jQuery UI Widgets Forums General Discussions Problem in jqsPivotGrid
This topic contains 7 replies, has 4 voices, and was last updated by  axe020 7 years, 6 months ago.
  • Problem in jqsPivotGrid #95769
    Manu Vashishtha
    Hello Sir
    I am using Pivot Grid in my project. I have data in which ‘name’ and text property in datafields are different.
    but in Pivot Table Designer when I drag field to Values Section then text of the field is showing the value of name property instead of text property.
    For example it is showing:– “Count of firstname” instead of “Count of First Name”
    var datafields= [
    { name: ‘price’, type: ‘number’ },
    { name: ‘total’, type: ‘number’ }
    var fields= [ { dataField: ‘firstname’, text: ‘First Name’ },
    { dataField: ‘lastname’, text: ‘Last Name’ },
    { dataField: ‘productname’, text: ‘Product Name’ },
    { dataField: ‘quantity’, text: ‘Quantity’ },
    { dataField: ‘price’, text: ‘Price’ },
    { dataField: ‘total’, text: ‘Total’ }
    Kindly provide the solution to me.This is urgent.
    Regards
    Manu Vashishtha
    Problem in jqsPivotGrid #95787
    Hello Manu Vashishtha,
    Let me know if you need anything else.
    Problem in jqsPivotGrid #95798
    Manu Vashishtha
    Hello Sir
    Thank you for your response.
    I have checked the example given by you. This is working fine for grid. But I also need this functionality for pivot designer value area.
    And also it is not possible for me to change the text on button click. I need any event like dragcomplete (lets assume when draging of a field is complete). So that I can change the text of particular field for pivot grid and designer both.
    Regards
    Manu Vashishtha
    Problem in jqsPivotGrid #95799
    Manu Vashishtha
    Hello Sir
    I also have one another requirement. I need data export functionality for pivot grid like jqxgrid.
    Currently I am in need of ‘Export To Excel’ only.
    Regards
    Manu Vashishtha
    Problem in jqsPivotGrid #95939
    There is no such functionality. Please, take a look at this section there are described possible features.
    Also, I would like to suggest you look at this tutorial:
    https://www.jqwidgets.com/jquery-widgets-documentation/documentation/jqxpivotgrid/jquery-pivotgrid-introduction.htm?search=pivot
    Problem in jqsPivotGrid #96476
    axe020
    Hello Sir,
    I am Using Pivot grid designer example and want to reinitialise the plugin once again on button how can i do it.
    I tried using refresh method but its not working for me.
    Problem in jqsPivotGrid #96478
    Hi axe020,
    If you mean to create again the Pivot Grid, then you should do the following:
    1. Remove the Pivot Grid’s DIV tag.
    2. Append a new DIV tag.
    3. Select the DIV tag and Run the initialization code.
    Problem in jqsPivotGrid #96479
    axe020
    It worked for me.
