jQuery UI Widgets Forums Grid Problem with loader
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 12 years, 9 months ago.
  • Problem with loader #6292
    Neelam
    I want to show loading image on change event while completing the ajax request but it shows loader image continuously and don’t replace div with data in jqgrid.
    Neelam
    Problem with loader #6293
    Hi Neelam,
    The provided details are not sufficient for reproducing the reported behavior. Please, provide additional details and a small sample which demonstrates the issue that you experience.
    Problem with loader #6295
    Neelam
    This function is called when I change value of combo box.
    when change event is called, I have replace jqgrid with loader image. later on it should replace with data. which is not happening.
    function accountSummary()
    var theme = ‘energyblue’;
    $(‘#jqxgrid’).html(‘‘);
    var url = SITEDOMAIN+”/accounts/accountsummary”;
    { name: ‘numeroCompte’ },
    { name: ‘variation’, type: ‘float’ },
    { name: ‘variation_perc’ }
    url: url,
    root: ‘data’
    $(“#jqxgrid”).jqxGrid(
    width: 930,
    { text: ‘NumeroCompte’, dataField: ‘numeroCompte’, width: 150},
    { text: ‘Variation’, dataField: ‘variation’, width: 120, cellsformat: ‘c2’ },
    { text: ‘Variation %’, dataField: ‘variation_perc’, width: 120, cellsformat: ‘c2’ }
    Neelam
    Problem with loader #6296
    Hi Neelam,
    The problem is that you replace the Grid’s content with some HTML, but you don’t destroy the Grid’s instance. If you want to put loader element, do not change the Grid’s HTML and use absolute positioned DIV tag.
    Another solution is to manually remove the Grid element and add it again :
          var parentElement = $("#jqxgrid").parent();
    $("#jqxgrid").remove();
    parentElement.append("<div id='jqxgrid'></div>");
