jQuery UI Widgets Forums Grid nested grid line problem
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 10 years, 6 months ago.
  • nested grid line problem #60984
    mustafa
    hello I did this sample
    http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/index.htm#demos/jqxgrid/nestedgrids.htm
    But the line does not appear
    What is the problem? thank you
    // nested grid
       var nestedDataAdapter = new $.jqx.dataAdapter(nestedSource);
            if (grid != null) {
                grid.jqxGrid({
                    source: nestedDataAdapter, editmode: 'selectedrow', selectionmode: 'singlerow', enabletooltips: true, editable: true, width: '98%', height: 200 ,
    // master grid
     $("#Gd_ExpensesGrid").jqxGrid(
               width: '98%',
               altrows: true,
               height: '500px',
               theme: 'arctic',
               virtualmode: false,
               rowdetailstemplate: { rowdetails: "<div id='grid'></div>", rowdetailsheight: 350, rowdetailshidden: true },
               rowdetails: true,
               editable: false,
               columns: window.Gd_ExpensesGrid.columns,
               showtoolbar: true,
    nested grid line problem #61018
    Hello mustafa,
    The provided code is insufficient for us to determine the source of the issue. Please provide us with your complete JavaScript code, including the script references.
    Please also note that the rowdetails setting "<div id='grid'></div>" is not recommended because that means all nested grids will have the same id and more than one HTML element with the same id is not allowed on the same page.
