jQuery UI Widgets Forums Lists ComboBox Problem with Combobox autocomplete and searchMode
This topic contains 8 replies, has 3 voices, and was last updated by  Peter Stoev 12 years, 7 months ago.
  • gokul
    Hai There,
    Currently I got some different output with/without using autocomplete:true and searchMode: ‘containsignorecase’. please see the�
    below code.
    var localdata = [
    "bank_code": "UOB-SGD", "bank_desc": "United Overseas Bank-SGD" },
    "bank_code": "UOB-USD", "bank_desc": "United Overseas Bank-USD" },
    "bank_code": "MBB-SGD", "bank_desc": "Maybank-SGD" },
    "bank_code": "DBS-SGD", "bank_desc": "DBS Bank Ltd-SGD" }
    var source =
    datatype: "json",
    datafields: [
    { name: 'bank_code' },
    { name: 'bank_desc' }
    localdata: localdata,
    var dataAdapter = new $.jqx.dataAdapter(source);
    $("#ddlBankName").jqxComboBox({
        width: 300,
        height: 25,
        theme: theme,
        source: dataAdapter,
        displayMember: "bank_desc"
        valueMember: "bank_code",
        autocomplete: true,
        searchMode: 'containsignorecase'
    $("#ddlBankName").bind('select', function (event) {
        $("#selectionlog").children().remove();
    if (event.args) {
    var item = event.args.item;
    if (item) {
    var valueelement = $("<div></div>");
    valueelement.html("Value: " + item.value);
    var labelelement = $("<div></div>");
    labelelement.html(item.label);
    $("#selectionlog").append(labelelement);
    Now come to my scenario,
    1. Combobox with autocomplete = ture and searchMode = ‘containsignorecase’.
    Once I start typing the word May ( bank_desc for Maybank) in the combobox list display only the ‘Maybank-SGD’ and selectionlog div shows as ‘United Overseas Bank-SGD’.�
    The main confusiton is after I selected the ‘Maybank-SGD’ from the combobox list then also the selectionlog div shows as ‘United Overseas Bank-SGD’.
    2. I tried combobox without autocomplete = ture and searchMode = ‘containsignorecase’.�
    Now I start typeing the word May the selectionlog div shows as ‘Maybank-SGD’
    Please help me out.
    Thanks – Gokul
    gokul
    Hai There,
    I have have one small update for the above issue.
    Just now I tried with autocomplete: false its working as expected.
    But whenever I used autocomplete: true I got the same issue.
    Please help me out.
    – Gokul
    Hi Gokul,
    How do you select the item in autoComplete mode? – with mouse click, pressing up/down arrow or by pressing the “Enter” key.
    Looking forward to your reply.
    gokul
    Hai Peter,
    I tried mouse click and ‘Enter’ key. But I am facing the same issue.
    Gokul
    I’ve tested your scenario and confirm that there’s an issue when auto-complete is true. I’ll create a new work item about it and we’ll resolve it in a future version of jQWidgets. Thank you for the provided feedback!
    shimmoril
    Has this bug been fixed? We’d like to use the combo box, but we require the auto-complete functionality.
    Hi shimmoril,
    There’s online demo which demonstrates the auto-complete functionality of jqxComboBox: remotesearch.htm.
    With local source is: settings.htm.
    If you want to keep track what is fixed and what is not, visit: releasehistory.htm.
    shimmoril
    Yes, I’ve viewed the demo, but if the bug is still present, it will not work for our situation.
    I’ve checked the release history, and I can’t see any items regarding the combo box and auto-complete for releases after Aug 6 (ie. when you last posted in this thread). Please state whether the bug is fixed or not as of the latest release.
    Hi shimmoril,
    As far as I know, the reported issue in this topic is resolved. At least I can’t reproduce it. That’s why I pointed you to our online samples.
