jQuery UI Widgets Forums Navigation Tabs jqxTab headers display issue
This topic contains 2 replies, has 2 voices, and was last updated by  AllanD 11 months, 3 weeks ago.
  • jqxTab headers display issue #134680
    AllanD
    I am using jqxTabs in a jqxWindow. Tabs work as expected if the window is displayed, however, if I add a tab when the window is hidden and then ‘open’ the window the tab headers are not displayed correctly.
    To demonstrate the issue I have added a tab ‘add’ button (consisting of ‘input’ html, jqxButton call and ‘click’ event handler) to the ver16.0.0 Javascript & Jquery windows demo code ‘defaultfunctionality.htm’. If you run demo and press the ‘add’ button a new tab is added correctly. If you ‘close’ the window, add a tab and then open the window the tab headers are not displayed correctly.
    Do you have a fix for this problem?
    AllanD
        <meta name="keywords" content="jQuery Window, Window Widget, Window" />
        <meta name="description" content="The jqxWindow is a floating window which have two main parts - title and content. In the title you can have any html content and close button.
                                          In the content you could put any html content." />
        <title id='Description'>You can use the jqxWindow to direct a user’s attention to a particular activity in your application, such as entering data or viewing information. Consider using a jqxWindow when you want greater customization, you want to block the user interface outside the window, or when you want to retrieve a DialogResult and other data from the popup window. jqxWindow can be displayed as a modal dialog window that blocks user interaction with the underlying user interface or as a standard window without blocking the web page's user interface.</title>
        <link rel="stylesheet" href="../../../jqwidgets/styles/jqx.base.css" type="text/css" />
        <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" />
        <meta name="viewport" content="width=device-width, initial-scale=1 maximum-scale=1 minimum-scale=1" />
        <script type="text/javascript" src="../../../scripts/jquery-1.12.4.min.js"></script>
        <script type="text/javascript" src="../../../jqwidgets/jqxcore.js"></script>
        <script type="text/javascript" src="../../../jqwidgets/jqxwindow.js"></script>
        <script type="text/javascript" src="../../../jqwidgets/jqxbuttons.js"></script>
        <script type="text/javascript" src="../../../jqwidgets/jqxscrollbar.js"></script>
        <script type="text/javascript" src="../../../jqwidgets/jqxpanel.js"></script>
        <script type="text/javascript" src="../../../jqwidgets/jqxtabs.js"></script>
        <script type="text/javascript" src="../../../jqwidgets/jqxcheckbox.js"></script>
        <script type="text/javascript" src="../../../scripts/demos.js"></script>
            var basicDemo = (function () {
                //Adding event listeners
                function _addEventListeners() {
                    $('#resizeCheckBox').on('change', function (event) {
                        if (event.args.checked) {
                            $('#window').jqxWindow('resizable', true);
                        } else {
                            $('#window').jqxWindow('resizable', false);
                    $('#dragCheckBox').on('change', function (event) {
                            $('#window').jqxWindow('draggable', true);
                        } else {
                            $('#window').jqxWindow('draggable', false);
                    $('#showWindowButton').click(function () {
                        $('#window').jqxWindow('open');
                    $('#hideWindowButton').click(function () {
                        $('#window').jqxWindow('close');
    				$('#addWindowButton').click(function() {
    					$('#tab').jqxTabs('addAt', 1, '1', 'tabContent');
                //Creating all page elements which are jqxWidgets
                function _createElements() {
                    $('#showWindowButton').jqxButton({ width: '70px' });
                    $('#hideWindowButton').jqxButton({ width: '65px' });
    				$('#addWindowButton').jqxButton({ width: '65px' });
                    $('#resizeCheckBox').jqxCheckBox({ width: '185px', checked: true });
                    $('#dragCheckBox').jqxCheckBox({ width: '185px', checked: true });
                //Creating the demo window
                function _createWindow() {
                    var jqxWidget = $('#jqxWidget');
                    var offset = jqxWidget.offset();
                    $('#window').jqxWindow({
                        position: { x: offset.left + 50, y: offset.top + 50} ,
                        showCollapseButton: true, maxHeight: 400, maxWidth: 700, minHeight: 200, minWidth: 200, height: 300, width: 500,
                        initContent: function () {
                            $('#tab').jqxTabs({ height: '100%', width:  '100%' });
                            $('#window').jqxWindow('focus');
                return {
                    config: {
                        dragArea: null
                    init: function () {
                        //Creating all jqxWindgets except the window
                        _createElements();
                        //Attaching event listeners
                        _addEventListeners();
                        //Adding jqxWindow
                        _createWindow();
                //Initializing the demo
                basicDemo.init();
        <div id="jqxWidget">
            <div style="float: left;">
                <div>
                    <input type="button" value="Open" id="showWindowButton" />
                    <input type="button" value="Close" id="hideWindowButton" style="margin-left: 5px" />
    				<input type="button" value="Add" id="addWindowButton" style="margin-left: 5px" />
                <div style="margin-top: 10px;">
                    <div id="resizeCheckBox">
                        Resizable
                    <div id="dragCheckBox">
                        Enable drag
            <div style="width: 100%; height: 650px; margin-top: 50px;" id="mainDemoContainer">
                <div id="window">
                    <div id="windowHeader">
                        <span>
                            <img src="../../../images/movie.png" alt="" style="margin-right: 15px" />Movies
                        </span>
                    <div style="overflow: hidden;" id="windowContent">
                        <div id="tab">
                            <ul style="margin-left: 30px;">
                                <li>Avatar</li>
                                <li>End Game</li>
                                <li>Twilight</li>
                                <li>Unstoppable</li>
                                <li>Priest</li>
                            </ul>
                            <div>
                                <img src="../../../images/avatar.png" style="float: left; margin: 10px;" alt="" />
                                Avatar is a 2009 American[6][7] epic science fiction film written and directed by
                                James Cameron, and starring Sam Worthington, Zoe Saldana, Stephen Lang, Michelle
                                Rodriguez, Joel David Moore, Giovanni Ribisi and Sigourney Weaver. The film is set
                                in the mid-22nd century, when humans are mining a precious mineral called unobtanium
                                on Pandora , a lush habitable moon of a gas giant in the Alpha Centauri star system.
