jQuery UI Widgets Forums Editors NumberInput problem with IE 8
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 9 years, 2 months ago.
  • problem with IE 8 #81129
    nico86
    I invite you to test this widget with IE8, for me there is a problem with the up and down arrows that does not work unless you click before the text fields on the right number. Unfortunately I have to use IE8 in my company
    Thanks.
    Nicolas.
    problem with IE 8 #81145
    Hello Nicolas,
    Please try setting the spinMode property to ‘simple’. This way, you will not need to position the cursor in the input and you can start incrementing/decrementing directly.
