jQuery UI Widgets Forums Angular jqxSplitter width of second panel 100% of total
This topic contains 2 replies, has 2 voices, and was last updated by  Martin 6 years, 2 months ago.
  • reven
    I’m using a fairly basic jqxsplitter, its nested deep down in other parts of the app, but the splitter itself is pretty basic.
    Theres an outer div with say a width of 1000px. The splitter width is set to 100% (even tried 1000 value). There are two panels one with min:300, not collapsible, another collapsible without the width set (so it should take up the remaining width).
    However, both panels width are set to basically 100% of the area (I have them printing out their actual element widths). This is messing up my panel content as it needs to be sized at 100% width, but this is over extending.
    However, as soon as I resize the panels via the splitbar, the width is correctly set and the content takes up the correct width.
    `<div #container style=”width:100%;height:100%;display:block;position:relative”>
    <jqxSplitter #usermatchingSplitter [panels]=”[{ min:300},{ collapsible: true}]” [height]=”‘100%'” [width]=”‘100%'”
    [orientation]=”‘vertical'” [theme]=”‘default'” [splitBarSize]=”5″>
    <div #panel1>width: {{getWidth()</div>
    <div #panel2>width2: {{getWidth2()}}</div>
    </jqxSplitter>
    how can i get it so, panel2 width is set to 100% of the remaining space???
    reven
    managed to get it to work with
    [panels]=”[{ min: 150, size: ‘70%’, collapsible:false}, { min: paneSize, size:paneSize, collapsed:true }]”
    paneSize I set in code via
    ngOnInit(){
        this.calcPaneSize();
      paneSize: number;
      calcPaneSize():void {
        let width = this.container.nativeElement.clientWidth - 300;
        if(isNaN(width) || width < 650) width = 650;
        else if(width > 1000) width = 1000;
        this.paneSize = width;
      @HostListener('window:resize', ['$event'])
      onResize(event) {
    just incase anyone has a similar issue.
    Martin
    Hello reven,
    Thank you for this update!
    Martin
