jQuery UI Widgets Forums Navigation Menu, Context Menu Load jqxMenu data from MySQL problem
This topic contains 2 replies, has 1 voice, and was last updated by  Hop 11 years, 5 months ago.
  • Load jqxMenu data from MySQL problem #30642
    Hop
    I am trying to create a menu widget using data from a mysql database table. I know the response returned is what I am expecting, but I cannot seem to get it to work. The menu widget draws but is blank. I looked for examples for what I am attempting and came up empty.
    I followed the example from demos/jqxmenu/menubindingtojson.htm.
    I would put the code here but I can’t for some reason. I have done it before so I do not know what is wrong. I paste it in ‘code’ tags and only some of it pastes, and even then it doesn’t look the same. Maybe someone could advise me to what I am doing wrong?
    Thank you for your time!
    Load jqxMenu data from MySQL problem #30773
    Hop
    I figured it out I think. I was just posting in code tags in text view while editing.
    menu-fetch.php
    <?php
    #Include the connect.php file
    include('connect.php');
    #Connect to the database
    //connection String
    $connect = mysql_connect($hostname, $username, $password)
    or die('Could not connect: ' . mysql_error());
    //select database
    mysql_select_db($database, $connect);
    //Select The database
    $bool = mysql_select_db($database, $connect);
    if ($bool === False){
    print "can't find $database";
    // get data and store in a json array
    $name = $_GET['name'];
    $query = "SELECT menuid,parentid,subMenuWidth,text FROM menus_cfg where name='".$name."' order by menuid asc";
    $result = mysql_query($query) or die("SQL Error 1: " . mysql_error());
    while ($row = mysql_fetch_array($result, MYSQL_ASSOC)) {
    $menudata[] = array(
    'id' => $row['menuid'],
    'parentid' => $row['parentid'],
    'text' => $row['text'],
    'subMenuWidth' => $row['subMenuWidth'],
    echo json_encode($menudata);
    index.php
    <title id='Description'>In this demo the jqxMenu is built from JSON data.</title>
    <link href="../../styles/hop.budget.css" rel="stylesheet" type="text/css" />
    <link rel="stylesheet" href="../../jqwidgets/styles/jqx.shinyblack.css" type="text/css" />
    <body>
    <div style="position:absolute; top:50px; left:5px" id='jqxWidget'>
    var theme = "shinyblack";
    { name: 'id' },
    { name: 'parentid' },
    { name: 'text' },
    { name: 'subMenuWidth' }
    url: 'menu_fetch.php',
    data: {
    cache: false
    // create data adapter.
    // perform Data Binding.
    dataAdapter.dataBind();
    // get the menu items. The first parameter is the item's id. The second parameter is the parent item's id. The 'items' parameter represents
    // the sub items collection name. Each jqxTree item has a 'label' property, but in the JSON data, we have a 'text' field. The last parameter
    // specifies the mapping between the 'text' and 'label' fields.
    var records = dataAdapter.getRecordsHierarchy('id', 'parentid', 'items', [{ name: 'text', map: 'label'}]);
    $('#jqxWidget').jqxMenu({ source: records, height: '30px', width: '400px', theme:'shinyblack' });
    $("#jqxWidget").on('itemclick', function (event) {
    $("#eventLog").text("Id: " + event.args.id + ", Text: " + $(event.args).text());
    MySQL menu_cfg table (result from query using ‘main_menu’ for ‘name’ field
    SQL result
    Host: localhost
    Database: home
    Generation Time: Oct 15, 2013 at 02:48 PM
    Generated by: phpMyAdmin 4.0.5 / MySQL 5.1.40-community
    SQL query: SELECT * FROM `menus_cfg` LIMIT 0, 200 ;
    Rows: 9
    id menuid parentid subMenuWidth text name
    3 1 -1 NULL HOME main_menu
    4 2 -1 200 File main_menu
    5 3 -1 200 Edit main_menu
    6 4 -1 200 View main_menu
    7 5 -1 200 Tools main_menu
    8 6 -1 200 Windows main_menu
    9 7 -1 200 Help main_menu
    10 10 2 NULL New main_menu
    11 11 10 NULL Account main_menu
    Load jqxMenu data from MySQL problem #30775
    Hop
    This is really killing me, and I am so sorry for the self-answered posts. It’s MAGIC I guess, that I finally post for help here and then I do something I see in stackoverflow and then it works.
    I got it working by adding “async: false,” in the source declaration. Apparently, it matters WHERE it is placed, because I did this already but I added the line after my data field. This time, I put it right after the datatype field and it works now.
    DAYS I labored on this because I didn’t want to post until I exhausted all the options. Thank you Peter for your patience!
    So for those ending up here searching for an answer like I was, adding
    async: false,
    after
    datatype: "JSON",
    fixed this for me using the code I posted above.
    Thank you for your time and patience!!
