jQuery UI Widgets › Forums › Grid › Nested grid data binding issue
Tagged: #jqwidgets-grid, grid, javascript grid, jquery grid, nested grid
This topic contains 1 reply, has 2 voices, and was last updated by Hristo 6 years, 7 months ago.
We are using nested grid functionality. Entire data will be fetched from database only.
Here, we are able to bind 1st table, but not able to bind nested grid data.
We are following jqxgrid’s “nested grid” functionality ==>
https://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/index.htm#demos/jqxgrid/nestedgrids.htmHere, we are going to pass “id” of parent table to child table to bind inner grid. Please find the code below.
var url = “main_data.php”;
{ name: ‘id’, type: ‘int’ },
{ name: ‘name’, type: ‘string’ },
root: ‘ids’,
datatype: ‘json’,
async: false,
url: url
var parentDataAdapter = new $.jqx.dataAdapter(source);
var nesteddetailsurl = “nested_data.php”;
var nestedSource =
{ name: ‘parent_id’, type: ‘int’ },
],root: ‘ids’,
record: ‘id’,
url: nesteddetailsurl,
async: false
};var childDataAdapter = new $.jqx.dataAdapter(nestedSource, { autoBind: true });
c_records = childDataAdapter.records;var nestedGrids = new Array();
var initrowdetails = function (index, parentElement, gridElement, record) {var id = parseInt(record.uid);
var grid = $($(parentElement).children()[0]);
nestedGrids[index] = grid;
var filtervalue = id;
var filtercondition = ‘equal’;
var filter = filtergroup.createfilter(‘numericfilter’, filtervalue, filtercondition);// fill the c_records depending on the id.
var recordsbyid = [];for (var a = 0; a < c_records.length; a++)
var result = filter.evaluate(c_records[a][“id”]);
if (result)
recordsbyid.push(c_records[a]);
}var nestedSource = { datafields: [
// id: ‘id’,
localdata: recordsbyid
var nestedGridAdapter = new $.jqx.dataAdapter(nestedSource);
if (grid != null)
grid.jqxGrid(
source: nestedGridAdapter, width: 780, height: 100,
{ text: ‘ID’, datafield: ‘id’, width: 200 },
{ text: ‘NAME’, datafield: ‘name’, width: 200 },
}// creage grid
$(“#data_grid”).jqxGrid(
width: ‘70%’,
height: ‘50%’,
source: source,
rowdetails: true,
rowsheight: 30,
rowdetailstemplate: { rowdetails: “<div id=’grid’ style=’margin: 10px;’></div>”, rowdetailsheight: 120, rowdetailshidden: true },
{ text: ‘ID’, datafield: ‘id’, width: 100 },
});Hello jumpstart,
Is there any error message in the console?
Could you clarify it?Also, I would like to suggest you look at this topic, that could be helpful:
https://www.jqwidgets.com/community/topic/multi-level-nested-grid/Best Regards,
Hristo HristovjQWidgets team
