jQuery UI Widgets Forums Grid Please give a example for textarea focus problem
This topic contains 4 replies, has 2 voices, and was last updated by  devsim 4 years, 11 months ago.
  • devsim
    Hello.
    Can I get a example for this issue.
    https://www.jqwidgets.com/community/topic/enter-focus-problem-textarea-in-jqxgrid/
    Sir. Peter Stoev answer to me ‘You can use the editorElement.focus() to put the focus to the first character in the editor’
    It’s too much hard too me plase give a example for me~~~ please… 🙁
    Hi devsim,
    The example is available here: http://jsfiddle.net/jqwidgets/t25k2Lch/
    devsim
    Thank you for example. Sir. Peter Stoev.
    But here’s my real question !
    $(“#grid”).jqxGrid(
    width: getWidth(‘Grid’),
    handlekeyboardnavigation: function (event)
    var key = event.charCode ? event.charCode : event.keyCode ? event.keyCode : 0;
    if (key == 13) {
    currentContent = editorElement.val() + ‘\n’;
    editorElement.val(currentContent);
    return true;
    } else if (key == 27) {
    return true;
    text: ‘First Name’,
    columntype: ‘template’,
    datafield: ‘firstname’,
    width: 120,
    createeditor: function(row, cellvalue, editor, celltext, cellwidth, cellheight) {
    editorElement = $(‘<textarea id=”customTextArea’ + row + ‘”></textarea>’).prependTo(editor);
    editorElement.jqxTextArea({
    height: 88,
    width: ‘100%’
    initeditor: function (row, cellvalue, editor, celltext, pressedChar)
    currentContent = ”;
    geteditorvalue: function(row, cellvalue, editor) {
    return editor.find(‘textarea’).val();
    { text: ‘Contact Name’, datafield: ‘ContactName’, width: 150 },
    { text: ‘Contact Title’, datafield: ‘ContactTitle’, width: 180 },
    { text: ‘City’, datafield: ‘City’, width: 120 },
    { text: ‘Postal Code’, datafield: ‘PostalCode’, width: 90 },
    { text: ‘Country’, datafield: ‘Country’, width: 100 }
    upper example is
    when I located a and b the cursor
    1.
    ab
    and I press Enter Key.
    2.
    ab
    3.
    ab
    _ <— cursur
    I want like this
    4.
    a
    b <—– cursur
    it is very hard to make source to me…
    please help me.. 🙁
    Hi devsim,
    In the initeditor call the focus method in order to focus the textarea when it becomes visible.
    devsim
    After 11 months later
    I solved the problem.
    This is My solution
    var editorElement = null;
    var currentContent = ”;
    $(“#devsimGrid”).jqxGrid({
    handlekeyboardnavigation: function (event) {
    if (key == 13) {
    var txtArea = editorElement[0];
    var txtValue = txtArea.value;
    var selectPos = txtArea.selectionStart;
    var beforeTxt = txtValue.substring(0, selectPos);
    var afterTxt = txtValue.substring(txtArea.selectionEnd, txtValue.length);
    currentContent = beforeTxt + “\n” + afterTxt;
    var pos = (selectPos+1);
    var obj = document.getElementById(“customTextArea0TextArea”);
    if (obj.setSelectionRange) {
    obj.focus();
    obj.setSelectionRange(pos, pos);
    else if (obj.createTextRange) {
    var c = obj.crateTextRange();
    c.move(“character”, pos);
    c.select();
    return true;
    return true;
    text: ‘Work’,
    datafield: ‘Work’,
    width: ‘380px’,
    align: ‘center’,
    cellsrenderer: textrenderer,
    height: 88,
    width: ‘100%’
    initeditor: function (row, cellvalue, editor, celltext, pressedChar) {
    currentContent = ”;
    editorElement.val(cellvalue);
    geteditorvalue: function (row, cellvalue, editor) {
    Hey Peter
    I think you have to love your job….
