jQuery UI Widgets Forums Scheduler Problem with editdialog
This topic contains 3 replies, has 2 voices, and was last updated by  Hristo 6 years, 3 months ago.
  • Problem with editdialog #103337
    ghis
    When I edit an appointment in the jqxScheduler dialog edit, when I put the cursor in the location and desciption fields, the cursor immediately returns to the subject field. There is also the time button that does not work against the calender button works well.
    I can not understand this information.
    I use 6.2.0 jwidgets in a desktop application do with ELECTRON 4.0.0 under windows 10.
    P.S. Excuse my English, it’s a GOOGLE translation.
    Thank you very much for your help.
    Ghislain Plante
    Problem with editdialog #103353
    Hello Ghislain Plante,
    I tested this demo and it seems to work fine:
    https://www.jqwidgets.com/jquery-widgets-demo/demos/jqxscheduler/defaultfunctionality.htm?light
    Could you clarify it?
    On which browser do you try it? Is there any error message?
    Unfortunately, I am not familiar with this “ELECTRON 4.0.0”.
    We support these browsers:
    Edge, Internet Explorer 7.0+, Firefox 2.0+, Safari 3.0+, Opera 9.0+, Google Chrome, IE Mobile, Android, Opera Mini, Mobile Safari (IPhone, IPad)
    Problem with editdialog #103493
    ghis
    Hi Hristo,
    Electron 4.0.0 use Chromium 69.0.3497.106 and Node 10.11.0.
    Most jqwidgets components works very well with Electron 4.0.0.
    Ghislain
    Problem with editdialog #103513
    Hello Ghislain,
    The full list of supported frameworks & libraries can be found on: http://www.jqwidgets.com/jquery-widgets-documentation/
    As an alternative I would like to suggest you try to override the dialog with custom one – you could try with jqxWindow.
