jQuery UI Widgets Forums Dialogs and Notifications Tooltip, Notification, Popover Jqxpopover offset values not taking dynamically.
This topic contains 1 reply, has 2 voices, and was last updated by  Martin 6 years, 7 months ago.
  • Hi team,
    i am using JQXPOPOVER in my project. i can maximize and minimize my application. so i want jqxpopover to be placed at right position after application resized. application size will differ from monitor to monitor according to resolution. Now i want POPOVER to be place at right position even after application resized. By setting the offset values dynamically my popover is dis-appearing.
    <jqxPopover #propertiesPopOver (onClose)="propertiesPopOverClose($event)" [showCloseButton]="true" [selector]="'#propertiespaneltour'"
      [arrowOffsetValue]="0" [theme]="'propertiesTour'" [position]="'left'" [width]="350" [autoClose]="false"></jqxPopover>
              if (this.propertiesPopOver) {
                    this.propertiesPopOver.position('center');
    this if statement will execute in my resize function where i will resize the application. while executing this if statement the POPOVER is dis-appearing
    kindly suggest a solution.
    Hanusaikrishna.
    Martin
    Hello Hanusaikrishna,
    Yes, when you update the popover’s position it closes.
    However, you can simply call the open method after that.
    Please, take a look at this Example.
    Martin
