jQuery UI Widgets Forums Lists DropDownList Keyboard navigation does not work completly
This topic contains 3 replies, has 4 voices, and was last updated by  alexsmith0007 5 years, 4 months ago.
  • I have tried to use Keyboard navigiation for jqxDropDownList in the way you have shown on your demo page. Unfortunately it is not possible to open a drop down list by using the ENTER key as you have documented. It does not work in my own application (jqxwidgets Version 3.3.0), but it does not work on your demo page too! (I have tested with IE 11 and FF 31.0).
    Is it possible to supply some fix or workaround?
    Thanks in advance!
    Hi flemming,
    Alt+Arrow Down opens the Popup. You can use this. Otherwise, you may open it through the “open” method.
    shivk
    I have another issue related to the same control. Using keyboard navigation, just traversing via up/down arrow triggers select event and hence long queue of events are created in back end that causes application hang or crash.
    Does this control have any way of keyboard navigation that does not trigger select event unless user press Enter.
    alexsmith0007
    Thank you so much for sharing such superb information’s with us. Your website is very cool. we are impressed by the details that you have on your site.we Bookmarked this website. keep it up and again thanks
