jQuery UI Widgets Forums Grid Problem getting dynamic datafields to work
This topic contains 1 reply, has 2 voices, and was last updated by  Stanislav 7 years, 9 months ago.
  • tomintex
    Here is test#1. It loads the grid data just fine.
    datafields = new Array();
    columns = new Array();
    urlhdr = “JQWidgets.aspx/GetMonthlyGridHeaders”;
    urldata = “JQWidgets.aspx/GetMonthlyGridData”;
    datafields = [{name: ‘Category’, type: ‘string’},
    {name: ‘PracticeName’, type: ‘string’},
    {name: ‘M20160501’, type: ‘number’},
    {name: ‘M20160601’, type: ‘number’},
    {name: ‘M20160701’, type: ‘number’},
    {name: ‘M20160801’, type: ‘number’},
    {name: ‘M20160901’, type: ‘number’},
    {name: ‘M20161001’, type: ‘number’},
    {name: ‘M20161101’, type: ‘number’},
    {name: ‘M20161201’, type: ‘number’},
    {name: ‘M20170101’, type: ‘number’},
    {name: ‘M20170201’, type: ‘number’},
    {name: ‘M20170301’, type: ‘number’},
    {name: ‘M20170401’, type: ‘number’},
    {name: ‘M20170501’, type: ‘number’}];
    var source = {
    datatype: ‘xml’,
    datafields: datafields,
    async: false,
    root: ‘Table’,
    url: urldata
    { contentType: ‘application/json; charset=utf-8’,
    autoBind: true,
    Here is test #2 – It uses a datafield array constructed by a function and returns from the jqx.dataAdapter with the following exception:
    Unable to get property ‘nodeType’ of undefined or null reference\n
    at attr (http://localhost:65048/vendor/jquery/jquery.min.js:3:31424)\n
    at S (http://localhost:65048/vendor/jquery/jquery.min.js:3:155)\n
    at attr (http://localhost:65048/vendor/jquery/jquery.min.js:3:31262)\n
    at a.jqx.dataAdapter.prototype.loadxml (http://localhost:65048/jqwidgets/jqxdata.js:7:7510)\n
    at success (http://localhost:65048/jqwidgets/jqxdata.js:6:21618)\n
    at i (http://localhost:65048/vendor/jquery/jquery.min.js:2:27598)\n
    at j.fireWith (http://localhost:65048/vendor/jquery/jquery.min.js:2:28311)\n
    at g (http://localhost:65048/jqwidgets/jqxdata.js:7:27274)\n
    at c (http://localhost:65048/jqwidgets/jqxdata.js:8:1026)\n
    at send (http://localhost:65048/jqwidgets/jqxdata.js:8:1152)”
    type: “GET”,
    url: urlhdr,
    dataType: “json”,
    async: false,
    success: function (response, txtstatus, XMLHttpRequest) {
    //console.log(response.d);
    SetupGridHeaders(response);
    failure: function (XMLHttpRequest, textStatus, errorThrown) {
    alert(‘An ajax error occurred – check console for more information’);
    console.log(textStatus);
    console.log(errorThrown);
    alert(datafields);
    var source = {
    datatype: ‘xml’,
    async: false,
    root: ‘Table’,
    url: urldata
    autoBind: true,
    function SetupGridHeaders(response) {
    var str = response.d;
    var colList = new Array();
    var colList = str.split(“,”);
    var i;
    //datafields = [];
    datafields.push(“{ name: ‘Category’, type: ‘string’ }”);
    datafields.push(“{ name: ‘PracticeName’, type: ‘string’ }”);
    //columns = [];
    columns.push(“{ text: ‘Category’, datafield: ‘Category’, width: ‘14%’ }”);
    columns.push(“{ text: ‘Practice’, datafield: ‘PracticeName’, cellsalign: ‘left’, width: ‘8%’ }”);
    for (i = 0; i < colList.length; ++i) {
    str = colList[i]; //str holds the datafield name
    if ((str.substring(0, 2) == ‘”M’) || (str.substring(0, 2) == ‘”W’) || (str.substring(0, 2) == ‘”Q’)) {
    str = str.substring(1, 10);
    datafields.push(“{ name: ‘” + str + “‘, type: ‘number’ }”);
    // { text: ’05/31/2016′, datafield: ‘M20160501’, cellsalign: ‘right’, cellsformat: ‘d2’, width: ‘6%’ , cellsrenderer: cellsrenderer },
    var str2 = str.substring(1, 9); //str2 holds the grid column display text
    var m = str2.substring(4, 6);
    var d = str2.substring(6, 8);
    var y = str2.substring(0, 4);
    str2 = m + “/” + d + “/” + y;
    //columns = columns + “, { text: ‘” + str2 + “‘, datafield: ‘” + str + “‘, cellsalign: ‘right’, cellsformat: ‘d2’, width: ‘6%’ , cellsrenderer: cellsrenderer }”
    columns.push(“{ text: ‘” + str2 + “‘, datafield: ‘” + str + “‘, cellsalign: ‘right’, cellsformat: ‘d2’, width: ‘6%’ }”);
    continue;
    When I use alert to display the constructed array – it looks identical to the hard-coded array example in test #1 Does anyone have an idea what I am missing???
    Stanislav
    Hi tomintex,
    I would suggest you to first take a look at our Dynamic columns. It should be a similar case to what you are trying to achieve here.
