jQuery UI Widgets Forums Editors Editor jqxvalidation is not working for jqxeditor
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 9 years, 3 months ago.
  • prianch
    i am using jqxeditor, jqxvalidation , jqxtooltip, jqxgrip and jqxtabs all together
    for jqxeditor jqxvalidation is not working properly.
    it gives error when I left editor empty but when we try to add text like “test” it gives error :- Error: Syntax error, unrecognized expression: test<br>
    following is my code:-
    // version 1.1
    $ = jQuery.noConflict();
        // show the grid for email Template
        loadGridForEmailTemplates();
        // load add button
    	createAddButtons();
        // create window popup for add and Edit
    	createWindowPopupforAdd();
    	createWindowPopupforEdit();
    // tooltip function starts
    function loadTooltipForBothAddAndEditform() {
        $(".TypeTooltip").jqxTooltip({
            content: '<p align=left>Select the type of message you want to create.<BR>A brief explanation will appear bellow upon selecting one.</p>',
            position: 'mouse',
            position: 'right',
            autoHideDelay: '30000'
        $(".DaysTooltip").jqxTooltip({
            content: '<p align=left>Number of days to wait after the order has been paid to send this message.</p>',
            position: 'mouse',
            position: 'right',
        $(".UserTooltip").jqxTooltip({
            content: '<p align=left>Makes this template available to the Customers of this Seller Id.</p>',
            position: 'mouse',
            position: 'right',
        $(".htmlTooltip").jqxTooltip({
            content: '<p align=left>The core message send to the Buyer.<BR>This can be plain text or HTML.</p>',
            position: 'mouse',
            position: 'right',
        $(".EnableTooltip").jqxTooltip({
            content: '<p align=left>Please enable or disable this message template.<BR>A disabled message is ignored by the application.</p>',
            position: 'mouse',
            position: 'right',
        $(".SubjectTooltip").jqxTooltip({
            content: '<p align=left>The Subject of the message.</p>',
            position: 'mouse',
            position: 'right',
        $(".BccTooltip").jqxTooltip({
            content: '<p align=left>Select BCC yes if you want to send email.</p>',
            position: 'mouse',
            position: 'right',
    // function to show explation
    function loadExplanationTextAccToTypeSelectedInAddForm() {
        // show the explanation on elect of the type fro Add form
        $("#SystemUserEmailTemplateType").change(function() {
                url: "/ebays/fetchTypeDetailajax",
                type: "POST",
                cache: false,
                async: true,
                data: {
                    Type: $("#SystemUserEmailTemplateType option:selected").val(),
                dataType: "json",
                success: function(response) {
                    // response is JSON
                    if (response[0] != undefined) {
                        $('.displayExplanation').css('visibility', 'visible');
                        $('.displayExp').html(response[0].Explanation);
                    } else {
                        $('.displayExplanation').css('visibility', 'hidden');
        // show the explanation on elect of the type for Edit form
        $("#Type").change(function() {
                type: "POST",
                cache: false,
                async: true,
                data: {
                    Type: $("#Type option:selected").val(),
                dataType: "json",
                    // response is JSON
                    } else {
    // end function
    // function to load the text prefilled
    function DisableTabInAddIfTabNotSelected(){
    	// if the type is nt selected we will disabled the other tabs.
    	if ($('#SystemUserEmailTemplateType').val() == 0) {
    		var check = $('#addtemplateForm').jqxValidator('validate'); // adding validation in add form
    		$('#jqxTabsAdd').jqxTabs({
    			disabled: true
    		}); // disabled tab
    	$('#SystemUserEmailTemplateType').on('change', function(event) {
    				disabled: true
    			}); // disabled tab
    		} else {
    				disabled: false
    			}); // enabled tab on select of the type
    function loadSubjectBodyWithPrefilledtextInAdd() {
        // the Tab Contents will be loaded with Ajax
        $('#jqxTabsAdd').on('selected', function(event) {
            var pageIndex = event.args.item + 1;
            if (pageIndex == 2) {
                    url: "/ebays/prefilledcontentajax",
                    type: "POST",
                    cache: false,
                    async: true,
                    data: {
                        Type: $("#SystemUserEmailTemplateType").val(),
                    dataType: "json",
                        // response is JSON
                            if (response[0].Subject != undefined) {
                                $("#SystemUserEmailTemplateSubject").val(response[0].Subject);
                            if (response[0].PlainTextBody != undefined) {
                                $("#SystemUserEmailTemplatePlainTextBody").val(response[0].PlainTextBody);
                        } else {
                            $("#SystemUserEmailTemplateSubject").val('');
                            $("#SystemUserEmailTemplatePlainTextBody").val('');
    // end function to load prefilled value
    // function that will save value during add
    function addEventForSaveValueUsingAjax() {
        $(".addtemplate").click(function(event) {
    		if ($('#SystemUserEmailTemplateSubject').val() == "") {
    			alert("You haven't filled the Subject field.");
    			return false;
            event.preventDefault(); //If this method is called, the default action of the event will not be triggered.