                                The expansion of the mining colony threatens the continued existence of a local
                                tribe of Na'vi—a humanoid species indigenous to Pandora. The film's title refers
                                to the genetically engineered Na'vi-human hybrid bodies used by a team of researchers
                                to interact with the natives of Pandora.
                         </div>   <div>
                                <img src="../../../images/endgame.png" style="float: left; margin: 10px;" alt="" />
                                End Game is a 2006 action/thriller film, written and directed by Andy Cheng. The
                                film stars Cuba Gooding, Jr. as Secret Service agent Alex Thomas, who is shot in
                                the hand, while unsuccessfully trying to protect the President (played by Jack Scalia)
                                from an assassin's bullet. Later, with the help of a persistent newspaper reporter
                                named Kate Crawford (played by Angie Harmon), he uncovers a vast conspiracy behind
                                what initially appeared to be a lone gunman. James Woods, Burt Reynolds, and Anne
                                Archer co–star in this film that was originally set to be shown in cinemas by MGM
                                in 2005, but was delayed by the takeover from Sony and eventually sent direct to
                                DVD.
                            <div>
                                <img src="../../../images/twilight.png" style="float: left; margin: 10px;" alt="" />
                                The project was in development for approximately three years at Paramount Pictures,
                                during which time a screen adaptation that differed significantly from the novel
                                was written. Summit Entertainment acquired the rights to the novel after three years
                                of the project's stagnant development. Melissa Rosenberg wrote a new adaptation
                                of the novel shortly before the 2007–2008 Writers Guild of America strike and sought
                                to be faithful to the novel's storyline. Principal photography took 44 days, and
                                completed on May 2, 2008; the film was primarily shot in Oregon
                            <div>
                                <img src="../../../images/unstoppable.png" style="float: left; margin: 10px;" alt="" />
                                Meanwhile, in a rail yard within the northern town of Fuller, two AWVR hostlers,
                                Dewey (Ethan Suplee) and Gilleece (T.J. Miller), are ordered by Fuller operations
                                dispatcher Bunny (Kevin Chapman) to move a freight train led by locomotive #777
                                (nicknamed "Triple Seven") off its current track to clear the track for an excursion
                                train carrying schoolchildren. Dewey attempts to take shortcuts, instructing Gilleece
                                to leave the hoses for the air brakes disconnected for the short trip. Dewey later
                                leaves the moving cab to throw a misaligned rail switch along the train's path,
                                but is unable to climb back on, as the train's throttle jumps from idle, to full
                                power. He is forced to report the train as a "coaster" to Fuller yardmaster Connie
                                Hooper (Rosario Dawson)...
                            <div>
                                <img src="../../../images/priest.png" style="float: left; margin: 10px;" alt="" />
                                Priest is a 2011 American post-apocalyptic sci-fi western and supernatural action
                                film starring Paul Bettany as the title character. The film, directed by Scott Stewart,
                                is based on the Korean comic of the same name. In an alternate world, humanity and
                                vampires have warred for centuries. After the last Vampire War, the veteran Warrior
                                Priest (Bettany) lives in obscurity with other humans inside one of the Church's
                                walled cities. When the Priest's niece (Lily Collins) is kidnapped by vampires,
                                the Priest breaks his vows to hunt them down. He is accompanied by the niece's boyfriend
                                (Cam Gigandet), who is a wasteland sheriff, and a former Warrior Priestess (Maggie
                                Q).
    <div style="position: absolute; bottom: 5px; right: 5px;">
    <a href="https://www.jqwidgets.com/" alt="https://www.jqwidgets.com/"><img alt="https://www.jqwidgets.com/" title="https://www.jqwidgets.com/" src="https://www.jqwidgets.com/wp-content/design/i/logo-jqwidgets.png"/></a>
    jqxTab headers display issue #134681
    admin
    Hi AllanD,
    You can call the “render” method of the Tabs to re-render it.
    $(“#tab”).jqxTabs(“render”);
    jqxTab headers display issue #134683
    AllanD
    Thanks, works perfectly.
    Allan
