jQuery UI Widgets Forums Plugins AngularJS Please HELP!!!
This topic contains 7 replies, has 3 voices, and was last updated by  mikemazz 10 years, 5 months ago.
  • Please HELP!!! #62721
    mikemazz
    I’m struggling with getting a simple AngularJS directive ng-repaat to work in my jqxTab. For some reason when inside of the <jxq-splitter> I have not access to the $scope. If I put a template reference like {{ users[0].login }} just above the <jqx-splitter> it works fine.
    I really like jqxwidgets and angular but I’m totally frustrated with this integration.
    <jqx-splitter jqx-settings="userSplitterSettings">
            <div id="userList">
                {{ totalUsers }}
                <div style="margin-left: 20px; margin-right: 20px; margin-bottom: 10px;">
                    <jqx-grid jqx-instance="userGrid" jqx-create="createWidget" jqx-settings="gridSettings" jqx-orientation="horizontal"></jqx-grid>
            <div id="userInfo">
                <jqx-tabs jqx-data="users" jqx-create="createWidget" jqx-width="'100%'" jqx-height="'100%'" jqx-animation-type="'fade'" jqx-selection-tracker="'true'">
                    <ul>
                        <li style="margin-left: 30px;">A</li>
                        <li>B</li>
                        <li>C</li>
                        <li>D</li>
                        <li>E</li>
                        <li ng-repeat="user in data">{{ user.login }}</li>
                    </ul>
                    <div>
                        {{totalUsers}}
                        <div ng-repeat="user in data" style="margin: 15px;">
                           <div style="margin-bottom: 10px;">
                               User Id: {{ user.userId }}
                            <div style="float: left; width: 15%;">
                                <div class='jqx-rc-all' style='margin: 10px;'></div>
                                <div style='margin-top: 10px;'>
                                    <img height="60" width="60" src="images/users/unknown.jpg">
                            <div style="float: left; width: 45%;">
                                <div style='margin: 10px;'>Login: </div>
                                <div style='margin: 10px;'>Name:</div>
                                <div style='margin: 10px;'>E-mail: </div>
                                <div style='margin: 10px;'>Phone: </div>
                    <div>
                    <div>
                    <div>
                    <div>
                </jqx-tabs>
        </jqx-splitter>
    Please HELP!!! #62725
    Hello Mike,
    Each Directive has its own Isolated scope. That should answer why your code will not work in that way. If you want to bind inner to outer scope members, you will have to use jqx-data attribute.
    Please HELP!!! #62726
    mikemazz
    Peter,
    I am using the jqx-data attribute in the above example. It seems to work until I tried to do it within the jqx-tab. Any other ideas?
    Please HELP!!! #62765
    Hi mikemazz,
    You’re using the data attribute but you tried to bind it to something which is in different scope. Your jqxTabs directive is in the jqxSplitter directive i.e you can bind the jqxTabs to jqxSplitter’s data and you can bind the jqxSplitter’s data to the outer scope.
    Please HELP!!! #62806
    mikemazz
    Peter,
    How do I bind an inner element data to an outer scope? I don’t see any documentation on it.
    – Mike
    Please HELP!!! #62810
    Hi mikemazz,
    Through the “jqx-data” attribute. I am sure you know about Isolted Scopes. Each directive has isolated scope. When you put a directive inside a directive, the outer scope for the inner directive will be isolated scope, too. That’s how you should pass data up and down through the hierarchy, through the jqx-data attribute and inside the directive you refer to it with “data.xxx”.
    Please HELP!!! #62887
    bobmazzo
    Mike,
    Have you found any docs on the jqx-data directive ? I only find one minor example under the “button” example here: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxangular/index.htm?%28arctic%29#demos/jqxangular/button.htm
    Please HELP!!! #62899
    mikemazz
    No, I have not found examples. However, Peter has been helping. The key is to understand that these special angular jqwidgets use isolated scope which can be kind of tricky to understand. I was able to get much stuff working but the fact is I don’t have a lot of experience with isolated scope and it trips me up.
