jQuery UI Widgets › Forums › Chart › [PIE CHART] with PHP/MySQL — Problem display chart
Tagged: [PIE CHART] with PHP/MySQL -- Problem display, Angular chart, chart, datafield, jquery chart, jqxChart, php, pie, Pie chart, series
This topic contains 5 replies, has 2 voices, and was last updated by Dimitar 9 years, 3 months ago.
I work on the code below but I’am blocked.
I work with a Database “MySQL” and my Website is in PHP language.
I try to create a Chart with your code.
And follow my code.I have a script : graph_table.php
#Connection DataBase
include(‘/database/bdd.php’);
#Get date Start and Stop
$date_start = $_GET[‘date_start’];
$date_stop = $_GET[‘date_stop’];//Changement date –> FRANCE to ENGLISH
$date_start_EN = date_format(date_create_from_format(‘d/m/Y’, $date_start), ‘Y-m-d’);
$date_stop_EN = date_format(date_create_from_format(‘d/m/Y’, $date_stop), ‘Y-m-d’);//SQL request which is count the request status between Start date and Stop date
$sql = “SELECT stat,COUNT(stat) AS nbStat FROM <table> WHERE date BETWEEN ‘$date_start_EN’ AND ‘$date_stop_EN’ GROUP BY stat”;
$result_nbStat = mysql_query($sql) or die(“SQL Error 1: ” . mysql_error());;?>
<?php
echo(“var source = [];”);
while ($row = mysql_fetch_array($result_nbStatutRequest))
$stat = $row[‘stat’];
$nbStat = $row[‘nbStat’];echo(“source.push(\”$stat, $nbStat; \”);\n”);
?>var dataAdapter = new $.jqx.dataAdapter(source, { async: false, autoBind: true, loadError: function (xhr, status, error) { alert(‘Error loading “‘ + source.url + ‘” : ‘ + error); } });
// prepare jqxChart settings
var settings =
title: “”,
description: “”,
enableAnimations: true,
showLegend: true,
showBorderLine: true,
legendPosition: { left: 520, top: 140, width: 200, height: 100 },
// legendLayout : { right: 50, top: 40, width:100, height: 100, flow: ‘vertical’ },
titlePadding: { left: 0, top: 0, right: 0, bottom: 10 },
colorScheme: ‘scheme01’,
seriesGroups:
type: ‘pie’,
showLabels: true,
series:
//dataField: ‘Value’,
//displayText: ‘Status’,
labelRadius: 120,
initialAngle: 15,
radius: 70,
centerOffset: 0,}
};</script>
And my WebSite page :
include (“graph_test.php”);
var myChart = $(‘#chartContainer’).jqxChart(settings);
// add a new color scheme named ‘myScheme’
myChart.jqxChart(‘addColorScheme’, ‘myScheme’, [‘#459AFE’, ‘#DC5551’, ‘#C0C0C0’]);
// apply the new scheme by setting the chart’s colorScheme property
myChart.jqxChart(‘colorScheme’, ‘myScheme’);
// refresh the chart
myChart.jqxChart(‘refresh’);On the Browser, I have a Legend with this information :
” Clos, 107; Mal, 1; Re, 9; Wai, 1; Waiut, 4; ”
But not the PIE Chart and I don’t found the error on the code.
I see the page for PHP MySQL :
http://www.jqwidgets.com/jquery-widgets-demo/demos/php/index.htm?%28arctic%29#demos/php/chart.htmBut same error.
Is it possible to check if you seen an error on my code.
Thanks In advance for your feedback.
Regards.
CocoHello Coco,
You need to set the dataField of your series (it is commented in your code). If this does not help solve the issue, please share some sample data so that we may test your code locally.
http://www.jqwidgets.com/Hello,
Thanks for your feedback.
Yes, Datafield is commented but if I de-commented the “DataField” parameters, I have the same result on my browser. I think the problem does not providedThanks in advance.
Regards
CocoHi Coco,
Please share some sample data so that we may test your code locally and determine what causes the issue.
This is more complicated to give you a Data because my data source is extracted by the SQL request.
But an overview about the data :
Clos 107
Malf 1
Reject 9
Waiting 1
Waiting Input 4Thanks in advance.
Regards and Happy New year.
CocoHi Coco,
Here is a working example with your data and chart settings:
<!DOCTYPE html> <html lang="en"> <head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.11.1.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdraw.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxchart.core.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript"> $(document).ready(function () { var data = [{ "Status": "Clos", "Value": 107 }, { "Status": "Malf", "Value": 1 }, { "Status": "Reject", "Value": 9 }, { "Status": "Waiting", "Value": 1 }, { "Waiting Input": 4}]; // prepare chart data as an array var source = { datatype: "json", datafields: [ { name: 'Status' }, { name: 'Value' } ], localdata: data }; var dataAdapter = new $.jqx.dataAdapter(source, { async: false, autoBind: true, loadError: function (xhr, status, error) { alert('Error loading "' + source.url + '" : ' + error); } }); // prepare jqxChart settings var settings = { title: "", description: "", enableAnimations: true, showLegend: true, showBorderLine: true, legendPosition: { left: 520, top: 140, width: 200, height: 100 }, // legendLayout : { right: 50, top: 40, width:100, height: 100, flow: 'vertical' }, padding: { left: 5, top: 5, right: 5, bottom: 5 }, titlePadding: { left: 0, top: 0, right: 0, bottom: 10 }, source: dataAdapter, colorScheme: 'scheme01', seriesGroups: [{ type: 'pie', showLabels: true, series: [{ enableAnimations: true, dataField: 'Value', displayText: 'Status', labelRadius: 120, initialAngle: 15, radius: 70, centerOffset: 0 }] }] }; // setup the chart $('#chartContainer').jqxChart(settings); }); </script> </head> <body class='default'> <div id='chartContainer' style="width: 850px; height: 500px;"> </div> </body> </html>
