jQuery UI Widgets › Forums › Dialogs and Notifications › Tooltip, Notification, Popover › jqxNotification with AngularJS: Databinding does not work
Tagged: Angular, angularjs, apply, bind, data, data binding, jqx-instance, jqxNotification, Notification
This topic contains 3 replies, has 2 voices, and was last updated by Dimitar 10 years, 5 months ago.
There seems to be a bug in jqxNotification used with AngularJS or at least in the example.
Please look at the example:
https://www.jqwidgets.com/jquery-widgets-demo/demos/jqxangular/#demos/jqxangular/notification.htmIf we click “Check mail”, the notification “You have new messages” is displayed. However, if we look at the source, I think that it is intended to display “You have 2 new messages”. There is something wrong with the databinding.
I need to be able to set the text of the notification, before I open it – if the example would work, I would also be able to do what I am up to do.
Thanks in advance for your help,
baderaHello badera,
Thank you for your feedback. This is just an issue with the example. You would have to change:
You have <b>{{data.length}}</b> new messages.
to
You have <b>{{notifications.length}}</b> new messages.
and the notification will correctly display “You have 2 new messages.”
http://www.jqwidgets.com/Thank you Dimitar for the feedback and that you have already fixed the online example. As I see, you also removed the “jqx-data” attribute from the jqx-notification directive, which surly makes sense (I wondered about it).
However, I still have a question:
Why does you open the notification with
$scope.notificationSettings.apply('open');
Why does this work? I mean, notificationSettings does not have a function apply assigned in the assignment in the controller:
$scope.notificationSettings = { width: "auto", position: "top-right", opacity: 0.9, closeOnClick: true, autoClose: false, showCloseButton: true, template: "mail" }
Can you explain that? (Yes, I am newbie…)
For me, the logical way would be: Assign a jqx-instance attribute, then invoke the method open of this object. But this seems not to work; the notification is opened but always empty.
MyApp.controller("notificationController", function ($scope) { $scope.notificationtext = 'notification...'; // jqy-notification instance will be point to $scope.notif later... $scope.notif = {}; $scope.openNotification = function (text) { $scope.notificationtext = text; $scope.notif.open(); }; $scope.notificationSettings = { width: "auto", position: "bottom-right", opacity: 0.9, browserBoundsOffset: 20, closeOnClick: false, autoClose: true, autoCloseDelay: 5000, showCloseButton: false, template: "info"//, blink: true } });
HTML:
<div ng-controller="notificationController"> <button ng-click="openNotification('hello world!')">Open...</button> <jqx-notification jqx-instance="notif" jqx-settings="notificationSettings"> <div>{{notificationtext}}</div> </jqx-notification> </div>
Thanks in advance!
baderaHi badera,
Please read about how the integration of jQWidgets with AngularJS is implemented here: http://www.jqwidgets.com/jquery-widgets-documentation/documentation/angularjs/angularjs.htm. Your question about apply is answered in the section Widget configuration.
