values selection work fine. When i apply one of the filters and loading new data, checkboxes are displaing. Now i try to select row, i do mouse click in checkbox, but row not displaying as selected. Jqxgrid are understand what this row are selected, but not displaying as selected((
Hi watchman,
We were not able to reproduce the issue you are experiencing with version 3.0.3 of jQWidgets and the following example:
<!DOCTYPE html><html lang="en"><head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.10.2.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxexpander.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdragdrop.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.filter.js"></script> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript" src="generatedata.js"></script> <script type="text/javascript"> $(document).ready(function () { var theme = ""; var source = { localdata: generatedata(500), datafields: [ { name: 'firstname', type: 'string' }, { name: 'lastname', type: 'string' }, { name: 'productname', type: 'string' }, { name: 'quantity', type: 'number' }, { name: 'price', type: 'number' }, { name: 'total', type: 'number' } ], datatype: "array" }; var dataAdapter = new $.jqx.dataAdapter(source); var columns = [ { text: 'First Name', dataField: 'firstname', width: 100 }, { text: 'Last Name', dataField: 'lastname', width: 100 }, { text: 'Product', dataField: 'productname', width: 180 }, { text: 'Quantity', dataField: 'quantity', width: 80, cellsalign: 'right' }, { text: 'Unit Price', dataField: 'price', width: 90, cellsalign: 'right', cellsformat: 'c2' }, { text: 'Total', dataField: 'total', cellsalign: 'right', minwidth: 100, cellsformat: 'c2' } ]; // create data grid. $("#grid").jqxGrid( { width: 670, height: 300, source: dataAdapter, selectionmode: "checkbox", filterable: true, theme: theme, columns: columns }); // init buttons. $("#refresh").jqxButton({ theme: theme }); $("#clear").jqxButton({ theme: theme }); $("#refresh").click(function () { source.localdata = generatedata(500); // passing "cells" to the 'updatebounddata' method will refresh only the cells values when the new rows count is equal to the previous rows count. $("#grid").jqxGrid('updatebounddata', 'cells'); }); $("#clear").click(function () { $("#grid").jqxGrid('clear'); }); }); </script></head><body class='default'> <div id='jqxWidget'> <div id="grid"> </div> <div style="margin-top: 10px;"> <input id="refresh" type="button" value="Refresh Data" /> <input id="clear" type="button" value="Clear" /> </div> </div></body></html>
Does the erroneous behaviour occur at your side in this example?
http://www.jqwidgets.com/This is solution is worked but i use in my project layout view (MVC 4 C#) and jqxgrid location in partial view. Maybe problem is here? Can you show for me how i can use jqxwidgets with layout view and bundle config?
Hi watchman,
Please check the file references in your partial view.
