jQuery UI Widgets Forums Navigation Tree jqxTree data from,mysql can not work,pls help me!!
This topic contains 4 replies, has 3 voices, and was last updated by  Dimitar 8 years, 2 months ago.
  • Ray
    Hi bro.
    I want to using jqxTree shown menu,I can get data from mysql,but can not work in jqxTree.pls help!!!
    php code:
    public function treedata(){
    $menu=D(‘menu’);
    $list=$menu->select();
    echo json_encode($list);
    result is:
    [{“id”:”1″,”parentid”:”0″,”name”:”Foods”},{“id”:”2″,”parentid”:”1″,”name”:”Fruits”},{“id”:”3″,”parentid”:”1″,”name”:”Vegetables”},{“id”:”4″,”parentid”:”2″,”name”:”apple”}]
    html code:
    // Stuff to do as soon as the DOM is ready;
    $(“#splitter”).jqxSplitter({ width: ‘100%’, height: ‘100%’, panels: [{ size: 250}] });
    $(‘#jqxTree’).jqxTree({ height: ‘100%’, width: ‘100%’,theme:’bootstrap’ });
    $(‘#jqxTree’).css(‘visibility’, ‘visible’);
    //get data
    $(‘#jqxTree’).jqxTree({ source: source, width: ‘100%’, height: ‘100%’});
    $(‘#jqxTree’).jqxTree(‘selectItem’, null);
    type:’POST’,
    url:’http://localhost/phperp/index.php/Home/Index/treedata’,
    alert(data);
    the question is:
    var source =[];
    source=data??? can not work!!!
    Ray
    here is my code:
    <!DOCTYPE HTML PUBLIC “-//W3C//DTD HTML 4.01 Transitional//EN” “http://www.w3.org/TR/html4/loose.dtd”>
    <html lang=”en”>
    <meta http-equiv=”Content-Type” content=”text/html;charset=UTF-8″>
    <title>tree</title>
    <link rel=”stylesheet” href=”<?php echo ADMIN_CSS_URL;?>jqwidgets/styles/jqx.base.css” type=”text/css” />
    <link rel=”stylesheet” href=”<?php echo ADMIN_CSS_URL;?>jqwidgets/styles/jqx.bootstrap.css” type=”text/css” />
    <script type=”text/javascript” src=”<?php echo ADMIN_JS_URL;?>scripts/jquery-1.11.1.min.js”></script>
    <script type=”text/javascript” src=”<?php echo ADMIN_JS_URL;?>scripts/demos.js”></script>
    <script type=”text/javascript” src=”<?php echo ADMIN_JS_URL;?>jqwidgets/jqxcore.js”></script>
    <script type=”text/javascript” src=”<?php echo ADMIN_JS_URL;?>jqwidgets/jqxbuttons.js”></script>
    <script type=”text/javascript” src=”<?php echo ADMIN_JS_URL;?>jqwidgets/jqxscrollbar.js”></script>
    <script type=”text/javascript” src=”<?php echo ADMIN_JS_URL;?>jqwidgets/jqxpanel.js”></script>
    <script type=”text/javascript” src=”<?php echo ADMIN_JS_URL;?>jqwidgets/jqxtree.js”></script>
    <script type=”text/javascript” src=”<?php echo ADMIN_JS_URL;?>qwidgets/jqxexpander.js”></script>
    <script type=”text/javascript” src=”<?php echo ADMIN_JS_URL;?>jqwidgets/jqxsplitter.js”></script>
    <style type=”text/css”>
    html, body
    height: 100%;
    width: 100%;
    margin: 0px;
    padding: 0px;
    overflow: hidden;
    </style>
    { name: ‘id’ },
    { name: ‘parentid’ },
    { name: ‘name’ }
    url: ‘http://localhost/phperp/Home/Index/treedata’,
    async: false
    dataAdapter.dataBind();
    var records = dataAdapter.getRecordsHierarchy(‘id’, ‘parentid’, ‘items’, [{ name: ‘name’, map: ‘label’}]);
    $(‘#jqxTree’).jqxTree({ source: records, width: ‘100%’, height: ‘100%’});
    $(‘#jqxTree’).on(‘select’, function (event) {
    var args = event.args;
    var item = $(‘#jqxTree’).jqxTree(‘getItem’, args.element);
    $(“#ContentPanel”).html(“<div style=’margin: 10px;’>” + item.id + “</div>”);
    <body class=’default’>
    <div id=”splitter”>
    <div>
    <div style=”visibility: hidden; border: none;” id=’jqxTree’>
    <div id=”ContentPanel”>
    Hi Ray,
    Could you, please, remove the following line:
    $(‘#jqxTree’).jqxTree({ height: ’100%’, width: ’100%’,theme:’bootstrap’ });
    and leave only this one:
    $(‘#jqxTree’).jqxTree({ source: records, width: ’100%’, height: ’100%’});
    Does the issue occur afterwards?
    If it has not been resolved, please make sure you are using the latest version of jQWidgets (4.1.2) and share if any errors are thrown in your browser’s console.
    mohammadTaghy
    Hi guys.I have a problem.I want to use of jqxtree with checkBox.I want to bind data with ajax,but in edit mode some checkbox have true value.
    I dont know how I can set value to checkbox.pleas help me.`
    url: url,
    data: “”,
    type: ‘POST’,
    dataType: “json”,
    success: function (json) {
    var result = $.parseJSON(json.d);
    localdata: result
    var records = dataAdapter.getRecordsHierarchy(‘Id’, ‘ParentId’, ‘items’, [{ name: ‘Text’, map: ‘label’ }]);
    $(element).jqxTree({ source: records, hasThreeStates: true, checkboxes: true });
    $(element).on(‘change’, function (event) {
    var checked = event.args.checked;
    $(element).jqxTree({ hasThreeStates: checked });
    $(element).jqxTree(‘selectItem’, $(“#home”)[0]);