            if (check === true) {
                showloader(); // to disable button and show loader image
                var EmailTemplateType = $('#SystemUserEmailTemplateType').val();
                var Subject = $('#SystemUserEmailTemplateSubject').val();
                var PlainTextBody = $('#SystemUserEmailTemplatePlainTextBody').val();
                var ebayuser = $('#ebayuser').val();
                var Enable = $('#SystemUserEmailTemplateEnable').val();
                var WaitForDays = $('#SystemUserEmailTemplateWaitForDays').val();
                var Bcc = $('#SystemUserEmailTemplateBcc').val();
                    url: "/ebays/addemailtemplateajax",
                    type: "POST",
                    cache: false,
                    async: true,
                    data: {
                        Type: EmailTemplateType,
                        Subject: Subject,
                        PlainTextBody: PlainTextBody,
                        UserPlateformId: ebayuser,
                        Enable: Enable,
                        Bcc: Bcc,
                        WaitForDays: WaitForDays,
                        if ($.trim(response) == "success") {
    					 	closePopUp();
                            var action = 'add';
                            showbuttons(); // function created in function.js file to show button enabled and hide loader
                            gridmessage(action);
                            $('#jqxgrid').jqxGrid('updatebounddata');
                        }else{
    						alert('Something went wrong.Please try again');
    						closePopUp();
                $("#addtemplateForm").submit(function() {
                    return false;
            } else {
                showbuttons();
    //end add function
    // function to load validation
    function loadValidatorsForEditForm() {
        $('#edittemplateForm').jqxValidator({
            rules: [{
    				input: '#PlainTextBody',
    				message: 'Html body is required!',
    				action: 'keyup,blur',
    				rule: function(input, commit) {
    					var editorValue = $.trim($(input.val()).text());
    					alert(editorValue);
    					if (editorValue === "" || editorValue === '') {
    						return false;
    					} else {
    						return true;
    				input: '#Subject',
    				message: 'Subject is required!',
    				action: 'blur',
    				rule: 'required'
    function loadValidatorsForAddForm(){
        $('#addtemplateForm').jqxValidator({
            rules: [{
                        input: '#SystemUserEmailTemplatePlainTextBody',
                        action: 'keyup, blur',
                            var editorValue1 = $.trim($(input.val()).text());
                            if (editorValue1 === "" || editorValue1 === '') {
    							alert('ddd');
                                return false;
                            } else {
    							alert('eeee');
                                return true;
                input: '#SystemUserEmailTemplateType',
                message: 'Please select a message type.',
                    var type = $("#SystemUserEmailTemplateType").val();
                    if (type != 0) {
                        return true;
                    return false;
                input: '#SystemUserEmailTemplateSubject',
                rule: 'required'
    //end validation function
    // function to edit function
    function loadEditFormWithSavedValues(columnindex, rowindex) {
    		//when user wants to edit the record
            $('#jqxTabsEdit').jqxTabs('select', 0);
            editrow = rowindex;
            var offset = $("#jqxgrid").offset();
            // get the clicked row's data and initialize the input fields.
            var dataRecord = $("#jqxgrid").jqxGrid('getrowdata', editrow);
            $("#Subject").val(dataRecord.Subject);
            $("#Type").val(dataRecord.TypeId);
            $("#Enable").val(dataRecord.Enable);
            $("#WaitForDays").val(dataRecord.WaitForDays);
            $("#Bcc").val(dataRecord.Bcc);
    		$("#UserPlateformId").val(dataRecord.UserPlateformId);
            if (($("#PlainTextBody").val() == "") && (dataRecord.PlainTextBody != "")) { // after page loads
                $("#PlainTextBody").html(dataRecord.PlainTextBody);
            } else {
                $("#PlainTextBody").jqxEditor('val', dataRecord.PlainTextBody);
    // function to delete function
    function deleteSelectedRecord(columnindex, rowindex) {
        // if user click want to delete record
    	if (confirm('Are you sure you want to delete this record?')) {
    		deleterow = rowindex;
    		var rowID = $('#jqxgrid').jqxGrid('getrowid', deleterow); // fetch the deleted id
    		var del = "param=delete&Id=" + rowID;
    			url: '/ebays/deleteemailtemplateajax',
    			data: del,
    			type: "POST",
    			cache: false,
    			async: false,
    				var res = response.match(/success/g);
    				if (response.replace(/\s+/, "") == res) {
    					var action = "delete";
    					gridmessage(action); //function called to disaply me
    // end function
    // function for edit functionality
    function updateRecordAjax() {
        // update the edited row when the user clicks the 'Update' button.
