jQuery UI Widgets Forums Grid Multiple row select problem
This topic contains 2 replies, has 2 voices, and was last updated by  davijeb 11 years, 11 months ago.
  • Multiple row select problem #22257
    davijeb
    Blocked
    If I have:
    selectionmode: ‘multiplerowsextended’,
    showfilterrow: true
    then selecting multiple rows will highlight the text in the columns in blue.
    Removing showfilterrow: true fixes this.
    What can I do?
    Jez
    Multiple row select problem #22258
    That is not an issue and is by design. The browser’s selection is enabled by default when the showfilterrow is true. If it was disabled, you will not be able to select text in the Input tags of the Filter Row.
    Multiple row select problem #22263
    davijeb
    Blocked
    Ah ok, understood and makes complete sense. If I did want to prevent this how would I go about it as I believe our users may need this functionality – one line change or more involved?
