jQuery UI Widgets Forums Grid Load Element now showing
This topic contains 7 replies, has 2 voices, and was last updated by  Thiago Arantes 11 years, 11 months ago.
  • Load Element now showing #21208
    I’m trying to make the Load Element appear each time I reaload my grid, but it just doesn’t show.
    I tried to set the showdefaultloadelement and autoshowloadelement properties to true (even though their default value is already true), and also tried the showloadelement method, but nothing works.
    I used 2.8.1 and 2.8.3 versions.
    Any thoughts?
    Load Element now showing #21237
    Hello Thiago Arantes,
    If your grid is small and loads quickly, the load element will not be shown. However, the showloadelement should show it no matter the loading time. Please post a code sample, which we may test locally to determine the source of the issue.
    Load Element now showing #21267
    This is the code I’m trying to make work:
    <title id='Description'>Grid</title>
    <link rel="stylesheet" href="../../jqwidgets/styles/jqx.energyblue.css" type="text/css" />
    <script type="text/javascript" src="../../scripts/jquery-1.9.1.min.js"></script>
    <script type="text/javascript" src="../../jqwidgets/jqxtree.js"></script>
    <script type="text/javascript" src="../../jqwidgets/jqxsplitter.js"></script>
    <script type="text/javascript" src="../../jqwidgets/jqxdata.export.js"></script>
    <script type="text/javascript" src="../../jqwidgets/jqxgrid.export.js"></script>
    <script type="text/javascript" src="../../demos/jqxgrid/generatedata.js"></script>
    <!-- page instructions -->
    var namesColumns = ""; // Selected treeview names that will appear in the grid
    var theme = ""; // Theme CSS du webpart
    // TreeView objects
    var dataTree = null; // Raw source of data
    var sourceTree = null; // Formatted source of data
    var dataAdapterTree = null; // DataAdapter do bound to grid
    var recordsTree = null; // Hierachically sorted version of dataAdapterTree
    // Grid objects
    var dataGrid = null; // Raw source of data
    var sourceGrid = null; // Formatted source of data
    var dataAdapterGrid = null; // DataAdapter do bound to grid
    theme = getDemoTheme();
    dataGrid = generatedata(100); //first load of data
    // Create jqxButtons
    $("#excelExport").jqxButton({ theme: theme });
    $("#refreshGrid").jqxButton({ theme: theme });
    // Create jqxSplitter
    $("#jqxSplitter").jqxSplitter(
    width: '100%',
    height: 615,
    panels:
    { size: 200 }
    // Create jqxTree
    loadTree();
    // Create Handler for Treeview click
    $('#jqxTree').on('select', function (event) {
    // get values from tree and create an array of it
    var e = event.args.element;
    var child = $(e).find(">ul>li");
    var result = event.args.element.id + "|" + child.text();
    result = result.substring(0, result.length - 1)
    /********** Highlight all items under this selected item */
    $(document).find("div.draggable").each(function() {
    $(this).css("background-color", "");
    $(e).find("div.draggable").each(function(index) {
    if ($(this).text() != event.args.element.id + "|") {
    $(this).css("background-color", "#EFEFEF");
    // split string with names into new array and build columns definition
    var arrayNames = result.split("|");
    namesColumns = "";
    for (var i = 0; i < arrayNames.length; i++) {
    namesColumns += "{ text: '" + arrayNames[i] + "', datafield: 'd" + i + "', width: 150, filtertype: 'textbox', filtercondition: 'starts_with' },";
    // Create jqxGrid
    loadGrid(false);
    // Select the first item in the TreeView
    $('#jqxTree').jqxTree('selectItem', $("#jqxTree").find('li:first')[0]);
    // Create Handler for Grid Export to Excel Button
    $("#excelExport").click(function () {
    $("#excelExport").jqxGrid('exportdata', 'xls', 'jqxGrid');
    // Create Handler for Refresh Grid Button
    $("#refreshGrid").click(function () {
    loadGrid(true);
    // load treeview into the page
    function loadTree() {
    dataTree = [{"id":"Item 1","parentid":"-1","text":"Item 1\u003cspan\u003e|\u003c/span\u003e"},{"id":"Item 1.1","parentid":"Item 1","text":"Item 1.1\u003cspan\u003e|\u003c/span\u003e"},{"id":"Item 1.2","parentid":"Item 1","text":"Item 1.2\u003cspan\u003e|\u003c/span\u003e"},{"id":"Item 1.2.1","parentid":"Item 1.2","text":"Item 1.2.1\u003cspan\u003e|\u003c/span\u003e"},{"id":"Item 1.2.2","parentid":"Item 1.2","text":"Item 1.2.2\u003cspan\u003e|\u003c/span\u003e"},{"id":"Item 1.3","parentid":"Item 1","text":"Item 1.3\u003cspan\u003e|\u003c/span\u003e"},{"id":"Item 1.4","parentid":"Item 1","text":"Item 1.4\u003cspan\u003e|\u003c/span\u003e"},{"id":"Item 1.4.1","parentid":"Item 1.4","text":"Item 1.4.1\u003cspan\u003e|\u003c/span\u003e"},{"id":"Item 2","parentid":"-1","text":"Item 2\u003cspan\u003e|\u003c/span\u003e"},{"id":"Item 2.1","parentid":"Item 2","text":"Item 2.1\u003cspan\u003e|\u003c/span\u003e"},{"id":"Item 2.2","parentid":"Item 2","text":"Item 2.2\u003cspan\u003e|\u003c/span\u003e"},{"id":"Item 2.3","parentid":"Item 2","text":"Item 2.3\u003cspan\u003e|\u003c/span\u003e"}]
