jQuery UI Widgets Forums Chart problem chart
This topic contains 8 replies, has 2 voices, and was last updated by  wanfr13 12 years, 7 months ago.
  • problem chart #7371
    wanfr13
    Hallo,
    I’m French, sorry for my english…
    When loading the page the number of elements can change
    I read the values ​​in the page then I format the values ​​like this
    [{pays:USA, nb:1},{pays:France, nb:25},{pays:belgique, nb:2}]
    here is my code :
    var data = ‘[‘;
    $(‘.pays’).each(function() {
    data = data + ‘{“Pays”:’ + $(this).text() + ‘,”Nb”:’ + $(this).next().text() + ‘},’;
    data = data.substr(0, data.length-1);
    data = data + ‘]’;
    $(‘#sp7’).jqxChart({
    title: “Répartitions des inscrits par pays”,
    enableAnimations: true,
    padding: { left: 20, top: 5, right: 20, bottom: 5 },
    legendLayout: { left: 20, top: 220, width: 200, height: 200, flow: ‘vertical’ },
    titlePadding: { left: 90, top: 0, right: 90, bottom: 10 },
    source: data,
    colorScheme: ‘scheme03’,
    seriesGroups: [{
    type: ‘pie’,
    showLabels: true,
    series: [{
    dataField: ‘nb’,
    displayText: ‘pays’,
    labelRadius: 120,
    initialAngle: 15,
    radius: 95,
    centerOffset: 0
    but no pie will be drawn, only 127 legends !
    Where is the problem?
    thank’s
    problem chart #7373
    Hello wanfr13,
    It is not possible to create a pie without any numeric values and your construction of the data variable has only text values for both “Pays” – $(this).text() and “Nb” – $(this).next().text(). However, here is an example with the values you gave:
    <title id='Description'>jqxChart Pie Series Example</title>
    <link rel="stylesheet" href="../../jqwidgets2.4/styles/jqx.base.css" type="text/css" />
    <script type="text/javascript" src="../scripts/jquery-1.7.2.min.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4/jqxcore.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4/jqxchart.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4/jqxdata.js"></script>
    var data1 = [{ pays: "USA", nb: 1 }, { pays: "France", nb: 25 }, { pays: "belgique", nb: 2}];
    { name: 'pays' },
    { name: 'nb' }
    localdata: data1
    $('#sp7').jqxChart({
    title: "Répartitions des inscrits par pays",
    legendLayout: { left: 20, top: 220, width: 200, height: 200, flow: 'vertical' },
    colorScheme: 'scheme03',
    seriesGroups: [{
    type: 'pie',
    showLabels: true,
    series: [{
    dataField: 'nb',
    displayText: 'pays',
    labelRadius: 120,
    initialAngle: 15,
    radius: 95,
    centerOffset: 0
    <div id='host' style="margin: 0 auto; width: 699px; height: 400px;">
    <div id='sp7' style="width: 680px; height: 400px; position: relative; left: 0px;
    top: 0px;">
    jqWidgets team
    problem chart #7374
    wanfr13
    hello Dimitar,
    ok and thank you for :
    var source = {
    { name: ‘pays’ },
    { name: ‘nb’ }
    localdata: data
    works with :
    var data1 = [{ pays: “USA”, nb: 1 }, { pays: “France”, nb: 25 }, { pays: “belgique”, nb: 2}];
    but not work with :
    var data = '[';
    $('.pays').each(function() {
    data = data + '{"Pays":' + $(this).text() + ',"Nb":' + $(this).next().text() + '},';
    data = data + ']';
    alert(data);
    result : [{ pays: “USA”, nb: 1 }, { pays: “France”, nb: 25 }, { pays: “belgique”, nb: 2}]
    I do not understand the difference…
    problem chart #7389
    wanfr13
    Hi Dimitar,
    Here is my code
    echo 'p class=hidden;
    $r_usr = pg_query ("SELECT usr_pays, COUNT(usr_pays) FROM lt_usr GROUP BY usr_pays ORDER BY usr_pays ASC;");
    while ($arr_usr = pg_fetch_array($r_usr)) {
    if ($arr_usr['usr_pays'] ==='') {
    $arr_usr['usr_pays'] = 'non-renseigné';
    echo 'span class=pays' .$arr_usr['usr_pays'] .'/span span class=nb' .$arr_usr['count'] .'/span';
    echo 'p div style=width: 680px;height: 400px /div'
    var data = '[';
    data = data + ']';
    $(this).text () is the first span is the name of the country ( USA, France Belgique……)
    $(this).next ().text () the second span is the number of membre (1, 25, 2……)
    Best regards
    problem chart #7399
    Hi wanfr13,
    The issue with your structure:
    having in mind that the text of the “pays” classes is for example “USA”, “France” and “belgique”, is that $(this).text() gets “USA” in the first iteration and $(this).next().text() gets “France” and so the JSON structure is as follows:
    [ {“pays”: “USA”, “nb”: “France”},… ] and not [ {“pays”: “USA”, “nb”: 1},… ].
    jqxChart needs at least one numeric value and the example gives it two strings – “USA” and “France”. You sholud change the structure $(this).next().text() to something that better suits your needs.
