jQuery UI Widgets Forums Navigation Menu, Context Menu jqxMenu separator problem
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 10 years, 9 months ago.
  • jqxMenu separator problem #56334
    atomic
    I am using jqxMenu widget, everything works fine but when I try to validate markup on w3c markup validator I get this error.
    “The type attribute on the li element is obsolete. Use CSS instead.”
    I was using separator like <li type=’separator’> to style my jqxMenu.
    Any solution?
    Thanks.
    jqxMenu separator problem #56395
    Hello atomic,
    You do not have to worry about this. It is only used internally to create a separator from the list item and will not cause any issues in any browser.
