jQuery UI Widgets Forums Grid loadstate with filter problem
This topic contains 3 replies, has 4 voices, and was last updated by  Hristo 4 years, 6 months ago.
  • loadstate with filter problem #68077
    Chad Randall
    I have a small problem. When loading a grid state, and there is a filter as “>200”, the filter textbox is loaded with “200” (with GREATER_THAN behind). The filter appears to work fine. But when another filter is changed, the original is now set to “EQUALS”, probably because the textbox was set to “200” instead of “>200”.
    Grid with “Excel” filters on top {showfilterrow: true}
    set filter1 (number) to “>200” (textbox)
    savestate
    loadstate
    filter1 shows up as “200”, but filter is working like GREATER_THAN
    “okay” up to this point, as the correct data is shown
    set filter2 to “X”
    filter1 now works like “EQUAL” 200.
    I did not try this with “<200” or “<>200”, but I suspect the same problem occurs.
    loadstate with filter problem #68114
    Hello Chad Randall,
    We suggest you set the column’s filtertype to ‘number’ and select the filter condition from the dropdown next to the filter input. This way, the issue will not occur.
    loadstate with filter problem #113395
    Singh_kiatec
    Hi Team,
    I am using angular and the load state works perfectly fine with dropdown filter and text but not with the date range . Am i missing something?
    Screen shot
    https://pasteboard.co/JwwSZYe.png
    jqwidgets version : 10.1.5
    Example of state object.
    columns: {levering: {…}, organisation_uuid: {…}, bruger_uuid: {…}, navn: {…}, brugernavn: {…}, …}
    filters:
    filtercondition0: “GREATER_THAN_OR_EQUAL”
    filtercondition1: “LESS_THAN_OR_EQUAL”
    filterdatafield0: “levering”
    filterdatafield1: “levering”
    filteroperator0: 0
    filteroperator1: 0
    filterscount: 2
    filtertype0: “datefilter”
    filtertype1: “datefilter”
    filtervalue0: “20-10-2020 00:00:00”
    filtervalue1: “20-10-2020 23:59:59”
    leveringoperator: “and”
    Thanks in advance.
    loadstate with filter problem #113408
    Hello Singh_kiatec,
    https://stackblitz.com/edit/github-3htnn5?file=src/app/app.component.ts
    https://www.jqwidgets.com
