jQuery UI Widgets Forums Grid Key/value filter problem with server-side filtering
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 8 years, 11 months ago.
  • ettemlevest
    I have a server-side filtering (paging, sorting) grid that has a Key/value column. It’s a status field that gets values from the database and on the client side the browser translates the key values to human readable text. I have to translate the label field to various languages. I used the example from the grid-list-filter-with-key-value-column.htm demo file. The displaying works fine but when it comes to filtering there’s a problem. When I filter the status column the grid sends wrong data (filterdatafield0) to the server.
    Status source and dataadapter:
    var statuses = [
     { value: 'vacant', label: 'Vacant' },
     { value: 'closed', label: 'Closed' },
     { value: 'under_construction', label: 'Under construction' },
    , statusSource = {
      datatype: 'array',
        { name: 'value', type: 'string' },
        { name: 'label', type: 'string' },
      localdata: statuses
    , statusAdapter = new $.jqx.dataAdapter(statusSource, { autoBind: true });
    Dataadapters datafields:
    { name: 'status', type: 'string' },
    { name: 'statusTranslated', type: 'string', value: 'status', values: { source: statusAdapter.records, value: 'value', name: 'label' },
    Column definition:
      text: 'Status', datafield: 'status', displayfield: 'statusTranslated',
      filtertype: 'list', filteritems: new $.jqx.dataAdapter(statusSource),
      createfilterwidget: function (column, htmlElement, editor) {
        editor.jqxDropDownList({ displayMember: 'label', valueMember: 'value' });
    Example post data sent to the server:
    statusTranslatedoperator and
    filtervalue0             Vacant
    filterid0                vacant
    filtercondition0         EQUAL
    filteroperator0          1
    filterdatafield0         statusTranslated
    filterscount             1
    groupscount              0
    pagenum                  0
    pagesize                 100
    recordstartindex         0
    recordendindex           100
    In the example demo file there’s a filter event listener when I apply it to my grid this is the created data object:
    filterid0        vacant
    filteroperator0  1
    filtervalue0     Vacant
    statuszoperator  and
    The server gets the displayfield name instead of the datafield. My goals is to send this kind of data to the server:
    statusoperator           and
    filtervalue0             <strong>vacant</strong>
    filteroperator0          1
    filterdatafield0         <strong>status</strong>
    filterscount             1
    groupscount              0
    pagenum                  0
    pagesize                 100
    recordstartindex         0
    recordendindex           100
    Is there something that I missed? How can I achieve that the post data contain the status as filterdatafield and the key value as filtervalue?
    The filterdatafield is always the column’s data field or the display field if it’s different from the data field. By using the adapter’s formatData callback function, you can send additional params if you wish.
