jQuery UI Widgets Forums Grid NestedGrid- Color cells
This topic contains 6 replies, has 2 voices, and was last updated by  kkasunperera 12 years, 6 months ago.
  • NestedGrid- Color cells #9077
    kkasunperera
    Hi
    I’m using NestedGrid and below is my code.
    1) I want to go through each child grid and compare each column’s cell values with each other column’s cell values
    is there a function to get no of columns in child grid?
    how to get no of cells in a column?
    2) Then if particular cell value is same as a cell value in other column I want to color both with a perticuler color.
    ‘ e.g. if column:1 cell:2 value appears in some cell in column 2,4,5, I want to color all 4 cells with “blue” color
    Is this possible, I could not find any functions to do this from the API, If this is possible please give me some hints how to do this
    <link rel="stylesheet" href="jqwidgets/styles/jqx.base.css" type="text/css" />
    <script type="text/javascript" src="scripts/jquery-1.8.1.min.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxdata.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxbuttons.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxscrollbar.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxmenu.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxgrid.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxgrid.grouping.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxgrid.selection.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxgrid.columnsresize.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxtabs.js"></script>
    <script type="text/javascript" src="scripts/gettheme.js"></script>
    var theme = getTheme();
    var data = new Array();
    var documentName=["HSBC inc.","City Bank"];
    var sectionName =["Risk Factors","Discription of Notes","Plan of Distribution","ERISA Considerations", "Tax Considerations"];
    var sectionCatogoryID= ["0","1","2","3","4"];
    var docSec=new Array();
    // create nested arrays
    for(var i=0; i<sectionName.length; i++){
    docSec[i]=new Array();
    for(var j=0; j<documentName.length; j++){
    docSec[i][j]= new Array();
    docSec[0][0]=["Putable","Calleble","assets managed by","Asset Pool Equity","Strippable"];
    docSec[0][1]= ["Putable","Strippable","Asset Pool Equity","Strippable"];
    docSec[0][2]= ["Putable"];
    docSec[0][3]= ["Bond Pool","Bullet Bond","Cash CDO"];
    docSec[1][0]=[];
    docSec[1][1]= ["Putable","Strippable","Asset Pool Equity","Strippable"];
    docSec[1][2]= ["Calleble","assets managed by","Asset Pool Equity","Strippable"];
    docSec[1][3]= ["Bond Pool","Cash CDO"];
    docSec[2][0]=["Management Style","Seniority","CDO Portfolio Manager"];
    docSec[2][1]= ["Putable","Strippable","Asset Pool Equity","Strippable"];
    docSec[2][2]= [];
    docSec[2][3]= ["Bond Pool","Cash CDO"];
    docSec[3][0]=["Value At Issue"];
    docSec[3][1]= ["Putable","Strippable","Asset Pool Equity","Strippable"];
    docSec[3][2]= ["Calleble","assets managed by","Asset Pool Equity","Strippable","Cash CDO"];
    docSec[3][3]= [];
    docSec[4][0]=["Value At Issue"];
    docSec[4][1]= ["Putable","Strippable","Asset Pool Equity","Strippable"];
    docSec[4][2]= ["Calleble","assets managed by","Asset Pool Equity","Strippable","Value At Issue"];
    docSec[4][3]= ["Strippable","Asset Pool Equity"];
    var k = 0;
    for (var i = 0; i < sectionName.length; i++) {
    var row = {};
    row["sectionname"] = sectionName[k];
    row["sectioncatogory"] = sectionCatogoryID[k];
    data[i] = row;
    k++;
    localdata: data,
    datatype: "array"
    var initrowdetails = function (index, parentElement, gridElement, datarecord) {
    var tabsdiv = null;
    var information = null;
    var notes = null;
    tabsdiv = $($(parentElement).children()[0]);
    var data2 = new Array();
    for (var i = 0; i < 10; i++) {
    var row2 = {};
    for (var j = 0; j < documentName.length; j++) {
    if(typeof docSec[datarecord.sectioncatogory][j] == 'undefined') {
    row2["doc"+j]="";
    else{
    row2["doc"+j] = docSec[datarecord.sectioncatogory][j][i];
    // row2["doc1"] = docSec[datarecord.sectioncatogory][1][i];
    // row2["doc2"]= docSec[datarecord.sectioncatogory][2][i];
    //row2["doc3"]= docSec[datarecord.sectioncatogory][3][i];
    data2[i] = row2;
    var source2 =
    localdata: data2,
    datatype: "array"
    //adding data to columns
    var columnsData = [];
    for (var i = 0; i < documentName.length; i++) {
    columnsData.push({ text: documentName[i], datafield:'doc'+i , width: 150 });
    if (tabsdiv != null) {
    tabsdiv.jqxGrid({source: source2, theme: theme, width: 700, height: 200,columns:columnsData});
    //create Parent Grid and call to raw details
    $("#jqxgrid").jqxGrid(
    width: 770,
    height: 450,
    source: source,
    rowdetails: true,
    rowdetailstemplate: { rowdetails: "<div id='grid' style='margin: 10px;'></div>", rowdetailsheight: 220, rowdetailshidden: true },
    ready: function () {
    $("#jqxgrid").jqxGrid('showrowdetails', 1);
    { text: 'Doc Section Name', datafield: 'sectionname', width: 770}
    <div id="jqxgrid"></div>
    NestedGrid- Color cells #9079
    Hello kkasunperera,
    1) In your case, the number of columns in the child grid is equal to the length of the documentName array (2). So, you can use documentName.length to get it. The number of cells in a column is equal to the number of rows in a grid. You can get that number with the following expression (where childGridID is the id of the current child grid):
    $("#childGridID").jqxGrid('getrows').length;
    2) For colouring cells you can use cellsrenderer. Find out more about it here.
