jQuery UI Widgets Forums General Discussions Problem in 5.5.0
This topic contains 6 replies, has 2 voices, and was last updated by  Stanislav 7 years, 2 months ago.
  • Problem in 5.5.0 #98138
    emberq
    I just upgraded from 5.4.0 to 5.5.0. On all my jqxWindow-based dialogs, as soon I put cursor into a dropdownlist and try to make a selection, the window is destroyed. Same for combo and datetime control and input with auto select. AS soon s I start entering data or make a selection, window quits.
    This problem has never occurred prior and was not in 5.4.0.
    Problem in 5.5.0 #98141
    Stanislav
    Hello emberq,
    I did some testing but I didn’t find anything.
    Can you please send us an example so we can have a better look at your situation and help you?
    Stanislav
    Problem in 5.5.0 #98149
    emberq
    This should be easy to reproduce but I’m going to create a fiddle to show it. But where can I point to a public version of 5.5.0? The version at http://jqwidgets.com/public/jqwidgets/jqx-all.js is still on 5.4.0.
    Has 5.5.0 actually been released to the public? If so why isn’t that public link updated?
    Problem in 5.5.0 #98150
    Stanislav
    Hello emberq,
    You can go to our git hub and download the latest version of jqx-all there. Link
    You can send us s snippet as well if you aren’t able to get the jqx-all.
    The fiddle will be updated to the latest version in the near future, sorry for the inconvenience.
    Stanislav
    Problem in 5.5.0 #98151
    emberq
    It’s not any fiddle that needs to be updated, or maybe it does. I was pointing out that this public URL: http://jqwidgets.com/public/jqwidgets/jqx-all.js is not on the latest version.
    So I”m just asking for help in how to set up my new fiddle properly by pointing it to a public URL that contains 5.5.0? Not a download.
    Problem in 5.5.0 #98152
    emberq
    I created this Fiddle: https://jsfiddle.net/emberq/p9bezk85/
    I eliminated virtually all of my window properties but let’s see if you can run this using 5.5.0 and just click the dropdown. See if the window closes. If the window doesn’t close then there is some option I’m using on the window or the drop down that is causing this behavior. Again, this worked fine for all version of JQWidgets prior to 5.5.0. I really could use a public URL pointing to 5.5.0 so I can reproduce this myself using this widget rather than getting you involved because this is really a shot in the dark.
    Thank you.
    Problem in 5.5.0 #98158
    Stanislav
    Hello emberq,
    I took your example from the fiddle and placed it in a custom test(with the 5.5.0v) and nothing occurred. The window did not close, I added some properties but still, it worked fine. Maybe the properties you have are creating are breaking the window, and that is the reason it closes.
    If you want, send me the properties your using and I will make the same test with them, or test them yourself.
    jqx-all should be updated soon, sorry again!
    Stanislav
