jQuery UI Widgets Forums Grid Need help mapping jason
This topic contains 9 replies, has 2 voices, and was last updated by  delebash 12 years, 6 months ago.
  • Need help mapping jason #8054
    delebash
    Trying to create a data adapter from jason url request
    Here is the response which is valid jason according to jasonlint. Any help would be appreciated. Thanks
    {"__entityModel":"People","__COUNT":3,"__SENT":3,"__FIRST":0,"__ENTITIES":[{"__KEY":"27","__STAMP":11,"ID":27,"firstName":"dan","lastName":"qqqq"},{"__KEY":"26","__STAMP":14,"ID":26,"firstName":"dan","lastName":"rrrr"},{"__KEY":"25","__STAMP":13,"ID":25,"firstName":"dan","lastName":"eeee"}]}
    root: "__KEY",
    { name: 'firstName' },
    { name: 'LastName' }
    url: "http://127.0.0.1:8081/rest/People"
    $("#jqxgrid").jqxGrid(
    width: 670,
    { text: 'First Name', datafield: 'firstName', width: 200 },
    { text: 'Last Name', datafield: 'lastName', width: 170 }
    Need help mapping jason #8072
    Hi delebash,
    I think that the root should be set to “__ENTITIES”.
    Hope this helps.
    Need help mapping jason #8075
    delebash
    Thanks I’ve tried that and still not getting data, not sure what else to look at. jsonlint shows __Entities as the outer container and the __Key as the first field in each record but still not getting it to work. Thanks.
    Need help mapping jason #8076
    Hi delebash,
    Here’s a working demo based on your code: http://jsfiddle.net/jqwidgets/ctvE8/
    The code is:
    var data = [{
    "__entityModel": "People",
    "__COUNT": 3,
    "__SENT": 3,
    "__FIRST": 0,
    "__ENTITIES": [{
    "__KEY": "27",
    "__STAMP": 11,
    "ID": 27,
    "firstName": "dan",
    "lastName": "qqqq"},
    "__KEY": "26",
    "__STAMP": 14,
    "ID": 26,
    "firstName": "dan",
    "lastName": "rrrr"},
    "__KEY": "25",
    "__STAMP": 13,
    "ID": 25,
    "firstName": "dan",
    "lastName": "eeee"}]}];
    var source = {
    root: "__ENTITIES",
    localdata: data
    $("#jqxgrid").jqxGrid({
    width: 370,
    text: 'First Name',
    width: 200},
    text: 'Last Name',
    width: 170}
    Need help mapping jason #8077
    delebash
    Thank you very much for the example but I still am not getting data for some reason. The only difference I see is that
    I am using url: “http://127.0.0.1:8081/rest/People” and also not using data: since I no parameters are required for this
    request. Is there a debugger event I can trap to see if the request is going out and what exact data is being returned? I really appreciate you taking the time to help. Thanks, very much!
    In this example the Grid is bound to a Remote Data.
    //var theme = getTheme();
    var source = {
    root: "__ENTITIES",
    width: 370,
    text: 'First Name',
    width: 200},
    text: 'Last Name',
    width: 170}
    Need help mapping jason #8086
    Hi delebash,
    You can use the jqxDataAdapter’s loadComplete and loadError callback functions for debugging purposes. You can read more about them here: jquery-data-adapter.htm.
    Need help mapping jason #8126
    delebash
    Thanks again for helping, I have been hacking away at it but still unable to get the data returned the rest service is
    working at http://ageektech.no-ip.org:8081/rest/People
    I have the events trapped but none of them show any data being returned or any error msg besides “error” I am at
    a loss as to what to check for troubleshooting.
    Thanks again,
    Dan
    var source = {
    root: "__ENTITIES",
    loadComplete: function () {
    alert("loadcomplete")
    var length = dataAdapter.records.length;
    beforeSend: function (jqXHR, settings) {
    alert("before send")
    debugger;
    loadError: function (jqXHR, status, error) {
    debugger;
    alert("load error")
    width: 370,
    text: 'First Name',
    width: 200},
    text: 'Last Name',
    width: 170}
    Need help mapping jason #8148
    Hi delebash,
    I think the data should be formatted like that:
    "__COUNT": 3,
    "__SENT": 3,
    "__FIRST": 0,
    "__ENTITIES": [{
    "__KEY": "27",
    "__STAMP": 11,
    "ID": 27,
    "firstName": "dan",
    "__KEY": "26",
    "__STAMP": 14,
    "ID": 26,
    "firstName": "dan",
    "__KEY": "25",
    "__STAMP": 13,
    "ID": 25,
    "firstName": "dan",
    not:
    "__COUNT": 3,
    "__SENT": 3,
    "__FIRST": 0,
    "__ENTITIES": [{
    "__KEY": "27",
    "__STAMP": 11,
    "ID": 27,
    "firstName": "dan",
    "__KEY": "26",
    "__STAMP": 14,
    "ID": 26,
    "firstName": "dan",
    "__KEY": "25",
    "__STAMP": 13,
    "ID": 25,
    "firstName": "dan",
    I also think you should use JSONP, not JSON in that scenario.
    Example:
    var source = {
    datatype: "jsonp",
    root: "__ENTITIES",
    url: "http://ageektech.no-ip.org:8081/rest/People"
    Need help mapping jason #8179
    delebash
    Thanks Peter,
    I don’t have access to changing the rest data as it is provided by wakanda server which is supposed to output valid jason. I have also tried jasonp but I still get an error call not made with jasonp. Again sorry for the trouble, I am working with wakanda as well to see if they can help. I have tried just a straight jquery ajax rest request and still getting errors. I just don’t know enough about jquery rest to troubleshoot the problem. Thanks again for taking your time to help, greatly appreciated!!
    Need help mapping jason #8189
    delebash
    Peter,
    Thanks for your help the grid is loading now. The problem was a cross-origin policy conflict with wkanda data since it is only
    outputting in json and not jsonp so we created a wrapper call to output it using json bypassing cross-origin policy. Thanks again for
    all your help.
    Dan
