jQuery UI Widgets Forums Navigation Tree onClick jqxTree focus move on top.
This topic contains 3 replies, has 4 voices, and was last updated by  Satyarao 5 years, 4 months ago.
  • onClick jqxTree focus move on top. #13369
    zohaib
    I am calling jqxTree in Iframe and when I click on link then it move fucus on top instead of selected item.
    Following is the example of the problem.
    treeFrame.htm
    <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
    <title>Tree Frame</title>
    <body>
    <table width="50%" border="0">
    <tr id="frameRow">
    <td>
    <iframe id="treeFrame" src="treeFrame2.htm" width="50%" height="100%" scrolling="yes" frameborder="0">
    </iframe>
    <td>
    </tr>
    </table>
    treeFrame2.htm
    <title id='Description'>In this demo the jqxTree is built from JSON data.</title>
    <link rel="stylesheet" href="jqwidgets/styles/jqx.base.css" type="text/css" />
    <script type="text/javascript" src="scripts/gettheme.js"></script>
    <script type="text/javascript" src="scripts/jquery-1.7.2.min.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxdata.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxbuttons.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxscrollbar.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxpanel.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxtree.js"></script>
    <body>
    <div id='content'>
    var theme = getTheme();
    var data = [
    { "id": "2",
    "parentid": "1",
    "text": "Hot Chocolate"
    "id": "3",
    "parentid": "1",
    "text": "Peppermint Hot Chocolate"
    "id": "4",
    "parentid": "1",
    "text": "Salted Caramel Hot Chocolate"
    "id": "5",
    "parentid": "1",
    "text": "White Hot Chocolate"
    "text": "Chocolate Beverage",
    "id": "1",
    "parentid": "-1"
    "id": "6",
    "text": "Espresso Beverage",
    "parentid": "-1"
    "id": "7",
    "parentid": "6",
    "text": "Caffe Americano"
    "id": "8",
    "text": "Caffe Latte",
    "parentid": "6"
    "id": "9",
    "text": "Caffe Mocha",
    "parentid": "6"
    "id": "10",
    "text": "Cappuccino",
    "parentid": "6"
    "id": "11",
    "text": "Pumpkin Spice Latte",
    "parentid": "6"
    "id": "12",
    "text": "Frappuccino",
    "parentid": "-1"
    "id": "13",
    "text": "Caffe Vanilla Frappuccino",
    "parentid": "12"
    "id": "15",
    "text": "450 calories",
    "parentid": "13"
    "id": "16",
    "text": "16g fat",
    "parentid": "13"
    "id": "17",
    "text": "13g protein",
    "parentid": "13"
    "id": "14",
    "text": "Caffe Vanilla Frappuccino Light",
    "parentid": "12"
    { name: 'id' },
    { name: 'parentid' },
    { name: 'text' }
    localdata: data
    // create data adapter.
    // perform Data Binding.
    dataAdapter.dataBind();
    // get the tree items. The first parameter is the item's id. The second parameter is the parent item's id. The 'items' parameter represents
    // the sub items collection name. Each jqxTree item has a 'label' property, but in the JSON data, we have a 'text' field. The last parameter
    // specifies the mapping between the 'text' and 'label' fields.
    var records = dataAdapter.getRecordsHierarchy('id', 'parentid', 'items', [{ name: 'text', map: 'label'}]);
    $('#jqxWidget').jqxTree({ source: records, width: '300px', theme: theme });
    $('#jqxWidget').jqxTree('selectItem', $("#jqxWidget").jqxTree('expandAll'));
    function expand_all(){
    $('#jqxWidget').jqxTree('expandAll');
    function collapse_all(){
    $('#jqxWidget').jqxTree('collapseAll');
    <div id='jqxWidget'>
    – Thanks
    Zohaib.
    onClick jqxTree focus move on top. #13425
    Hello Zohaib,
    There seems to be an issue with the focus of the elements and therefore the iframe automatically scrolls to the top. Unfortunately, we cannot offer you any solution on the matter.
    onClick jqxTree focus move on top. #14265
    harish kumar
    Hello Zohaib,
    Issue is that you have set the toggle mode to “dblClick” (or) by default its set to dblclick in jqxTree, To fix the issue you need to replace the below modified code in “_updateItemEvents” event find h.toggleMode!=”click” condition and replace with modified code.
    Actual Code :
    if (h.toggleMode != “click”) {
    h.addHandler(c, “click”, function (l) {
    h.selectItem(k.element);
    if (h.panel != null) {
    h.panel.jqxPanel({ focused: true })
    h.host.focus()
    Modified Code :
    if (d.length > 0) {
    clearTimeout(d.data(“timer”).hide)
    } if (h.panel != null) {
    if (k.isExpanding == undefined) {
    k.isExpanding = false
    if (k.isCollapsing == undefined) {
    k.isCollapsing = false
    h.panel.jqxPanel({ autoUpdate: false });
    if (d.length > 0) {
    if (!k.isExpanded) {
    if (false == k.isExpanding) {
    k.isExpanding = true; h._expandItem(h, k)
    h.panel.jqxPanel({ autoUpdate: true })
    Best Regard,
    Harish Kumar A
    onClick jqxTree focus move on top. #107552
    Satyarao
    Hi Harish Kumar,
    The suggested change didn’t help. JqxTreeGrid is still jumping for the first click in my webapp.
    Satyarao.
