jQuery UI Widgets Forums Grid Paging issue
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 12 years, 6 months ago.
    Paging issue Posts
  • Paging issue #8860
    vossg
    I’m retrieving data froma 3rd party API that only returns a max of 50 rows at a time, but will return a total count of records (3,412).
    Is it possible to use paging under these circumstances without getting all 3,412 rows back at once and tell the pager control that I have 3,412?
    The API allows me to retrieve the “next” n…..50 rows each way.
    So ideall I would like to let the pager know I have 3,142 and each time the next or back button is pushed retreive the correct range of the next 50 rows.
    I’m trying to avoid caching or saving all 3,412 rows in a Db because it’s break their license agreement.
    thanks,
    voss.
    Paging issue #8893
    Hi voss,
    You can use server paging. For example: php-server-side-grid-paging.htm.
    Paging issue #8895
    vossg
    Peter,
    I’m not using PHP or MySql. Looking for a javascript solution or MVC.
    thanks.
    voss.
    Paging issue #8897
    Hi voss,
    See this sample: virtualdata.htm.
    It shows paging with virtual data i.e data loaded on demand.
