jQuery UI Widgets Forums Layouts Panel and Responsive Panel Panel content and scrollbar dissappear
This topic contains 1 reply, has 1 voice, and was last updated by  gwailoh 5 years, 7 months ago.
  • Panel content and scrollbar dissappear #106895
    gwailoh
    Hi folks. I use a jqxPanel to display messages received from a server in a client/server application; new messages appended on receipt, panel scrolling upward to display them. Has worked happily for years, but sometime fairly recently without changes on our part the panel has begun to misbehave. At some point the text and scrollbar disappear, leaving a blank panel which subsequently fails to display new messages.
    Before I work up a jsfiddle to attempt to reproduce, can you tell me how to roll-back to earlier versions of jqx-all.js? I reference it this way: “<script src=”https://jqwidgets.com/public/jqwidgets/jqx-all.js”></script>”. I tried playing with “jqx-all-7.2.0.js” and similar with no luck. I’d like to roll back to an earlier release to get our app stable again, then work on reproducing the issue to show it to you.
    Thx!
    Panel content and scrollbar dissappear #106899
    gwailoh
    I found the instructions for using npm to pull previous versions. So that’s settled.
    Thx.
