jQuery UI Widgets › Forums › Navigation › Tree › jqxTree-updateItem-method not work!
Tagged: icon, javascript tree, javascript treeview, jqxtree, Tree, treeview control, updateItem
This topic contains 9 replies, has 6 voices, and was last updated by Dimitar 8 years, 3 months ago.
I want to make the selectedItem’s label to change automatically when I update it on server.
submitUpdate:function(){ var url=rootPath+"Org?action=update"; var postData={"id":viewModel.instit_id(),"name":viewModel.newName()}; $.post(url,postData,function(data){ if(data="true"){ var selectedItem = tree.jqxTree('getSelectedItem'); alert(selectedItem.value+" - - - "+selectedItem.label); tree.jqxTree('updateItem', selectedItem.element, {label:'MLGB c'}); tree.jqxTree('render'); } }); }
how to achieve it?
The ‘updateItem’ method was recently added so make sure that you use the latest version if you intend to use it.
Below is a working sample with jQWidgets 2.8.3.
<!DOCTYPE html><html lang="en"><head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript" src="../../scripts/jquery-1.8.3.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxtree.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript"> $(document).ready(function () { var theme = getDemoTheme(); // Create jqxTree $('#jqxTree').jqxTree({ height: '400px', width: '300px', theme: theme }); // Create and initialize Buttons $('#Update').jqxButton({ height: '25px', width: '100px', theme: theme }); // Update $('#Update').click(function () { var selectedItem = $('#jqxTree').jqxTree('selectedItem'); if (selectedItem != null) { $('#jqxTree').jqxTree('updateItem', selectedItem.element, { label: 'Item' }); } }); $('#jqxTree').jqxTree('selectItem', $("#jqxTree").find('li:first')[0]); }); </script></head><body class='default'> <div id='jqxWidget'> <div style='float: left;'> <div id='jqxTree' style='float: left; margin-left: 20px;'> <ul> <li id='home'>Home</li> <li item-expanded='true'>Solutions <ul> <li>Education</li> <li>Financial services</li> <li>Government</li> <li>Manufacturing</li> <li>Solutions <ul> <li>Consumer photo and video</li> <li>Mobile</li> <li>Rich Internet applications</li> <li>Technical communication</li> <li>Training and eLearning</li> <li>Web conferencing</li> </ul> </li> <li>All industries and solutions</li> </ul> </li> <li>Products <ul> <li>PC products</li> <li>Mobile products</li> <li>All products</li> </ul> </li> <li>Support <ul> <li>Support home</li> <li>Customer Service</li> <li>Knowledge base</li> <li>Books</li> <li>Training and certification</li> <li>Support programs</li> <li>Forums</li> <li>Documentation</li> <li>Updates</li> </ul> </li> <li>Communities <ul> <li>Designers</li> <li>Developers</li> <li>Educators and students</li> <li>Partners</li> <li>By resource <ul> <li>Labs</li> <li>TV</li> <li>Forums</li> <li>Exchange</li> <li>Blogs</li> <li>Experience Design</li> </ul> </li> </ul> </li> <li>Company <ul> <li>About Us</li> <li>Press</li> <li>Investor Relations</li> <li>Corporate Affairs</li> <li>Careers</li> <li>Showcase</li> <li>Events</li> <li>Contact Us</li> <li>Become an affiliate</li> </ul> </li> </ul> </div> <div style='margin-left: 60px; float: left;'> <div style='margin-top: 10px;'> <input type="button" id='Update' value="Update" /> </div> </div> </div> </div></body></html>
http://www.jqwidgets.com/Hi Peter Stoev
I want change Icon Team. However i used
$(‘#jqxTree’).jqxTree(‘updateItem’, selectedItem.element, {icon: ‘abc.png’ , label: ‘Item’ }); that not working
pls help meHi,
At present, it is possible to update only the item’s text. It will be possible to update the icon in the next version.
http://www.jqwidgets.com/thank you
I am using version 3.4.0. I want to change the label of the node but want to keep the icon same.
$(‘#jqxTree’).jqxTree(‘updateItem’, selectedItem.element, { icon: selectedItem.icon, iconsize: selectedItem.iconsize, label: ‘Item Deactivated’ });
As you mentioned, it will be possible to update the icon in the next version. Just wanted to check with you, has it been made available with version 3.4.0.
Yatin BabariaHello Yatin Babaria,
This functionality works in version 3.4.0.
Thanks for replying. It works as expected.
Yatin BabariaHi,
Is it possible to use updateItem to update the id and parentId of an item?
The reason I need to update the id and parentId is that I am moving elements from one list to another (like in the drag and drop example), and need the moved elements to conform to the destination list.
JonasHi Jonas,
Unfortunately, these ids cannot be updated using the method updateItem.
