jQuery UI Widgets › Forums › Grid › Problem with localization
Tagged: grid globalization, javascript grid localization, jquery grid localization, jqwidgets grid localization
This topic contains 2 replies, has 2 voices, and was last updated by wfr 11 years, 1 month ago.
My localization code is not working. Everything else works fine.
Maybe I have placed something in the wrong place or missed something.<!DOCTYPE html> <html> <head> <title>Titel</title> <meta charset="utf-8"> <link rel="stylesheet" href="../../jqwidgets/jqwidgets/styles/jqx.base.css" type="text/css" /> <link rel="stylesheet" href="../../jqwidgets/jqwidgets/styles/jqx.darkblue.css" type="text/css" /> <script type="text/javascript" src="../../jqwidgets/scripts/jquery-1.10.2.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqwidgets/jqx-all.js"></script> <script> $(document).ready(function () { // prepare the data var source ={ datatype: "json", datafields: [ { name: 'datum', type: 'date' }, { name: 'bank', type: 'string' }, { name: 'bank_wert', type: 'number' }, { name: 'zu_an', type: 'string' }, { name: 'zu_wert', type: 'number' }, // { name: 'info_text', type: 'string' }, // { name: 'info_wert', type: 'number' }, // { name: 'bemerkungen', type: 'string' }, ], url: 'data.php' }; var dataAdapter = new $.jqx.dataAdapter(source); // define grid parameter $("#jqxgrid").jqxGrid({ source: dataAdapter , theme: 'classic' , width: 650 , sortable: true , filterable: true , //filtermode: 'excel' , //autoshowfiltericon: false , showfilterrow: true , autoheight: true , editable: true , selectionmode: 'singlecell' , // define column parameter columns: [ { text: 'Datum', datafield: 'datum', width: 112, cellsformat: 'dd.MM.yyyy', columntype: 'datetimeinput', filtertype: 'date' }, { text: 'Bank', datafield: 'bank', width: 150, columntype: 'combobox', filtertype: 'textbox', createeditor: function (row, column, editor) { // assign a new data source to the combobox. var list = ['SPK', 'STP', 'VB', 'RK', 'SH', 'EÖ', 'FC' ]; editor.jqxComboBox({ autoDropDownHeight: true, source: list, promptText: "Wähle:" }); }, // update the editor's value before saving it. cellvaluechanging: function (row, column, columntype, oldvalue, newvalue) { // return the old value, if the new value is empty. if (newvalue == "") return oldvalue; } }, { text: 'Bank-Wert', datafield: 'bank_wert', width: 100, cellsformat: 'F2', cellsalign: 'right', filtertype: 'textbox' }, { text: 'Zahlung unterwegs an', datafield: 'zu_an', width: 180, columntype: 'textbox', filtertype: 'textbox' }, { text: 'ZU-Wert', datafield: 'zu_wert', width: 100, cellsformat: 'F2', cellsalign: 'right', filtertype: 'textbox' } ] }); // Localization var localizationobj = {}; localizationobj.pagergotopagestring = "Gehe zu:"; localizationobj.pagershowrowsstring = "Zeige Zeile:"; localizationobj.pagerrangestring = " von "; localizationobj.pagernextbuttonstring = "voriger"; localizationobj.pagerpreviousbuttonstring = "nächster"; localizationobj.sortascendingstring = "Sortiere aufsteigend"; localizationobj.sortdescendingstring = "Sortiere absteigend"; localizationobj.sortremovestring = "Entferne Sortierung"; localizationobj.firstDay = 1; localizationobj.percentsymbol = "%"; localizationobj.currencysymbol = "€"; localizationobj.currencysymbolposition = "before"; localizationobj.decimalseparator = "."; localizationobj.thousandsseparator = ","; var days = { // full day names names: ["Sonntag", "Montag", "Dienstag", "Mittwoch", "Donnerstag", "Freitag", "Samstag"], // abbreviated day names namesAbbr: ["Sonn", "Mon", "Dien", "Mitt", "Donn", "Fre", "Sams"], // shortest day names namesShort: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"] }; localizationobj.days = days; var months = { // full month names (13 months for lunar calendards -- 13th month should be "" if not lunar) names: ["Januar", "Februar", "März", "April", "Mai", "Juni", "Juli", "August", "September", "Oktober", "November", "Dezember", ""], // abbreviated month names namesAbbr: ["Jan", "Feb", "Mär", "Apr", "Mai", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dez", ""] }; localizationobj.months = months; // apply localization. $("#jqxgrid").jqxGrid('localizestrings', localizationobj); }); </script> </head> <body> <div id="jqxgrid"></div> </body> </html>
Thank you
WalterHi Walter,
The problem is that at the point you localize the Grid, the Grid is still not rendered and is loading its data i.e your localization code should be either in “ready” or “bindingcomplete” functions or you should set the Grid’s localization property to point to your localization object during the Grid’s initialization.
