This topic contains 1 reply, has 2 voices, and was last updated by  Nadezhda 10 years, 1 month ago.
  • problem recreating color picker #68044
    rtessler
    create the color picker, then create it again, clicking on the color picker produces and error in jqxcolorpicker.js
    see code below
    <!doctype html>
    <html>
    <body>
    <style>
    .color-selector {
    width: 50px;
    .color-selector .jqx-icon-arrow-down {
    background-image: none;
    .field {
    margin-top: 0px;
    margin-bottom: 10px;
    overflow: hidden;
    </style>
    <link rel=”stylesheet” type=”text/css” href=”js/libs/jqwidgets-ver3.6.0/jqwidgets/styles/jqx.base.css” >
    <script src=”js/libs/jquery-1.11.1.min.js” ></script>
    <script src=”js/libs/jqwidgets-ver3.6.0/jqwidgets/jqxcore.js”></script>
    <script src=”js/libs/jqwidgets-ver3.6.0/jqwidgets/jqxnavigationbar.js”></script>
    <script src=”js/libs/jqwidgets-ver3.6.0/jqwidgets/jqxdropdownbutton.js”></script>
    <script src=”js/libs/jqwidgets-ver3.6.0/jqwidgets/jqxbuttons.js”></script>
    <script src=”js/libs/jqwidgets-ver3.6.0/jqwidgets/jqxcolorpicker.js”></script>
    <script src=”js/libs/jqwidgets-ver3.6.0/jqwidgets/jqxscrollview.js”></script>
    <body>
    <div class=”field color-selector”>
    <div id=”fontColorDropDownButton” >
    <div style=”padding: 3px;”>
    <div id=”fontColorPicker”></div>
    create color picker
    <script>
    function getTextElementByColor(color) {
    if (color == ‘transparent’ || color.hex == “”) {
    return $(“<div style=’text-shadow: none; position: relative; padding-bottom: 2px; margin-top: 2px;’>transparent</div>”);
    var element = $(“<div style=’text-shadow: none; position: relative; padding-bottom: 2px; margin-top: 2px; height: 18px; border: 1px solid #fff;’> </div>”);
    //var element = $(“<div style=’text-shadow: none; position: relative; padding-bottom: 2px; margin-top: 2px;’>#” + color.hex + “</div>”);
    var nThreshold = 105;
    var bgDelta = (color.r * 0.299) + (color.g * 0.587) + (color.b * 0.114);
    var foreColor = (255 – bgDelta < nThreshold) ? ‘Black’ : ‘White’;
    element.css({ color: foreColor, background: “#” + color.hex }).addClass(‘jqx-rc-all’);
    return element;
    function createColorPicker(color_picker, dropdown, background_color)
    if (!color_picker || !dropdown)
    return;
    dropdown.jqxDropDownButton({ width: 60, height: 25 });
    dropdown.jqxDropDownButton(‘setContent’, getTextElementByColor(new $.jqx.color({ hex: background_color })));
    color_picker.jqxColorPicker({ color: background_color, colorMode: ‘hue’, width: 220, height: 220, showTransparent: false });
    color_picker.on(‘colorchange’, function (event) {
    dropdown.jqxDropDownButton(‘setContent’, getTextElementByColor(event.args.color));
    var color = event.args.color.hex;
    console.log(“color = ” + color);
    $(“.create-color-picker”).click(function(e) {
    var color_picker = $(“#fontColorPicker”);
    var dropdown = $(“#fontColorDropDownButton”);
    createColorPicker(color_picker, dropdown, “000”);
    problem recreating color picker #68063
    Nadezhda
    Hello rtessler,
    In the above code you are using class selector create-color-picker which is not created in your html. You are also using invalid html structure.
    Please, follow the HTML structure from jqxColorPicker demos (Default Functionality and Settings) and take out the double body tag from your code.
    Nadezhda