        $(".Saverecord").click(function(event) {
    		if($("#Subject").val()===""){
            var checkedit = $('#edittemplateForm').jqxValidator('validate'); // adding validation in add form
            if (checkedit == true) {
                var rowID = $('#jqxgrid').jqxGrid('getrowid', editrow);
                var row = {
                    Subject: $("#Subject").val(),
                    Type: $("#Type").val(),
                    PlainTextBody: $("#PlainTextBody").val(),
                    UserPlateformId: $("#UserPlateformId").val(),
                    Enable: $("#Enable").val(),
                    WaitForDays: $("#WaitForDays").val(),
                    Bcc: $("#Bcc").val(),
                // ajax called to UPDATE the row on edit
                    url: "/ebays/updateemailtemplateajax",
                    type: "POST",
                    cache: false,
                    async: true,
                    data: row,
                            var action = 'edit';
    						closePopUp();
                        }else{
    						closePopUp();
                $("form").submit(function() {
                    return false;
            } else {
                showbuttons();
    // function to load grid
    function loadGridForEmailTemplates() {
        var url = "/ebays/emailtemplatejson"; // action from where we get the result in json
        var source = {
            datafields: [{
                type: 'string',
                map: 'SystemUserEmailTemplate>Subject'
                type: 'string',
                map: 'SystemEmailTemplateType>Type'
                type: 'string',
                map: 'SystemEmailTemplateType>TypeDisplay'
                type: 'string',
                map: 'SystemUserEmailTemplate>PlainTextBody'
                type: 'string',
                map: 'SystemUserEmailTemplate>UserPlateformId'
                type: 'string',
                map: 'SystemUserEmailTemplate>Type'
                type: 'string',
                map: 'SystemUserEmailTemplate>Enable'
                type: 'string',
                map: 'SystemUserEmailTemplate>Explanation'
                type: 'string',
                map: 'SystemUserEmailTemplate>Bcc'
                type: 'int',
                map: 'SystemUserEmailTemplate>WaitForDays'
            updaterow: function(rowid, rowdata, commit) {
            url: url,
            pagesize: 30
        var cellsrenderer = function(row, columnfield, value, defaulthtml, columnproperties) {
            if (value == "1") {
                return "yes";
            } else if (value == "0") {
                return "No";
        var editrow = -1;
        // initialize jqxGrid
        $("#jqxgrid").jqxGrid({
            width: '100%',
            theme: KiouiTheme,
            height: 350,
            altrows: true,
            enabletooltips: true,
            pagesizeoptions: ['10', '20', '30', '40'],
            showfilterrow: true,
            showtoolbar: false,
            enablebrowserselection: true,
            selectionmode: 'singlecell',
            // columns shown in grid are mention below
            columns: [{
                text: '',
                datafield: 'Edit',
                columntype: 'number',
                filterable: false,
                sortable: false,
                width: '5%',
                cellsrenderer: function() {
                    return '<div style="width: 100%"><img src="/images/edit.png" title="Edit" style=" margin-top: 10%;margin-left: 25%" /></div>';
                text: 'Type',
                datafield: 'TypeDisplay',
                width: '35%',
                filtertype: 'checkedlist'
                text: 'Subject',
                datafield: 'Subject',
                width: '35%'
                text: "User",
                datafield: 'UserPlateformId',
                width: '10%'
                text: "Bcc",
                datafield: 'Bcc',
                width: '5%',
                cellsrenderer: cellsrenderer,
                text: "Enable",
                datafield: 'Enable',
                width: '5%',
                text: '',
                datafield: 'Delete',
                filterable: false,
                sortable: false,
                width: '5%',
                    return '<div><img src="/images/trash.png"  title="Delete" style="margin-top:10%;margin-left:25%" /></div>';
        // on click of edit and delete
        $("#jqxgrid").on("cellclick", function(event) {
            var column = event.args.column;
            var rowindex = event.args.rowindex;
            var columnindex = event.args.columnindex;
    		if (columnindex == 0) {
    			loadEditTabForEmailTemplate();
    			loadValidatorsForEditForm();
    			loadTooltipForBothAddAndEditform();
    			loadEditFormWithSavedValues(columnindex, rowindex);
    			// show the popup window.