Here’s how to apply localization:
` var data = generatedata(250);
localdata: data,
datafields:
{ name: ‘name’, type: ‘string’ },
{ name: ‘available’, type: ‘bool’ },
{ name: ‘date’, type: ‘date’ },
{ name: ‘price’, type: ‘number’ }
datatype: “array”
var getLocalization = function () {
localizationobj.pagergotopagestring = “Gehe zu:”;
localizationobj.pagershowrowsstring = “Zeige Zeile:”;
localizationobj.pagerrangestring = ” von “;
localizationobj.pagernextbuttonstring = “voriger”;
localizationobj.pagerpreviousbuttonstring = “nächster”;
localizationobj.sortascendingstring = “Sortiere aufsteigend”;
localizationobj.sortdescendingstring = “Sortiere absteigend”;
localizationobj.sortremovestring = “Entferne Sortierung”;
localizationobj.percentsymbol = “%”;
localizationobj.currencysymbol = “€”;
localizationobj.currencysymbolposition = “after”;
localizationobj.decimalseparator = “.”;
localizationobj.thousandsseparator = “,”;
localizationobj.emptydatastring = “keine Daten angezeigt”;
var days = {
// full day names
names: [“Sonntag”, “Montag”, “Dienstag”, “Mittwoch”, “Donnerstag”, “Freitag”, “Samstag”],
namesAbbr: [“Sonn”, “Mon”, “Dien”, “Mitt”, “Donn”, “Fre”, “Sams”],
namesShort: [“So”, “Mo”, “Di”, “Mi”, “Do”, “Fr”, “Sa”]
var months = {
// full month names (13 months for lunar calendards — 13th month should be “” if not lunar)
names: [“Januar”, “Februar”, “März”, “April”, “Mai”, “Juni”, “Juli”, “August”, “September”, “Oktober”, “November”, “Dezember”, “”],
namesAbbr: [“Jan”, “Feb”, “Mär”, “Apr”, “Mai”, “Jun”, “Jul”, “Aug”, “Sep”, “Oct”, “Nov”, “Dez”, “”]
var patterns = {
d: “dd.MM.yyyy”,
D: “dddd, d. MMMM yyyy”,
t: “HH:mm”,
T: “HH:mm:ss”,
f: “dddd, d. MMMM yyyy HH:mm”,
F: “dddd, d. MMMM yyyy HH:mm:ss”,
M: “dd MMMM”,
Y: “MMMM yyyy”
localizationobj.patterns = patterns;
localizationobj.todaystring = “Heute”;
localizationobj.clearstring = “Löschen”;
return localizationobj;
$(“#jqxgrid”).jqxGrid(
width: 685,
showfilterrow: true,
selectionmode: ‘singlecell’,
{ text: ‘Name’, columntype: ‘textbox’, filtertype: ‘textbox’, datafield: ‘name’, width: 115 },
{ text: ‘Produkt’, filtertype: ‘textbox’, datafield: ‘productname’, width: 220 },
{ text: ‘Datum’, datafield: ‘date’, columntype: ‘datetimeinput’, filtertype: ‘date’, width: 210, cellsalign: ‘right’, cellsformat: ‘d’ },
{ text: ‘Qt.’, datafield: ‘quantity’, columntype: ‘numberinput’, filtertype: ‘textbox’, cellsalign: ‘right’, width: 60 },
{ text: ‘Preis’, datafield: ‘price’, columntype: ‘numberinput’, filtertype: ‘textbox’, cellsformat: “c2”, cellsalign: ‘right’ }
});`Best Regards,
http://www.jqwidgets.com/Thanks a lot, Peter!
Walter
