jQuery UI Widgets Forums Angular not able to compile with angular 11
This topic contains 4 replies, has 2 voices, and was last updated by  admin 2 years, 3 months ago.
  • not able to compile with angular 11 #132205
    rajesh gupta
    I am not able to compile with angular 11. I am using node 16 on ubuntu.
    Here is my package.json
    “dependencies”: {
    “@angular/animations”: “~11.1.1”,
    “@angular/common”: “~11.1.1”,
    “@angular/compiler”: “~11.1.1”,
    “@angular/core”: “~11.1.1”,
    “@angular/fire”: “^6.1.4”,
    “@angular/forms”: “~11.1.1”,
    “@angular/localize”: “^11.1.1”,
    “@angular/platform-browser”: “~11.1.1”,
    “@angular/platform-browser-dynamic”: “~11.1.1”,
    “@angular/router”: “~11.1.1”,
    “@kolkov/angular-editor”: “^1.1.2”,
    “@ng-bootstrap/ng-bootstrap”: “^6.0.0”,
    “@types/file-saver”: “^1.3.0”,
    “core-js”: “^2.5.4”,
    “file-saver”: “^1.3.3”,
    “firebase”: “^8.2.4”,
    “jqwidgets-ng”: “^9.1.6”,
    “mydatepicker”: “^9.0.2”,
    “ngx-cookie”: “4.0.2”,
    “rxjs”: “^6.6.3”,
    “tslib”: “^2.0.0”,
    “zone.js”: “~0.10.2”
    not able to compile with angular 11 #132206
    rajesh gupta
    Following are the errors
    ERESOLVE overriding peer dependency
    npm WARN While resolving: @angular/cdk@9.2.4
    npm WARN Found: @angular/common@11.1.1
    npm WARN node_modules/@angular/common
    npm WARN   @angular/common@"~11.1.1" from the root project
    npm WARN   6 more (@angular/fire, @angular/forms, ...)
    npm WARN
    npm WARN Could not resolve dependency:
    npm WARN peer @angular/common@"^9.0.0 || ^10.0.0-0" from @angular/cdk@9.2.4
    npm WARN node_modules/@angular/cdk
    npm WARN   @angular/cdk@"^9.1.1" from jqwidgets-ng@9.1.7
    npm WARN   node_modules/jqwidgets-ng
    npm WARN
    npm WARN Conflicting peer dependency: @angular/common@10.2.5
    npm WARN ERESOLVE overriding peer dependency
    npm WARN Found: @angular/core@11.1.1
    npm WARN node_modules/@angular/core
    npm WARN   @angular/core@"~11.1.1" from the root project
    npm WARN   8 more (@angular/animations, @angular/common, @angular/fire, ...)
    npm WARN
    npm WARN peer @angular/core@"^9.0.0 || ^10.0.0-0" from @angular/cdk@9.2.4
    npm WARN
    npm WARN Conflicting peer dependency: @angular/core@10.2.5
    npm WARN Found: tslib@2.0.3
    npm WARN node_modules/tslib
    npm WARN   tslib@"^2.0.0" from the root project
    npm WARN   10 more (@angular/animations, @angular/common, ...)
    npm WARN
    npm WARN peer tslib@"^1.9.0" from @angular/cdk@9.2.4
    npm WARN
    npm WARN Conflicting peer dependency: tslib@1.14.1
    npm WARN While resolving: @angular/elements@9.1.13
    npm WARN
    npm WARN peer @angular/core@"9.1.13" from @angular/elements@9.1.13
    npm WARN node_modules/@angular/elements
    npm WARN   @angular/elements@"^9.0.5" from jqwidgets-ng@9.1.7
    npm WARN
    npm WARN Conflicting peer dependency: @angular/core@9.1.13
    npm WARN Found: @angular/platform-browser@11.1.1
    npm WARN node_modules/@angular/platform-browser
    npm WARN   @angular/platform-browser@"~11.1.1" from the root project
    npm WARN   4 more (@angular/fire, @angular/forms, ...)
    npm WARN
    npm WARN peer @angular/platform-browser@"9.1.13" from @angular/elements@9.1.13
    npm WARN
    npm WARN Conflicting peer dependency: @angular/platform-browser@9.1.13
    npm WARN
    npm WARN peer tslib@"^1.10.0" from @angular/elements@9.1.13
    npm WARN
    npm ERR! code ERESOLVE
    npm ERR! ERESOLVE could not resolve
    npm ERR!
    npm ERR! While resolving: @kolkov/angular-editor@1.1.4
    npm ERR! Found: @angular/common@11.1.1
    npm ERR! node_modules/@angular/common
    npm ERR!   @angular/common@"~11.1.1" from the root project
    npm ERR!   peer @angular/common@"^9.0.0 || ^10.0.0 || ^11.0.0" from @angular/fire@6.1.4
    npm ERR!   node_modules/@angular/fire
    npm ERR!     @angular/fire@"^6.1.4" from the root project
    npm ERR!   5 more (@angular/forms, @angular/platform-browser, ...)
    npm ERR!
    npm ERR! Could not resolve dependency:
    npm ERR! peer @angular/common@">=8.0.0 <11" from @kolkov/angular-editor@1.1.4
    npm ERR! node_modules/@kolkov/angular-editor
    npm ERR!   @kolkov/angular-editor@"^1.1.2" from the root project
    npm ERR!
    npm ERR! Conflicting peer dependency: @angular/common@10.2.5
    npm ERR!
    npm ERR! Fix the upstream dependency conflict, or retry
    npm ERR! this command with --force, or --legacy-peer-deps
    npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
    npm ERR!
    npm ERR! See /root/.npm/eresolve-report.txt for a full report.
    npm ERR! A complete log of this run can be found in:
    npm ERR!     /root/.npm/_logs/2023-01-10T13_24_46_604Z-debug-0.log
    not able to compile with angular 11 #132209
    admin
    With Angular 11, you will need to use an old version of the jqwidgets-ng package which is released after the release of Angular 11 and before the release of Angular 13. The current version is packaged and suitable for Angular 13+.
    Peter
    not able to compile with angular 11 #132217
    rajesh gupta
    which version of the jqwidgets-ng should be used with angular11.
    Where can I see the doc on the jqwidgets version and the equivalent angular version to be used
    not able to compile with angular 11 #132218
    admin
    You can look at https://www.jqwidgets.com/jquery-widgets-documentation/documentation/releasehistory/releasehistory.htm. jQWidgets v11.0.0 Release, Nov-16-2020 has Angular 11 support.
    Peter
