This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 4 months ago.
  • LinkButton & Theme problem #31490
    alme
    if I create a LinkButton like this
    $("#button_go").jqxLinkButton({ width: '100', height: '30', disabled: false, theme: 'energyblue' });
    everything works fine, but if I create it disabled and later I enable it, it doesn’t get the Theme css.
    Example:
    $("#button_go").jqxLinkButton({ width: '100', height: '30', disabled: true, theme: 'energyblue' });
    $('#button_go').jqxButton({disabled: false });
    <div style="margin-top: 30px;">
    <a style='margin-left: 25px;' target="_blank" href="http://www.jqwidgets.com" id='button_go'>Go</a>
    LinkButton & Theme problem #31505
    Hi alme,
    If you initialize it like a LinkButton, then you should set its properties like a LinkButton. I mean that $(‘#button_go’).jqxButton({disabled: false }); should be: $(‘#button_go’).jqxLinkButton({disabled: false });
    LinkButton & Theme problem #31507
    alme
    yes, I tried that also but I got the same result.
    LinkButton & Theme problem #31536
    Hi alme,
    Thanks for the feedback. That would be resolved in the next version.