                		$("#EditPopupWindow").jqxWindow('show');
    		if (columnindex == 6) {
    			deleteSelectedRecord(columnindex, rowindex);
    // function load tab for add functionality
    function loadAddTabForEmailTemplate() {
    		//width: "600px",
            initTabContent: function(tab) {
                switch (tab) {
                    case 0:
                        // called ajax to save the data on click of "add template"
                        addEventForSaveValueUsingAjax();
                        break;
                    case 1:
                        $("#SystemUserEmailTemplatePlainTextBody").jqxEditor({
                            height: '440px',
                            width: '650px'
                        break;
        }); // adding tabS
    function loadEditTabForEmailTemplate() {
        $('#jqxTabsEdit').jqxTabs({
    		//width: "600px",
                switch (tab) {
                    case 0:
                        	$("#Type").prop("disabled", true);
                        	updateRecordAjax();
                        	break;
    		case 1:
    			$("#PlainTextBody").jqxEditor({
    				height: '440px',
    				width: '650px'
    			break;
        }); // adding tabs
    	function closePopUp(){
    		$('#AddPopupWindow').jqxWindow('close');
    		$('#EditPopupWindow').jqxWindow('close');
    		$('#jqxTabsAdd').jqxTabs('select', 0);
        //Adding event listeners
        function openPopupForAddButton() {
            $('#addrowbutton1').click(function() {
    		loadAddTabForEmailTemplate();
                	$('#SystemUserEmailTemplateSubject').val('');
                	$('#SystemUserEmailTemplatePlainTextBody').val('');
                	$('#ebayuser').val('All');
                	$('#SystemUserEmailTemplateWaitForDays').val('0');
                	$('#SystemUserEmailTemplateType').val('0');
    		loadValidatorsForAddForm();
    		DisableTabInAddIfTabNotSelected();
    		loadSubjectBodyWithPrefilledtextInAdd();
    		loadExplanationTextAccToTypeSelectedInAddForm();
    		$('#AddPopupWindow').jqxWindow('open'); // to open the window onclick of open button
        //Creating all page elements which are jqxWidgets
        function createAddButtons() {
            $('#addrowbutton1').jqxButton({
                width: '70px',
                theme: KiouiTheme
    		$('.addtemplate').jqxButton({
                width: '70px',
                theme: KiouiTheme
    		$('.CloseButtonEditWindow').jqxButton({
                width: '70px',
                theme: KiouiTheme
    		$('.Saverecord').jqxButton({
                width: '70px',
                theme: KiouiTheme
    		$('.CloseButtonAddWindow').jqxButton({
                width: '70px',
                theme: KiouiTheme
    	openPopupForAddButton();
        //Creating the window
        function createWindowPopupforAdd() {
            $('#AddPopupWindow').jqxWindow({
                	theme: KiouiTheme,
                	isModal: true,
    				modalOpacity: 0.3,
    				cancelButton: $(".CloseButtonAddWindow"),
                	height: 850,
                	width: 850,
                	resizable: false,
                	autoOpen: false,
                	initContent: function() {
                    	$('#AddPopupWindow').jqxWindow('focus');
    	$('.CloseButtonAddWindow').mouseup(function() {
    		closePopUp();
    	$('#AddPopupWindow').on('close', function (event) {
     function createWindowPopupforEdit() {
            // initialize the edit pop up window.