    NestedGrid- Color cells #9158
    kkasunperera
    Hi Dimitar
    In the link that you have send you, cellsrenderer is used at the time of the data initialization to columns.
    How can I use cellsrenderer to color the cells after grid displays all the data, i.e in a event of button click?
         //var dataFields stores the datafileds names
    var dataFields=["firstname","lastname","productname","price","quantity","total"];
    $("#colorcellbutton").bind('click', function () {
    //var datarow = generaterow();
    // $("#jqxgrid").jqxGrid('addrow', null, datarow);
    var rowcount= $("#jqxgrid").jqxGrid('getrows').length;
    for(var x=0; x<dataFields.length;x++){
    for(var y=0;y<rowcount;y++){
    var value = $('#jqxgrid').jqxGrid('getcellvalue', y, dataFields[x]);
    //How can I change color of the cell here
    NestedGrid- Color cells #9183
    Hi kkasunperera,
    Using setcolumnproperty when the button is clicked you can set the cellsrenderer function in a moment of time after the creation of the grid. Here is an example:
    <title id='Description'>This example shows how to create a Grid from Array data.
    </title>
    <link rel="stylesheet" href="../../jqwidgets2.4.2/jqwidgets/styles/jqx.base.css"
    type="text/css" />
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxcore.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxdata.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxbuttons.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxscrollbar.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxmenu.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxgrid.js"></script>
    <script type="text/javascript" src="../../jqwidgets2.4.2/jqwidgets/jqxgrid.selection.js"></script>
    var firstNames =
    var lastNames =
    var productNames =
    var priceValues =
    for (var i = 0; i < 100; i++) {
    var row = {};
    row["price"] = price;
    row["quantity"] = quantity;
    data[i] = row;
    localdata: data,
    datatype: "array"
    loadComplete: function (data) { }
    width: 670,
    { text: 'Unit Price', datafield: 'price', width: 90, cellsalign: 'right', cellsformat: 'c2' },
    { text: 'Total', datafield: 'total', width: 100, cellsalign: 'right', cellsformat: 'c2' }
    $("#render").click(function () {
    $("#jqxgrid").jqxGrid('setcolumnproperty', 'firstname', 'cellsrenderer', function (row, columnfield, value, defaulthtml, columnproperties) {
    if (value < 20) {
    return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; color: #0000ff;">' + value + '</span>';
    else {
    <div id="jqxgrid">
    <button id="render">
    Click to colour the cells!</button>
    NestedGrid- Color cells #9325
    kkasunperera
    Hi Dimitar
    Here is my complete code for coloring same like cells in child-grids, when row-details arrow is expanded.
    But I have a small problem. When I shrink the row details arrow, The child grid does not disappear, whats the wrong with my code and how do I overcome this problem?
    docSec[1][0]=[];
    docSec[2][2]= [];
    docSec[3][3]= [];
    var k = 0;
    var row = {};
    data[i] = row;
    k++;
    localdata: data,
    datatype: "array"
    var tabsdiv = null;
    var notes = null;
    var row2 = {};
    row2["doc"+j]="";
    else{
    data2[i] = row2;
    var source2 =
    localdata: data2,
    datatype: "array"
    * Organizing the cell values for coloring
    var rowcount= tabsdiv.jqxGrid('getrows').length;
    var celColor= new Array();
    var dataFields=["doc0","doc1"]; // since size of documentName is ==2 yes this should modify
    var celValue = tabsdiv.jqxGrid('getcellvalue', y, dataFields[x]);
    if(typeof celColor[celValue] == 'undefined'){
    celColor[celValue]= new Array();
    celColor[celValue][0]=[dataFields[x]];
    else{
    function checkContains(element, target){
    var is_found = false;
    for(var i=0;i<celColor[element].length;i++){
    if(celColor[element][i] == target){
    is_found = true;
    break;
    return is_found;
    if(checkContains(celValue,dataFields[x])){
    else{
    var arrLenght=celColor[celValue].length;
    celColor[celValue][arrLenght]=[dataFields[x]];
    //setting the highlight color for the cells
    for(var z=0; z<dataFields.length;z++){
    tabsdiv.jqxGrid('setcolumnproperty', dataFields[z], 'cellsrenderer', function (row, columnfield, value, defaulthtml, columnproperties) {
    if (celColor[value].length==6) {
    //bool=false;
    return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; background: #CC99FF;">' + value + '</span>';
    else if(celColor[value].length==5){
    return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; background: #FF9999;">' + value + '</span>';
    else if(celColor[value].length==4){
    return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; background: #FFFF66;">' + value + '</span>';
    else if(celColor[value].length==3){
    return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; background: #00FF00;">' + value + '</span>';
    else if(celColor[value].length==2){
    return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; background: #CCFFFF;">' + value + '</span>';
    else{
    width: 770,
    height: 450,
    source: source,
    rowdetails: true,
    NestedGrid- Color cells #9334
    Hi kkasunperera,
    The issue comes from the fact that sometimes there may be empty cells, whose value is an empty string (“”). You should check if a cell is empty before you render it, like is shown:
                        for (var z = 0; z < dataFields.length; z++) {
    if (value != "") {
    if (celColor[value].length == 6) {
    //bool=false;
    else if (celColor[value].length == 5) {
    else if (celColor[value].length == 4) {
    else if (celColor[value].length == 3) {
    else if (celColor[value].length == 2) {
    else {
    NestedGrid- Color cells #9340
    kkasunperera
    Thanks Dimitar, I was able to solve the problem, with your inputs.
    Thanks again.