    You may also want to provide us with your entire source code so we can better understand your example.
    jqWidgets team
    problem chart #7400
    Hi wanfr13,
    Please post your entire source code, including the HTML. To do it, paste your code, select it and then click the Format HTML Code button above the Reply panel (it looks like { }).
    jqWidgets team
    problem chart #7408
    wanfr13
    Hi Dimitar
    code html
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="fr" lang="fr">
    <script type="text/javascript" src="default/js/jquery.min.js"></script> //1
    <script type="text/javascript" src="default/js/jqwidgets/jqxcore.js"></script>
    <script type="text/javascript" src="default/js/jqwidgets/jqxchart.js"></script>
    <script type="text/javascript" src="default/js/jqwidgets/jqxdata.js"></script>
    <link rel="stylesheet" href="default/js/jqwidgets/styles/jqx.base.css" type="text/css" />
    var data = ‘[';
    data = data + ']‘;
    { name: 'pays' },
    { name: 'nb' }
    localdata: data
    legendLayout: { left: 20, top: 155, width: 200, height: 200, flow: 'vertical' },
    seriesGroups: [{
    type: 'pie',
    showLabels: true,
    series: [{
    dataField: 'nb',
    labelRadius: 120,
    initialAngle: 15,
    radius: 95,
    centerOffset: 0
    <body>
    <div id="ssite">
    <p class="hidden">
    <span class="pays">non-renseigné</span><span class="nb">70</span>
    <span class="pays">Belgique</span><span class="nb">2</span>
    <span class="pays">France</span><span class="nb">25</span>
    <span class="pays">suisse</span><span class="nb">1</span>
    <span class="pays">USA</span><span class="nb">1</span>
    </p>
    <div id="sp7" style="height: 400px; position: relative; left: 0px; top: 0px;"></div>
    code php
    if (!$r_usr) {
    echo "Erreur durant la requète sur lt_eur.<BR>";
    exit;
    $num_usr = pg_num_rows($r_usr);
    echo "\n\t\t\t\t\t\t\t" .'<div id="ssite">'
    ."\n\t\t\t\t\t\t\t\t" ."<h3>Statistiques de l'espace privé</h3>"
    ."\n\t\t\t\t\t\t\t\t" .'<p class="hidden">';
    echo "\n\t\t\t\t\t\t\t\t\t" .'<span class="pays">' .$arr_usr['usr_pays'] .'</span><span class="nb">' .$arr_usr['count'] .'</span>';
    echo "\n\t\t\t\t\t\t\t\t\t" .'</p>';
    echo "\n\t\t\t\t\t\t\t\t" .'<div id="sp7" style="height: 400px; position: relative; left: 0px; top: 0px;"></div>';
    echo "\n\t\t\t\t\t\t\t" .'</div>'
    ."\n\t\t\t\t\t\t";
    excuse me for my ignorance
    thank you very much
    wanfr
    problem chart #7413
    Hi wanfr,
    We have fixed your code and now it is working:
    <script type="text/javascript" src="../jqwidgets2.4/jqxcore.js"></script>
    <script type="text/javascript" src="../jqwidgets2.4/jqxchart.js"></script>
    <script type="text/javascript" src="../jqwidgets2.4/jqxdata.js"></script>
    <link rel="stylesheet" href="../jqwidgets2.4/styles/jqx.base.css" type="text/css" />
    var data = '[';
    $('.pays').each(function () {
    data = data + '{ "Pays": "' + $.trim($(this).text()) + '", "Nb": "' + $.trim($(this).next().text()) + '" },';
    data = data.substr(0, data.length - 1);
    data = data + ']';
    datatype: 'json',
    { name: 'Pays' },
    { name: 'Nb', type: 'number' }
    localdata: data
    seriesGroups: [{
    type: 'pie',
    showLabels: true,
    series: [{
    dataField: 'Nb',
    displayText: 'Pays',
    labelRadius: 120,
    initialAngle: 15,
    radius: 95,
    centerOffset: 0
    <body>
    <div id="ssite">
    <p class="hidden">
    <span class="pays">non-renseigné</span><span class="nb">70</span> <span class="pays">
    Belgique</span><span class="nb">2</span> <span class="pays">France</span><span class="nb">25</span>
    <span class="pays">suisse</span><span class="nb">1</span> <span class="pays">USA</span><span
    class="nb">1</span>
    </p>
    jqWidgets team
    problem chart #7415
    wanfr13
    Hi dimitar
    bravo !
    jason encoding will allow me to go further
    everything is ok
    thank you very much
