jQuery UI Widgets › Forums › Grid › Problem with grid and remote async databinds
Tagged: angular grid, bootstrap grid, combobox, foreigkey, grid, javascript grid, jquery grid, jqwidgets grid, jqxgrid, json, remotedata
This topic contains 1 reply, has 2 voices, and was last updated by Hristo 9 years, 1 month ago.
Hello everyone.
I’m trying to edit the custom combobox example (http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/customcomboboxcolumn.htm) to work with json remote data.
This is my problem: if I use the async: false option it works fine. If I don’t then the value on the column is blank until I edit it. The combobox itself once I’m editing works well. I would like to use an asynchronous request for this as what I’m building will have large amounts of data and a synchronous request might affect user experience.Can anyone help me out? I’ll leave the code below.
Thanks in advance!<script type="text/javascript"> $(document).ready(function () { var countriesSource = { datatype: "json", cache: false, datafields: [ { name: 'label', type: 'string' }, { name: 'value', type: 'int' } ], //localdata: teste, url: 'getcountries.php', async : false, }; var countriesAdapter = new $.jqx.dataAdapter(countriesSource, { autoBind: true, beforeLoadComplete: function (records) { var data = new Array(); // update the loaded records. Dynamically add EmployeeName and EmployeeID fields. for (var i = 0; i < records.length; i++) { var employee = records[i]; employee.EmployeeName = employee.FirstName + " " + employee.LastName; employee.EmployeeID = employee.uid; data.push(employee); } return data; } }); // prepare the data var gridSource = { datatype: "json", datafields: [ // name - determines the field's name. // value - the field's value in the data source. // values - specifies the field's values. // values.source - specifies the foreign source. The expected value is an array. // values.value - specifies the field's value in the foreign source. // values.name - specifies the field's name in the foreign source. // When the adapter is loaded, each record will have a field called "Country". The "Country" for each record comes from the countriesAdapter where the record's "countryCode" from gridAdapter matches to the "value" from countriesAdapter. { name: 'Country', value: 'countryCode', values: { source: countriesAdapter.records, value: 'value', name: 'label' } }, { name: 'countryCode', type: 'int'} ], url: 'infoacustica.php?acustica=1', }; var gridAdapter = new $.jqx.dataAdapter(gridSource); $("#jqxgrid").jqxGrid( { width: 600, source: gridAdapter, selectionmode: 'singlecell', autoheight: true, editable: true, columns: [ { text: 'Country', datafield: 'countryCode', displayfield: 'Country', columntype: 'combobox', createeditor: function (row, value, editor) { editor.jqxComboBox({ source: countriesAdapter, displayMember: 'label', valueMember: 'value' }); } } ] }); $("#jqxgrid").on('cellselect', function (event) { var column = $("#jqxgrid").jqxGrid('getcolumn', event.args.datafield); var value = $("#jqxgrid").jqxGrid('getcellvalue', event.args.rowindex, column.datafield); var displayValue = $("#jqxgrid").jqxGrid('getcellvalue', event.args.rowindex, column.displayfield); $("#eventLog").html("<div>Selected Cell<br/>Row: " + event.args.rowindex + ", Column: " + column.text + ", Value: " + value + ", Label: " + displayValue + "</div>"); }); $("#jqxgrid").on('cellendedit', function (event) { var column = $("#jqxgrid").jqxGrid('getcolumn', event.args.datafield); console.log(column.displayfield + " - " + column.datafield); if (column.displayfield != column.datafield) { $("#eventLog").html("<div>Cell Edited:<br/>Index: " + event.args.rowindex + ", Column: " + column.text + "<br/>Value: " + event.args.value.value + ", Label: " + event.args.value.label + "<br/>Old Value: " + event.args.oldvalue.value + ", Old Label: " + event.args.oldvalue.label + "</div>" ); } else { $("#eventLog").html("<div>Cell Edited:<br/>Row: " + event.args.rowindex + ", Column: " + column.text + "<br/>Value: " + event.args.value + "<br/>Old Value: " + event.args.oldvalue + "</div>" ); } }); }); </script>
Hello rpcosta,
If you would like load bigger data you could use
virtualmode: true
property of the Grid.
There you could load huge amount of data (1000k records).
Please take a look those demos:
http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/virtualdata.htm?arctic
http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/virtualscrolling.htm?arcticBest Regards,
Hristo HristovjQWidgets team