    sourceTree = {
    { name: 'id' },
    { name: 'parentid' },
    { name: 'text' }
    localdata: dataTree
    //Apply data - Tree
    dataAdapterTree = new $.jqx.dataAdapter(sourceTree);
    dataAdapterTree.dataBind();
    recordsTree = dataAdapterTree.getRecordsHierarchy('id', 'parentid', 'items', [{ name: 'text', map: 'label'}]);
    // Create jqxTree
    $('#jqxTree').jqxTree({ source: recordsTree, height: '100%', width: '100%', theme: theme });
    $('#jqxTree').jqxTree('expandAll');
    // load grid into the page
    function loadGrid(newData) {
    // Load new data only if button refresh is pressed
    if (newData) {
    sourceGrid = {
    localdata: dataGrid,
    datatype: "array",
    { name: 'date', type: 'date' },
    { name: 'price', type: 'number' }
    dataAdapterGrid = new $.jqx.dataAdapter(sourceGrid);
    $('#jqxgrid').jqxGrid('showloadelement'); // Load appears
    // Create jqxGrid
    eval(defineGrid(namesColumns));
    $('#jqxgrid').jqxGrid('hideloadelement'); // Load disappears
    // define how the grid will be loaded into the page
    function defineGrid(namesColumns) {
    var command = "";
    command += "$('#jqxgrid').jqxGrid("
    command += "{";
    command += " width: 1053,";
    command += " height: 615,";
    command += " source: dataAdapterGrid,";
    command += " showfilterrow: true,";
    command += " filterable: true,";
    command += " theme: theme,";
    command += " columnsresize: true,";
    command += " sortable: true,";
    command += " columns: [";
    command += " { text: 'First Name', datafield: 'firstname', width: 150, filtertype: 'textbox', filtercondition: 'starts_with', pinned: true },";
    command += " { text: 'Last Name', datafield: 'lastname', width: 150, filtertype: 'textbox', filtercondition: 'starts_with', pinned: true },";
    command += namesColumns;
    command += " { text: 'Product', datafield: 'productname', width: 250, filtertype: 'textbox', filtercondition: 'starts_with' },";
    command += " { text: 'Available', datafield: 'available', columntype: 'checkbox', width: 67, cellsalign: 'center', align: 'center', filtertype: 'bool' },";
    command += " { text: 'Ship Date', datafield: 'date', width: 150, align: 'right', cellsalign: 'right', cellsformat: 'd', filtertype: 'date' },";
    command += " { text: 'Quantity', datafield: 'quantity', width: 100, align: 'right', cellsalign: 'right', filtertype: 'number' },";
    command += " { text: 'Price', datafield: 'price', width: 150, cellsalign: 'right', align: 'right', cellsformat: 'c2', filtertype: 'number' }";
    command += " ]";
    command += "});";
    return command;
    <style>
    div.jqx-tree-item span {
    display:none;
    div.saveButton {
    float: right;
    padding-bottom: 10px;
    </style>
    <body>
    <div id="container">
    <div class="saveButton">
    <input type="button" value="Refresh Grid" id='refreshGrid' />
    <input type="button" value="Export Grid to Excel" id='excelExport' />
    <div id="jqxSplitter">
    <div style="border: none;" id='jqxTree'></div>
    <div id="jqxgrid"></div>
    Load Element now showing #21313
    Hi Thiago Arantes,
    Here is a small modification to your code:
    // Create jqxGrid
    to:
    setTimeout(function () {
    }, 300);
    Load Element now showing #21557
    Thanks Dimitar,
    So, for now, there’s no way to make the load appear when the grid is actually loading, right?
    Let’s wait for a future update on that, but for now I think this trick would work.
    Thanks again!
    Load Element now showing #21589
    Hi Thiago Arantes,
    This is not an issue, the load element would show if the grid needed more time to load. It is not purely cosmetic, it shows during the loading time. If your grid loads within milliseconds, the load element will not be seen.
    Load Element now showing #22538
    Hi Dimitar,
    Maybe it is something I’ve been doing wrong, then, because I never see the loading message, even when my grid takes 5 seconds (or even more) to load.
    Since all related parameters are set by default for it to appear, in my opinion this should work.
    Load Element now showing #22788
    I’ve found a way to make it work:
    // Waits .5 seconds before starting the process for the load image to be able to appear...
    setTimeout(function() {
    //loadgrid function
    }, 500);
    What this code does it delaying the grid load for half a second in other for the loading image to be able to appear.
