jQuery UI Widgets › Forums › Grid › Problem with cellsrenderer and renderer
This topic contains 3 replies, has 2 voices, and was last updated by sved 12 years, 5 months ago.
Hello, I’m trying to set cellsrenderer and renderer on one column in my grid, but whitout success. I’m using php code to generate dynamic data for the columns.
Here is simple example of the code:
php page $(document).ready(function () { loadGrid({"url": "'.$url.'", "colNames": '.json_encode($colNames).', "rowData": '.json_encode($rowData).'}) }); where $rowData is: [{ "text": "id" , "datafield": "id", "width": "140" ,"cellsrenderer": "imagerenderer", "pinned": "1" },{ "text": "product_name" , "datafield": "product_name", "width": "140" , "pinned": "1" },{ "text": "category_1" , "datafield": "category_1", "width": "140" , "pinned": "1" },{ "text": "returns_rate" , "datafield": "returns_rate", "width": "140" , "pinned": "0" },{ "text": "returned_order_value" , "datafield": "returned_order_value", "width": "140" , "pinned": "0" }]
the grid.js code include var loadGrid = function ( o) { var cellsrenderer = function (row, column, value) { return value; } var imagerenderer = function (row, datafield, value) { return value; } var url = o.url.replace(/&/g, '&'); var colNames = jQuery.parseJSON(o.colNames); var rowData = jQuery.parseJSON(o.rowData); var theme = 'darkness'; var source = { datatype: "json", datafields: colNames, url: url, filter: function() { $("#jqxgrid").jqxGrid('updatebounddata'); }, sort: function() { $("#jqxgrid").jqxGrid('updatebounddata'); }, root: 'Rows', beforeprocessing: function(data) { if (data != null) { source.totalrecords = data[0].TotalRows; } } }; var dataadapter = new $.jqx.dataAdapter(source, { loadError: function(xhr, status, error) { alert(error); } }); $("#jqxgrid").jqxGrid({ source: dataadapter, theme: theme, filterable: true, sortable: true, autoheight: true, pageable: true, width: 955 columnsresize: true, columnsreorder: true, columns: rowData, pagenum: 0, pagesize: 20, virtualmode: true }); }
I tried couple of ways to set cellsrenderer, but everything ends with error in JS:
TypeError: f.cellsrenderer is not a function
or
TypeError: this.renderer is not a functionHi Sved,
In the provided code, you set the cellsrenderer and renderer functions as strings, Example: “imagerenderer”. This will not work because the expected value is a function, not the function’s name.
Peter StoevjQwidgets Team
http://www.jqwidgets.comThanks, I’ll post working solution later
okay, the following line:
should be replaced by:
var rowData = JSON.parse(o.rowData, function(key, value){ if (key=="cellsrenderer") //if "thedate" property return imagerenderer else return value });
Now I can call function imagerender