            $("#EditPopupWindow").jqxWindow({
                resizable: false,
                isModal: true,
                autoOpen: false,
                cancelButton: $(".CloseButtonEditWindow"),
                modalOpacity: 0.3,
                theme: KiouiTheme,
                height: 850,
                width: 850,
            $('.CloseButtonEditWindow').mouseup(function() {
    		closePopUp();
    	$('#EditPopupWindow').on('close', function (event) {
        //            closePopUp();
    <div id=”AddPopupWindow”>
    <div id=”windowHeader”>
    <span>Add Email Template </span>
    <div id=”jqxTabsAdd”>
    <!– ul li to create tabs–>
      <li style=”margin-left: 30px;”>Details
    • Message
    • Rules
    <div style=”overflow: hidden;” ><!– detail tab–>
    <table cellspacing=”0″ class=”grey-layout”>
    <tr>
    <td style=”padding:10px”>
    <table cellspacing=”0″ class=”content-space”>
    <!–Email Template form start here–>
    <form accept-charset=”utf-8″ method=”post” id=”addtemplateForm” action=””>
    <tr>
    <td>
    Type:
    </td>
    <td>
    <select id=”SystemUserEmailTemplateType” class=”typeajax”>
    <option value=”0″>Notification</option>
    <option value=”2″>test</option>
    <option value=”13″>testingg</option>
    </select>
    </td>
    <td></td>
    </tr>
    <tr>
    <td style=”height:5px;line-height:5px;” colspan=”2″> </td>
    </tr>
    <tr>
    <td>
    Enable:
    </td>
    <td>
    <select id=”SystemUserEmailTemplateEnable”>
    <option value=”0″>No</option>
    <option value=”1″>Yes</option>
    </select>
    </td>
    <td></td>
    </tr>
    <tr>
    </td>
    </tr>
    <tr>
    <td colspan=”2″>
    <input type=”submit” value=”Add” class=”addtemplate”/>
    <input type=”button” value=”Close” class=”CloseButtonAddWindow”/>
    </td>
    </tr>
    </form>
    <!–Email Template form ends here–>
    </table>
    </td>
    </tr>
    </table>
    <div style=”visibility: hidden;margin-left: 20px;margin-top: 20px;” class=”displayExplanation” >
    <div class=”displayExp” >
    <div style=”overflow: hidden;”> <!– message tab –>
    <table>
    <tr>
    <td>Subject:</td>
    <td>
    <input type=”text” id=”SystemUserEmailTemplateSubject”/>
    </td>
    <td></td>
    </tr>
    <tr>
    </td>
    </tr>
    <tr>
    <td>Body:</td>
    <td>
    <textarea id=”SystemUserEmailTemplatePlainTextBody”></textarea >
    </td>
    <td></td>
    </tr>
    <tr>
    </td>
    </tr>
    <tr>
    <td colspan=”2″>
    </td>
    </tr>
    </form>
    </table>
    <div style=”overflow: hidden;” > <!– rule tab –>
    <table>
    <tr>
    <td> User:</td>
    <td>
    <select id=”ebayuser” class=”ebayuser SystemUserEmailTemplateUserPlateformId” name=”data[SystemUserEmailTemplate][UserPlateformId]”>
    <option value=”All”>All</option>
    <option value=”testingg”>testingg</option>
    </select>
    </td>
    <td></td>
    </tr>
    <tr>
    </td>
    </tr>
    <tr>
    <td>Wait for Days :</td>
    <td>
    <select id=”SystemUserEmailTemplateWaitForDays”>
    <option value=”0″>0 Day</option>
    <option value=”1″>1 Day</option>
    <option value=”2″>2 Days</option>
    <option value=”3″>3 Days</option>
    <option value=”4″>4 Days</option>
    <option value=”5″>5 Days</option>
    <option value=”6″>6 Days</option>
    <option value=”7″>7 Days</option>
    <option value=”8″>8 Days</option>
    <option value=”9″>9 Days</option>
    <option value=”10″>10 Days</option>
    <option value=”11″>11 Days</option>
    <option value=”12″>12 Days</option>
    <option value=”13″>13 Days</option>
    <option value=”14″>14 Days</option>
    <option value=”15″>15 Days</option>
    <option value=”16″>16 Days</option>
    <option value=”17″>17 Days</option>
    <option value=”18″>18 Days</option>
    <option value=”19″>19 Days</option>
    <option value=”20″>20 Days</option>
    <option value=”21″>21 Days</option>
    <option value=”22″>22 Days</option>
    <option value=”23″>23 Days</option>
    <option value=”24″>24 Days</option>
    <option value=”25″>25 Days</option>
    <option value=”26″>26 Days</option>
    <option value=”27″>27 Days</option>
    <option value=”28″>28 Days</option>
    <option value=”29″>29 Days</option>
    <option value=”30″>30 Days</option>
    <option value=”31″>31 Days</option>
    </select>
    </td>
    <td></td>
    </tr>
    <tr>
    </td>
    </tr>
    <tr>
    <td>Bcc me:</td>
    <td>
    <select id=”SystemUserEmailTemplateBcc”>
    </select>
    </td>
    <td></td>
    </tr>
    <tr>
    </td>
    </tr>
    <tr>
    <td colspan=”2″>
    <input type=”submit” value=”Add” class=”addtemplate”/>  <input type=”button” value=”Close” class=”CloseButtonAddWindow”/>
    </td>
    </tr>
    </form>
    </table>
    i even tried to create fiddle for this but it is to complicated to create it. your help will be appriciated
    Hello prianch,
    Your code is too extensive for us to test or review. Please share where exactly in your code the error is thrown. Please also take a look at the following clarification regarding the validation of jqxEditor: http://www.jqwidgets.com/community/topic/validate-jqxeditor/#post-73484.
