jQuery UI Widgets Forums Layouts Panel and Responsive Panel panel & scroll on mobile devices
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 8 years, 7 months ago.
  • panel & scroll on mobile devices #87305
    Florian Auer
    Hi
    I have an issue with the scrolling behaviour of a panel in a dockPanel layout on a tablet.
    The result of scrolling is not as expected:
    • scrolling down mosty scrolls all the way down in one big animation, independent of the gestures length and speed.
    • scolling up sometimes seem not not fire the event so the panel does not scroll
    • the scrolling event seem to execute after the gesture finished
    I tried to create an example as code snipped of the created Ui.
    https://jsfiddle.net/ref83vz4/6/
    Did i implement something the wrong way?
    In the original application i now catch the “swipetop” and “swipebutton” events and manually implemented a scroll effect by using the scrollBar-properties of the panel. But this does not look so nice as “regular scrolling”
    panel & scroll on mobile devices #87318
    Hello Florian Auer,
    We could not spend time to create/check (private) project. Thank you for the example but it is too big source.
    However, first the jqxDockPanel (could try to change with another widget – ex: jqxPanel) do not have such feature – scrollbar and another that I saw is the way you set height of the widget ( $(“#dockPanel”).height(600) correct way is $("#dockPanel").jqxDockPanel({height: 600});)
    Please, provide small examples with issues for particular Widget if it is possible.
